had this happen to me before...talk about a day killer. mine was a bit more identifiable...
#1
Well, that sucks.
Good news - Set only has 9K miles on them, I'm only buying one.
Bad news - The size is discontinued, and I need to wait a week for one to get here.
#2
#3
A stud ofsome sort. Can you remove it for a full view?
A(u). Klasse A, unbeschrankt, ungedrosselt
Compared to a British roadster, all Volkswagens are reliable!
nevAr Lose - DE Minister of Foreign Affairs - IPROfftopikstan
#4
It's a hose fitting. The small diameter and blotchy corrosion suggests it's probably for coolant flow to some sort of auxiliary cooler.
I don't practice llanteria
#5
#7
#8
looks like a stud that holds a caster wheel.....like on an office chair. sucks about the location![]()
#9
#11
#12
we still have people come in to my shop once in a while with punctures like that. they get all upset that we cant fix sidewall damage. then you get the old timers that still ask to put a tube in the tire
Dubstatic
REP860
CornStatuS
#14
Our new CX-7 is due for a new tire (under 1000 miles on the entire car) thanks to a nail where the tread and sidewall meet. Not even a payment made on the vehicle yet and $200 spent on a new tire.![]()
#15
#16
Tire came in, so I dropped the wheel off. Thought I would be funny and just walk in and say, "I think there is something wrong with my tire, can you help me?" and then show him this. I was not as funny as I thought...
Anyways, I pulled this out, and it was in there about 1.5 inches.
#17
Impressive!
My worst was a chunk of thin metal with a nail sticking out of it... the metal whipped around in the wheel well slicing up the fender liner and mud flap. The metal departed, leaving just the nail. Thankfully no paint damage. I made it 95 miles on the tire before the nail finally vacated its new home and left me with a flat.
#18
It can be patched, however the patch will came off after certain period of time, I have tires damaged like that caused from nails or drywall screws, and patched, it was mater of time and the tire started loosing air again, it was because the patch cant stand the sidewall flex.
#19
And by 2012 we should have a better way to patch tires or sealing them with some vulcanized rubber or something.
We sent a team to the moon 50 years ago! We can't patch sidewalls on tires? INSANE.
I *JUST* replaced a brand new tire with under 1,000 miles on it on our new CX-7 thanks to a screw too close to the sidewall (still in the tread).
#20
#21
#22
*sigh*
Here is the problem.
A tire generally has two main plies that are the main casing of the tire. These are the only plies on the sidewall of the tire. Some tires only have one, and some truck tires have three. They can be nylon, rayon, and a few other materials.
When those main plies are breached, they lose strength and start to come apart, just as if you ripped a piece of yarn in your favorite Christmas sweater. In the tread part of the tire there are more plies, two of which are woven steel. They can still come apart but they are much stronger and do not flex nearly as much as a sidewall does.
Patching it is not going to stop the sidewall plies from coming apart. This is why a tire sidewall bulges sometimes if you hit a pothole or something. The air is coming through the plies and is only being held in by the outer rubber itself.
#23
Add a new piece of sidewall with new plies on the inside, vulcanize it against the punctured part.
Win all around?
#24
#25
#26
Would your speed rating still be the same? What about the load rating? Tires are rated for way more load than the vehicle GVW but you have to account for cornering/braking/downforce loads.
There is just way too much liability involved with repairing tires. We don't live in some third world country, just do the right thing even if it costs you an extra few bucks.
#27
#28
Michelin spends a huge amount of money on R&D. They have done **** nobody else has done. They invented the radial tire. They have been working on the tweel for years. They have also worked on a tire with two air pockets so if you get a puncture in one side, the other side stays inflated. They are the only manufacturer with a single tire/rim instead of duals for tractor/trailers. They can't get any of it to work better than what is currently on the market and you can bet they have spend tens if not hundred of millions on this stuff.
#29
#30
