Results 1 to 8 of 8
Thread: Sway / Anti-Roll Bars...
  1. 05-08-2012 02:19 PM #1
    Searched FAQs for info regarding bars for B3 Wagon.
    ... admittedly it was 3am so I may have overlooked something.
    I have been putting off installing my subframe after installing VR6
    arms, rebuilt steering rack and powder coating because not sure if I
    should upgrade sway bar.
    I'm not planning on auto crossing or anything, but do enjoy and
    often seek out the curvy roads in nearby mountains & deserts.
    I have Bilstien HD's all around on FK springs, considering coils.
    Also, can bars for A2/A3's or Rado (not stock) be used?
    Any thoughts, advise & suggestions would be greatly appreciated.
    Thanks in advance!
  2. Member 91B3DUB's Avatar
    Jul 1st, 2010
    Durham, NC
    91B3PASSAT
    05-08-2012 02:37 PM #2
    you can use A/3 and corrado bars, im using a sway bar that came off an A3 lol and before that it was on a corrado its actually off the car now. did you have one or were looking for one?
    pushindubssince'89
  3. Member Bozwell's Avatar
    Aug 25th, 2003
    greenwood lake ny
    89 jetta GLI 2.0 16vT, 90 passat variant 1.9 TDI
    05-08-2012 04:43 PM #3
    Quote Originally Posted by 91B3DUB View Post
    is this true for both front and rear?
  4. Banned ellocolindo's Avatar
    Jan 14th, 2010
    05-08-2012 07:40 PM #4
    the tt webpage used to show the bars for hte corrado and passat with part numbers.
    they are similar to the point where you can interchange them. from part number stand point are different for the hardware kit part number i think.
    i have a shine racing rear bar for the centre of the rear beam and i am not sure if it will ever get used. it is off a mk3 car...
  5. Member Venkman's Avatar
    Jun 24th, 2005
    Harrisburg, PA
    94 Golf, 96 Wagon, 98 Jetta
    05-08-2012 08:27 PM #5
    i know the rear beam on the b4 is different from the mk3, but i think it is the same as the corrado. not sure if the b3 is the same as a b4 though.
    COYS!!!
  6. Banned ellocolindo's Avatar
    Jan 14th, 2010
    05-08-2012 09:02 PM #6
    the b platform is closer to the corrado than the mk3 platform
  7. Member Bozwell's Avatar
    Aug 25th, 2003
    greenwood lake ny
    05-08-2012 11:48 PM #7
    Quote Originally Posted by ellocolindo View Post
    that makes sense about the hardware kit since the passats have a larger lower shock bolt that the mk2/3 and corrado
  8. Member 91B3DUB's Avatar
    Jul 1st, 2010
    Durham, NC
    91B3PASSAT
    05-09-2012 09:57 AM #8
    Quote Originally Posted by Bozwell View Post
    yes it is. and also the b3 and b4 platforms are different in some aspects. I have an autotech rear sway bar, (solid) and also have the adjustment brackets. never got around to puttin it on the car. really dont need it but oh well
    pushindubssince'89
