Results 1 to 28 of 28
Thread: Cranks but won't start.
  1. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    1993 Corrado VR6, 2004.5 Jetta GLI, 2004 Ford F150 :)
    05-08-2012 02:39 PM #1
    Crummy situation ... the car cranks over like it's trying to start, but never actually fires up.
    There's gas in the tank. I did recently put in a new fuel filter, and I know the first start-up usually takes a little patience because the filter has to fill with fuel--but this has literally been 15 start-up attempts with no success.
    There was previously a very small fuel leak where the fuel exits the filter and heads toward the engine--the hose at that connection was brittle and coming apart. It would leak a little from there, but NOW when I've tried starting up the car, that area is bone dry.
    Any thoughts?
  2. Member 6BangSneezer's Avatar
    Mar 3rd, 2011
    Coral Springs SFL
    1992 Corrado VRT, HEMI
    05-08-2012 03:14 PM #2
    May want to check the crank positioning sensor. Harness accidentally came loose during my tranny swap and had the same issue. It cranked forever with no start. Reconnected and fired right up
  3. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    05-08-2012 07:04 PM #3
    Quote Originally Posted by 6BangSneezer View Post
    X2
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  4. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    2013 Charger R/T - 91 Corrado - 92 Corrado VR6
    05-08-2012 07:47 PM #4
    That's what was wrong with my car. The motor ran when pulled, put it back in and the sensor was bad.
    From what I hear they are very sensitive and commonly go bad. I had the same issue crank and crank with nothing. After replacing I felt it igniting after first good try. Fired up the second attempt
    They are expensive though. Thedubnutz has them for half the price of GAP but they're OE replacement, works just find for me
    ...furthermore it's the white plug located near where the trans meets the engine on the front side, not the top. It's on the same bracket with an identical plug that is black
  5. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    05-09-2012 02:48 PM #5
    Man I was so hopeful after reading these responses.
    Of course, then I go get under my car and the crank sensor is untouched, secure, and tight.
    I'm so frustrated. I've spend a ton of time doing the following:
    - new Godspeed radiator (with all the annoying fab/grinding work it took to make it fit)
    - figured out the wiring on the aftermarket slim fans
    - billet crack pipe
    - billet rad neck
    - new thermostat housing and mounting hardware
    - low-temp thermostat
    - low-temp fan switch
    - new coolant
    All I want to do is turn on the car so I can make sure all the new cooling stuff doesn't leak ... but the effer won't start. I'm about ready to pony up for a scan tool.
    Thanks for the help anyway!
    Vortex =
    My Corrado currently =
  6. Member vw16v88's Avatar
    Oct 4th, 2002
    Woonsocket, RI
    '92 Corrado SLC, '88 Scirocco 16v, '09 GLI
    05-09-2012 03:17 PM #6
    Have you tried to give the Idle Stabalizer Valve a good cleaning. If the car has been sitting for a while it might have got clogged up...happen to me.
    -Jeff
  7. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    05-09-2012 04:05 PM #7
    If I had an ISV, I'd check that ... but I did the delete years ago and drove the car all the time after that with no problems ...
    Appreciate the suggestion though!
  8. Member 2021cc8V's Avatar
    Apr 21st, 1999
    California...
    05-10-2012 12:21 AM #8
    - check fuel pump relay
    - fuel pump (they like to take a dump especially if it's really old)
    - if it's none of those, then start checking your ignition (ie. plug wires...pull off a boot and put it close to some metal, crank her over and see if it sparks)
    fuel, air spark....gotta have those in order to fire up.
    IF all else fails... lemme know and I'll bring over a match and we'll have a vw corrado bonfire....
  9. Member Tk2g60's Avatar
    Aug 26th, 2010
    Eastern PA
    1993 vr6 Corrado, 04 Frontier crewcab/ 2000 vr6 jetta(sold), 1991 g60(sold); 93 BMW 318ti(sold)
    05-10-2012 01:25 PM #9
    Edit: somehow I posted in the wrong thread. Sry
    Quote Originally Posted by ZEBLOR View Post
    You gotta pay to play my friend
    WTB: Estyles Headers
    My build thread-->The NeverEnding Story
    If you live in PA and own a Corrado click here-> Pennsylvania's Corrado's
    Shop Spoonfed Tuning for your Corrado essentials
  10. 05-12-2012 08:04 PM #10
    I had the same issue with my car after i over hauled the engine, it had spark, you could hear the fuel pump activating, but i had no injector pulse, turned out to be a bad ground. Easiest way to test for injector pulse is by taking a 194 bulb (usually found in a side marker light) bending the wires down and plugging the bulb into the most accessable injector connector, if it illuminates, then you'll know youve got working injectors
  11. Member Tomandante's Avatar
    Jan 30th, 2004
    Watsonville
    1993 VW Corrado VR6
    05-14-2012 06:28 PM #11
    I've been dealing with a similar problem, but my car starts after a few tries. Sometimes it does it and sometimes it doesn't do it.
    Sofa King uro
    C'mon man, you know that criticizing wheel size is the de facto way to show your mettle as an elitist car snob.
  12. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    05-14-2012 07:02 PM #12
    Swap Crank & Knock sensors connections - they look the same and you might have them crossed.
    Project Corrado RS: Keep Up
    MSD 12v VR6 coilpack setup/components For Sale: Here
    Other items for sale: Sparco, VR6 HVAC box, VR6 radiators, Mocal Oil Cooler: Here
  13. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    05-14-2012 07:24 PM #13
    My crank position sensor was clean, secure and above all BAD... Find someone to swap with you before you rule it out.
  14. Member -(Dubslinger)-'s Avatar
    May 28th, 2008
    Northern Va
    92 Corrado vr6 90 corrado g60, 90 jetta coupe vr6, 96 jetta vr6, 01 JTI VR6T, 96 slammed 2.0 jetta
    05-14-2012 07:24 PM #14
    Try a new battery
  15. 05-14-2012 10:27 PM #15
  16. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-14-2012 10:54 PM #16
    What does a tight and secure crank sensor have to do with its function? It's an electrical component with magnetic pick up, just cause you can't wiggle it doesn't mean it's good. Lmao!!!!!!
    Sorry man but they are exposed to constant heat and oil. They go bad and when they do, you can run your starter and battery into the ground and it won't start.
    Let's do a process of elimination here: spark? Yes? Fuel? Yes? = crank sensor
    Sent while sitting on my ass VIA my iPad
  17. Member lnoriel's Avatar
    Jul 31st, 2000
    Pasadena, CA
    1985 Golf GL with a 2.0l 16v, 1990 Corrado G60
    05-14-2012 11:00 PM #17
    Have you verified any of the following?
    1. Is gas being delivered to the fuel injectors?
    2. Do you have spark at the spark plugs?
    3. Have you verified the timing?
    85 Golf GL with 2.0l 16v
    90 Corrado G60 TEC 2RS
    corradog60project.blogspot.com
    mkiigolfproject.blogspot.com
  18. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    05-15-2012 03:19 PM #18
    Quote Originally Posted by HavokRuels View Post
    This was the point I was trying to make. A visual inspection on an electronic part very rarely gives you any information. Also I have read that the crank sensor also can stop both fuel and spark or one of the other intermittently if the ECU chooses. Bottom line I say replace it. If it wasn't the problem then you know to rule that out but I would bet a shiny new nickel that its the problem
  19. Member 6BangSneezer's Avatar
    Mar 3rd, 2011
    Coral Springs SFL
    05-15-2012 03:55 PM #19
    Quote Originally Posted by vdubCorrado View Post
    I think his reply was in response to post #5 but I do agree. It could look brand new AND secure, but if it's original replace it and continue from there. If money is an issue borrow one from a running VR to diagnose it.
  20. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-15-2012 03:56 PM #20
    I'll back bet you, make that two shiny nickels
  21. Member xtremevdub's Avatar
    Jun 25th, 2004
    Neo Tokyo, Florida
    1991 Corrado. Aqua Blue Pearl. 2004 Mk4 Golf (Daily)
    05-16-2012 12:42 AM #21
    Hey!!! I have a great Idea...
    Why dont you CHECK the CPS before you buy a new one..
    . you can do it with a simple multimeter and the Bentley gives you the specs..
    Or buy a new one or swap a working one from a friend...
    I have had 2 VR cars that would not start because of that damn sensor...
    Also.. did you put the fuel filter with the Arrow pointing towards the engine?????
  22. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    06-16-2012 07:40 PM #22
    Of course I did. I'm a novice, not an idiot.
    So after diagnosing a bad fuel pump, I replaced it today (getting it back in was a PIA, by the way). I sat in the driver's seat, all excited to fire it up after fixing the problem. I turn the key, and nothing. Zero. It used to at least TRY to start, but now there's just nothing.
    Of course, all the dash lights are lit and the digital numbers are displaying on all my readouts, so I know the battery is working.
    So pissed right now. I wanna take a baseball bat to this car.
  23. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    06-16-2012 07:49 PM #23
    So now you've reached true Corrado owner status.
    Does it crank at all now? And did you swap crank position sensors with someone? I assume you got power to the old pump but noting coming out correct? And now are you getting power to the new pump?
    Did you check spark? This ones easy, hook up a timing light and put it around each wire to see if you're getting spark from them all. That's how I confirmed a bad coil pack on my green one
  24. Member 2021cc8V's Avatar
    Apr 21st, 1999
    California...
    06-16-2012 07:57 PM #24
    Quote Originally Posted by thevisualedge View Post
    Just because you get lights on the readout doesn't necessarily mean your battery has enough juice to start the car.
    We've cranked the starter many times by now, so battery is getting drained.
    Check battery voltage. I'd recommend putting the battery on a trickle charger overnight.
  25. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    06-16-2012 09:35 PM #25
    SUCCESS!
    After checking the battery voltage and getting a wimpy 10.5 volts, I jumped it with our Jetta and it fired up after some minor sputtering. Once I knew the new pump was working properly, I fastened everything down and put the fuel tank cover back on.
    I've had an electrical gremlin for a while now (pretty sure it's from an aftermarket stereo install), so I'm 95% sure that's why the battery was weak.
    Now I just have to fix a leak where the fuel line meets the in-line filter, then I can take it out for a rip.
    I have to say, working on my Corrado FRUSTRATES THE HELL out of me, but that all seems to go away once I rev the engine.
  26. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    06-16-2012 10:00 PM #26
    Welcome to Corrado ownership, congratulations! Haha
  27. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    06-16-2012 10:05 PM #27
    Haha ... appreciate the welcome, but I've had this car for 15 years. I guess it's only recently that I've really started tearing into it.
  28. Member vdubCorrado's Avatar
    Nov 8th, 2001
    Baltimore MD
    06-16-2012 10:20 PM #28
    Got me beat, I've only had red rado for 11... But it was a figure of speech haha they're so damn frustrating but worth it as soon as you drive it! ...your power drain is exactly why green rado doesn't even have a radio in it... Some day I'm sure OT will but I like letting it sit a week or 2 and being able to start it again haha
