Results 1 to 3 of 3
Thread: 312mm brake upgrade mk6 golf
  1. Member DankNugz's Avatar
    May 19th, 2007
    Quakertown
    2011 Golf 2 Door TDI, 91 Golf 4 Door with 1Z TDI swap
    05-08-2012 05:09 PM #1
    Ive seen it discussed for every other generation of vw/audi, but I cant seem to find anything on upgrading a mk6.
    I own a 2011 Golf TDI, which has 288mm rotors. 312mm rotors are on mk6 GTI, Jetta 2.0T, and JSW.
    Any chance I could Just use 312mm rotors, carriers, and pads from any one of those models? If that's the case, when it comes time to do brakes, that's the way I want to go. I could go for a set of bright red GTI calipers, but my wallet is telling me not to do that
    Anyone out there done it to their mk6 Golf/Jetta? Is it possible?
    Quote Originally Posted by ravera View Post
    How could you forget the most important point of all? Arguing on an internet forum. You'll never win with your silly pushrods.
    Quote Originally Posted by X37 View Post
    I see your 18K dumped into a woman's economy car, and I raise you a poor mans Bentley. Seriously just buy a Used Phaeton and fuck bitches.
    Own VAG-COM hex/can interface - check my location and PM me
    Nov 17th, 2006
    Jacksonville, FL
    2010 TDI Jetta Sedan
    05-20-2012 07:26 AM #2
    Yes that works. ECS and others sell kits to do just that. Make sure they will clear your wheels though. Not sure if GTI brakes clear 16" wheels if you have them
  3. 05-24-2012 11:35 AM #3
    I upgraded to GTI brakes on my MKV Rabbit...they just fit into 16" wheels. I bought a complete set of front GTI brakes on the Vortex Classifieds for $400...never used, calipers,pads, carriers and rotors! On the fronts that's all you need..the rear upgrade requires you to change (or cut up ) the dust shields....to do that you need to pull the stub axles...and that requires an 18mm triple square bit..replace axle bolts they are "stretch torqued one time use" bolts..sure don't want to stess risk fracture from reusing old bolts..rear wheel falling off screws up your handling big time!
    96 Golf...Gone...But not forgotten..Great ride!
    2000 Passat GLX...Gone...But not forgotten either..have scars on my knuckles from all the "wrenching" to keep it on the road!
    2008 Rabbit S, VWsport springs/OEM shocks, GTI brakes all around, GTI rear swaybar...best balanced car I've had in a while!
