VWVortex.com - Brake noise
    Results 1 to 18 of 18
    Thread: Brake noise
    1. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      05-08-2012 06:27 PM #1
      Hello all. I have started hearing a noise with my brakes. First thing in the morning when I back up and apply the brakes, I get a clunk or pop noise from the left front wheel. It will pop again once I move forward and hit the brakes. It only does the noise one time when I first apply the brakes in either direction. Once the brakes have been used out on the road and are warm, there is no noise when changing directions. I've had this noise in another car I used to have and it was caused by the aftermarket brake pads not being exactly large enough and there was slight pad shifting in the caliper. Being this is a new car and has the OEM pads, I would hope there would be no pad shifting or movment in the calipers. Has anyone else heard this noise in their Passat?
    2. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      05-08-2012 07:28 PM #2
      I get the same exact noise. Backing out of the driveway, popping noise from the left front when I hit the brake to stop. It's not just once though, meaning if I let of the brake and then hit it again it will make the pop again. I think it might be strut/suspension related, it only seems to do it with the wheel turned.
      It go down in the DM
    3. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      05-08-2012 07:42 PM #3
      Quote Originally Posted by vwbrvr6 View Post
      Strange. Mine never makes the sound again until I change direction. It also will not do it once the car has been driven any length of time. Does yours make the noise after it has been driven and the brakes are good and hot? I smell a TSB on this issue.
    4. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      05-08-2012 07:47 PM #4
      Quote Originally Posted by brsexton View Post
      I'll have to take notice, but I believe it only does it just when it is cold like the first start of the day. I've only had the car for 6 weeks, and have just started to notice the noise the last week or so
    5. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      05-08-2012 07:51 PM #5
      Same here. I got mine at the end of March and just started hearing this last week. I only have 1300 miles.
    6. Member siryokohomo's Avatar
      Jun 4th, 2004
      Wormtown, Massachusetts
      2012 Passat TDI SE, 2007 Rabbit (trade), 1995 Jetta VR6 GLX, 1985 Jetta coupe
      05-08-2012 09:56 PM #6
      ditto
    7. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      05-14-2012 03:10 PM #7
      It will do it anytime I reverse. I noticed today I just stopped at a quicky mart for 2 minutes, got back in and backed up, car fully warmed up.
      Also when I got home, put it in reverse with the wheels straight and it still did it. Pressed the pedal 3 times and it made the noise. Pressed it 4,5,6 and no noise. Weird.
    8. Member veedubcos's Avatar
      Jul 12th, 2006
      Atlanta
      2011 CW GTI MT
      05-14-2012 03:30 PM #8
      My gti did that once and it turned out to be loose caliper bolts. Not saying that may be the case on a brand new car.. but its worth taking a look.
      1985 Golf | 1996 Golf | 1997 Jetta Trek | 2005 GTI | 2012 3.6 SEL B7 Passat | '11 CW Autobahn GTI
    9. Member siryokohomo's Avatar
      Jun 4th, 2004
      05-16-2012 05:55 PM #9
      My break noise seems to be getting more pronounced--and it only happens if the car is cold--has anyone taken their Passat in yet to check this out?
    10. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      05-16-2012 07:25 PM #10
      Quote Originally Posted by siryokohomo View Post
      No not yet, I'm waiting until I take it in on the 90 day courtesy check.
    11. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      05-23-2012 09:07 PM #11
      Something odd to add to this. I heard my wifes 2012 Jetta make this exact same noise. Just like my Passat, no clicking after the brakes heat up.
    12. Semi-n00b
      Oct 21st, 2011
      2012 Passat TDI SEL
      06-05-2012 03:50 PM #12
      My Passat is at the dealer now getting this checked out. Hopefully I'll report back with good news.
    13. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      06-06-2012 06:24 PM #13
      Quote Originally Posted by wilky View Post
      any news?
    14. Member
      Feb 17th, 2012
      Dallas, TX
      06-06-2012 09:39 PM #14
      We're just getting an intermittent squeak, but no clunks or anything abrupt.
      Partner: 2012 Passat SEL 2.5L, 2000 Audi A6 (non-Quattro), 1996 Audi A4 (non-Quattro)
      Me: 1995 Passat GLX VR6, 1987 Jetta GL, 1985 Jetta GL
    15. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      06-11-2012 02:13 PM #15
      My car is at the dealer now.....i'll report what they find.
    16. Semi-n00b
      Oct 21st, 2011
      2012 Passat TDI SEL
      06-11-2012 03:19 PM #16
      So, my problem was the squeak when reversing.
      They couldn't replicate it and the service manager said that his Passat does the same thing. They say its a rust build up that occurs overnight. My plan is to bring it back one evening and let them keep it to experience in the morning. The problem happens like clockwork in the mornings, but happens throughout the day as well.
    17. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      06-11-2012 08:51 PM #17
      Just got it back.......tech noted front subframe not torqued properly from factory. Re-tourqued subframe mounting bolts.
      Get to my house, put it in reverse, hit the brakes.....same popping noise is there LOL. Eh it's a lease so, not gonna worry about it. Leasing cars has really taken the frustration out of car ownership. U just say ehhh, it'll be gone in 3 years.
    18. 07-07-2012 03:46 PM #18
      The same noise on my Passat was repared at the dealer, with only 30 km, when hit the brakes at reverse.
      The dealer put some "glue" on the pad brake.
