Bump
Sent from my DROID RAZR using Tapatalk 2
#1
I have been working on a 2001 VW Passat 2.8 for a while now. I replaced the engine for a customer. Now its misfiring bad.
I did a compression check, everything there is good
Leakdown test - everything good
Replaced plugs
Replaced coil pack with known good one
Replaced spark plug wires with good ones
Its missing on 1, 5, 6, some times 4, sometimes 3
I have check all my vaccum lines, no leaks. Sprayed throttle body cleaner every place I can think of, and no change in idle.
I did replace the timing belt, but that is all good. Start's right up. Just shakes bad.
I did check for spark at the plug wires and its getting really good spark.
Any ideas?? HELP!
#3
God bless the homicidal maniacs... they make life worthwhile. - George Carlin
#4
Yep, checked it again. Its spot on.
If timing was off, the valves would hit the pistons, or throw a code
#5
what type of plugs did you use? i think oem is either bosch or ngk. i use and prefer ngk, but i've heard of other brands (i.e. champion, etc.) giving people a headache with misfires.
edit: also check the plug wells for oil. the inner valve cover gaskets have a habit of leaking oil into them and fouling plugs.
#6
I put in NGK.
So I had two plug wires crossed, I fixed that, and now the car wont even start WTF
#7
for the plug wires, i believe the order from back to front should be:
6-5-4 (driver side)
3-2-1 (passenger side)
the coilpack should have a diagram on it that shows where each number connects.
are there any other codes getting logged besides misfires? any pcv work done to it recently?
#8
100 pictures of parts on this thread http://forums.vwvortex.com/showthrea...7#post78006507
Don't offer me half the asking price and get angry cause I won't sell to you, and bash my threads, delete your comments then call a mod over nothing twice, 2 infractions.with your 100+ posts.
