Results 1 to 3 of 3
Thread: Vag com
  1. Junior Member
    Apr 16th, 2012
    RVA
    2001 Audi TT Base
    05-08-2012 07:26 PM #1
    After I had the turbo exhaust gasket blow out I have been getting these codes and my tt seems to be sputtering. I have already deleted the dtc's but they seem to come back. Any advice?
    Tuesday,08,May,2012,17:36:53:49347
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8N - Audi TT
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN: TRUTX28N
    Address 01: Engine Labels: 06A-906-032-AWP.lbl
    Part No: 8N0 906 018 L
    Component: 1.8L R4/5VT G 0003
    Coding: 07500
    Shop #: WSC 01236
    VCID: 3A75C0DE2644B89
    TRUTX28N AUZ5Z0A2142034
    3 Faults Found:
    16487 - Mass Air Flow Sensor (G70)
    P0103 - 35-10 - Signal too High - Intermittent
    16839 - EVAP System
    P0455 - 35-00 - Large Leak Detected
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 -
    Readiness: 0000 1001
    Ordered forge dv/bov and relocation kit
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 D
    Component: ESP 20 CAN V006
    Coding: 23049
    Shop #: WSC 01236
    VCID: 3D7FCBC2376A8F1
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    57-00 - Electric Circuit Failure
    27-10 - Implausible Signal - Intermittent
    Address 08: Auto HVAC Labels: 8N0-820-043.lbl
    Part No: 8N0 820 043 A
    Component: TT-KLIMAVOLLAUTOMAT D03
    Coding: 00140
    Shop #: WSC 01236
    VCID: 28510A96C8E83A9
    1 Fault Found:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
    Part No: 8N7 962 267 A
    Component: Central Lock/Alarm D05
    Coding: 15900
    Shop #: WSC 01236
    VCID: 3E7DCCCE3A6C949
    3 Faults Found:
    01366 - Opened Due to Crash Signal
    35-00 - -
    01559 - Drivers Door
    59-00 - Can't Unlock
    01560 - Passenger Door
    59-10 - Can't Unlock - Intermittent
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00009
    Shop #: WSC 01236
    VCID: E5CFC3A27F7A671
    1 Fault Found:
    00776 - Level Control System Sensor; Left Front (G78)
    31-00 - Open or Short to Ground
    THIS ONE HAS BEEN CAUSED BY COILOVERS
    End ---------------------------------------------------------------------
    Audi TT 2001 ROADSTER FWD
    BILSTEIN PSS9, DEFCON competition kit, NEUSPEED f/r adjustable anti sway bar, APR stage 1 ecu, APR stage 1 clutch, INJEN cold air intake race series, intake manifold spacer, light weight pulleys, FORGE hybrid DV/BOV, FORGE relocation kit, SPYDER led smoked taillights, smoked side markers
    May 7th, 2009
    02 TT 180Q (daily), 01 TT 225Q (on jackstands), 03 20thAE GTI (daily), 03 GTI 1.8T (on jackstands)
    05-09-2012 07:51 AM #2
    You need to pressure test the system for leaks.
  3. Junior Member
    Apr 16th, 2012
    RVA
    2001 Audi TT Base
    05-09-2012 09:26 PM #3
    I disconnected the Maf for sh!ts and giggles and now she is running better than b4 the gasket blew out. I guess the first code found in address 01 was causing the rest of the problems. Will pick up new one tomorrow. and run vagcom
