Results 1 to 8 of 8
Thread: Can anyone help me identify the source of squeeking sound (video inside)
  1. 05-08-2012 07:38 PM #1
    Hey guys,
    Last week my 2011 GTI starting making the most unbearable squeeking sound anytime I drive on a bumpy or rough surface. As far as I can tell, it's coming from the interior and it's coming from the passenger seat. However, it's hard to identify the source while you are simultaneously driving.
    Here is a link to a video so you can hear the noise I am talking about, it starts around 8 seconds in: http://www.youtube.com/watch?v=OpxT5...ature=youtu.be
    Does this sound familiar to anyone? Any thoughts as to what could be causing the noise? Thanks for any help.
  2. Member Swagger76's Avatar
    Sep 30th, 2011
    Las Vegas
    2012 GTI MKVI DSG 1986 Cabriolet MKI
    05-08-2012 07:46 PM #2
    Video not working for me.
    MKVI|APR K04|BSH|42dd|Neuspeed
    MKI OEM+
  3. Member Swagger76's Avatar
    Sep 30th, 2011
    Las Vegas
    05-08-2012 07:52 PM #3
    Got it to work. Wow that is a squeak? Check out the hand break button. Pull up lightly on handbreak when it starts sqeaking to see if it goes away. Might be it.
    MKI OEM+
  4. 05-08-2012 08:03 PM #4
    The original link was bad, I updated it.
    I'll give the hand brake thing a try
  5. Semi-n00b Foltzwagen's Avatar
    Jun 3rd, 2011
    Ft. wayne
    D.B.P.M. MKVI GTI, MKIV P.G. GLI R.I.P.
    05-08-2012 08:40 PM #5
    Check your sun visor clips man. I have a squeaky one in my car. That might be it.
  6. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    05-08-2012 09:01 PM #6
    doors maybe? i put about 3" of black electrical tape on the striker plate on the door jamb so when the door closes its a little tighter. took care of my squeek.
    2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
    Follow on instagram @glfsprtct1
  7. 05-09-2012 09:44 AM #7
    I have a squeak that I thought was on the passenger side until I asked my wife to hunt around for it while we were driving and she said it sounded like it was coming from the diver's side. Turns out it is the sunglass holder area. If I touch that area it stops. Release it and it eventually returns. Doesn't matter if the holder is open or closed.
    Your video sounds louder than mine, but give it a shot.
  8. 05-09-2012 07:42 PM #8
    Okay I feel like an idiot. I folded the rear seat down but when I folded it back up, it didn't fully lock back into place. That's where the squeeking noise was coming from. It sounded like it was coming from the front so I didn't think to check back there. Thanks for the help guys.
