My vr6 has no throttle cable. What year did they do away with them?
it wont work, u need a VR cable
97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
2.0 cables will work in a Mk3 Vr. They are shorter. You have to route them behind the Manifold, not through the valve cover notch and around the manifold.
This works really well when doing a shaved/tucked bay. The pedal feel will be slightly stiffer.
