Results 1 to 6 of 6
Thread: FS: MK2/Corrado Neuspeed sport lowering springs -- complete with rear caps and top hats (55.10.11)
    Oct 29th, 2001
    Redding, CA
    89 Tornadored GTI16v, 99 Titansilber M3
    05-08-2012 09:04 PM #1
    SOLD SOLD
    These are excellent springs for those looking for an increase in spring rate over stock with a mild drop that won't sacrifice handling. In other words, don't look any further if you're looking for stance, wheel "crush," killing your suspension geometry, or other nonsense.
    Neuspeed advertises a 1.25" drop front and rear:
    http://www.neuspeed.com/551011-neusp...pring-kit.html
    I used to run a set of these years ago, but have something else now. I don't know the spring rate for sure
    Please PM any questions if something isn't clear from my pics or description.
    I'm asking $90 picked up in the south bay.
    SOLD SOLD
  2. Member vdubbmk2's Avatar
    Sep 22nd, 2011
    Central Coast,California
    90 jetta 1.8L-96 golf 2.0L-91 E34-87 W124
    05-09-2012 04:54 AM #2
    theyrll fit on my mk2 4 door jetta right?
    whats that you said on the post about not knowing the rate what is that about?
    im in salinas and im interested in the springs
  3. 05-10-2012 09:41 PM #3
    Quote Originally Posted by vdubbmk2 View Post
    These springs will fit on any 4 cylinder Mk2 and Mk3s. If you put them on a VR Mk3, you'll be lower in the front.
    These are likely the Sport springs, not the Race springs, which are a bit stiffer than stock springs, sit lower than stock, but are still comfortable.
    I don't know what you're getting all bent out of shape about, not everyone knows the spring rates of everything they have.
  4. Member
    Oct 29th, 2001
    Redding, CA
    05-10-2012 11:20 PM #4
    Quote Originally Posted by lunisport View Post
    Correct on all counts.
    These are Neuspeed sport springs, as opposed to "softsport" or race. Yes, a bit stiffer than stock with a published 1.25" drop all around.
    Spring rates are also often proprietary information and hard to get reliable numbers on without testing them yourself. Googling revealed nothing about these springs rates -- I'll add that tidbit of info if I find it out
    Oct 29th, 2001
    Redding, CA
    05-13-2012 01:18 PM #5
    Bump!
  6. Member
    Oct 29th, 2001
    Redding, CA
    05-20-2012 12:24 PM #6
    Bump!
