Results 1 to 6 of 6
Thread: Auto-xing a mk4 1.8t
  1. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    2001 jetta wolfsburg, 1989 jetta gli
    05-09-2012 12:22 AM #1
    my car is a 2001 jetta wolfsburg edition only mods are under the hood and a tune
    so the auto-x season finally started and i competed in my first two events. i havnt done any suspension or tire/wheel upgrades yet because i wanted to see how well it did and what needed improvement. first thing i noticed is i need decent tires really bad.
    the most surprising part of the day though is that i had trouble controlling the rear end when pushed to the limit. there were several occasions i had to hit the throttle to correct over-steer surprising most people complain about their fwd cars understeering. btw im picking up a set of tires in about 2 weeks and im going to see how that changes the behavoir of my car(i know it will grip more but im concerned with under/oversteer).
    so my big questions are what suspension upgrades should i go with to auto-x my car my class allows coil-overs sway bars strut braces etc
    should i go with a cup kit from neuspeed or should i get coilovers
    i dont want to spend 1600$ on coilovers but i also want a set that performs and isnt built for the purpose of lowering a car..... keep in mind that the cup kit is 500$ so i want the coilovers to be cost effective compared to a cup kit basically i dont want to spend more then 800-1100 on coilovers
    second keeping in mind i had trouble controlling the back end a bit which sway bars should i go with front, both, and what size should i go with
    im not an idiot when it comes to suspension choice but i have never built or driven a car with auto-x in mind before so i would like the opinions of those who have been there
    Quote Originally Posted by G3T3I7 View Post
    because race springs
    Quote Originally Posted by Vegeta Gti View Post
    i love sacks
    Quote Originally Posted by bryangb View Post
    TCL isn't car enthusiasts. It's a forum for 40 year old guys to brag about their 2007 Hyundai Sonata. And to talk meaningless sh*t on anything VW
  2. Member greyhare's Avatar
    Dec 23rd, 2003
    Corvallis, OR
    '96 Jetta, '78 Rabbit, '79 GMC 3/4T 4x4, 2013 BMW F700GS
    05-09-2012 12:00 PM #2
    I would start with tires and tire pressure. The car should understeer; it is designed that way.
  3. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    05-09-2012 01:45 PM #3
    i did the chalk the tire sidewall trick. after a few adjustments my tire pressures were spot on and the rear stayed planted until i pushed the car to its limits
    i love sacks
  4. Member
    Apr 19th, 2005
    Vancouver, BC
    00 GTI 1.8T
    05-14-2012 05:53 PM #4
    Out of curiosity, what tire pressures were you running?
    Also, you may want to review suspension geometry before lowering your car. If you're serious about autocrossing, look into Shine kits
    projectsatin: malone tuned K04 1.8T with methanol injection
  5. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    05-14-2012 07:36 PM #5
    42 psi front 37 rear
    i love sacks
  6. Member Sinner44's Avatar
    Oct 11th, 2006
    Reno, NV
    2003 1.8T GTI, 1.8 16VT GTI Project
    05-15-2012 12:49 PM #6
    If you're still looking for advice when I auto-x my '03 1.8t GTI here are some things I do
    Lock the seat-belt and then bring the seat up to it to try and keep me planted
    I bring a weed/pesticide sprayer filled with water to spray the intercooler post and pre-runs (some guys mix in a good bit of methanol in the mixe or use pure methanol (or heet) to facilitate cooling and reduce heatsoak)
    Remove the spare tire and leave in the parking spot pre-run
    keep my car running after runs to keep fluids moving
    On the Coilovers vs. Struts and Springs...I would stick with a good set of sport/cup kit I use a Koni Sport Cup Kit and it works perfectly just adjust the dampening a small bit at a time. I think C-O's are a bit of a waste and unnecessary. A properly selected Strut and Spring combo with outperform a coilover setup.
    Bring setup sheets or a notebook with you and record the track layout while you're walking it and also the setup on your car... this will help you get a better idea of what setup works best on what type of course configuration
    Get the TT Control arm bushings if you haven't already...no poly's they're garbage...
    Be careful what parts you throw on the car they will put you in different classes making you much less competitive in a higher class
    Also for tires, I love my Dunlop Direzza Star Specs...they work amazingly on the course
    Take driving lessons... it's less about the car and way more about the driving lol trust me on this haha
    These are of course just some suggestions and opinions everyone has their own and everyone will argue with these lol
