Results 1 to 6 of 6
Thread: APR 93 octane tune 18 psi?
  1. Junior Member
    Jun 27th, 2011
    Fallston, MD
    '01 TT 225
    05-09-2012 01:16 AM #1
    So i got an apr tune almost 2 years ago but just installed a boost gauge tonight... I know I'm lazy.
    Went and drove around for a bit and boost seems to build nicely and quickly touches 17 psi then drops to 15 and fluctuates from 14-15 until it starts to drop at the end of the power band.
    So my question is, does the APR tune actually provide an honest 18 psi? or do I have a boost leak or some kind of other problem.
    Oh, and at idle seems to keep a steady 20 in Hg
  2. Member 1fast2liter's Avatar
    Apr 3rd, 2005
    beaver dam WI
    2000 audi tt 180q
    05-09-2012 03:07 AM #2
    you will peak at 18 or so and will drop to 14-15 till redline... mine des it too. a manual boost controler and 20psi all the time is doable.
    infinity front,votex rear,st coilovers,eurodyne tapp 1000cc tuned,hks ssq bov, pte 5857 pagparts turbo kit with 38mm tial wastegate. spec stage 3, custom intake, bbm fuel rail, modded 225 exhaust,ecs bleeder block,mbc,fmic,bfi mounts,cm flywheel,
  3. Junior Member 12vGtiVR6's Avatar
    Jan 15th, 2011
    Waltham ma
    2000 GTI VR6 12V, 2001 Audi TT 263
    05-09-2012 03:40 PM #3
    Ive got a KN intake, Apr TIP and Stage 1 Flash 93, On the highway i peak at 20psi and it stays
  4. Junior Member aTTlas's Avatar
    Feb 26th, 2010
    01 225TT
    05-09-2012 04:33 PM #4
    Huh. My APR 93 will spike to 25, and will hold solid at 20 just fine. Apart from the Forge DV, the car is otherwise stock.
  5. Junior Member
    Nov 16th, 2011
    San Francisco, CA
    '02 TT 180qc
    05-09-2012 04:43 PM #5
    I have stage 1 93 on my 180q and it spikes to 20 and holds at 16-17. I would imagine that same tune on a 225 would have higher boost?
  6. Member Currancchs's Avatar
    Feb 24th, 2011
    Nashua, NH
    2001 Audi TT 225Q; 1998 VW Cabrio (Sold)
    05-09-2012 06:42 PM #6
    Stage II (Just deletes rear cat over stage I) APR 93 octane tune - Spike to ~19.5, holds 15-16 psi. Although I have some other issues that MAY be causing slightly low boost requests. This log was 3rd gear, just over a 19 psi spike I think.
    Image Hosted by ImageShack.us
    Please ignore the Y-axis label, it should be mbar boost (absolute pressure, not gauge, subtract 1000 mbar to see boost gauge pressure)
    MkI TT FAQ Vorsprung Durch Technik
    It is more fun to drive a slow car fast than to drive a fast car slow. - Abner Perney
    Have you ever noticed, anybody driving slower than you is an idiot, and anyone going faster than you is a maniac. - G. Carlin
    hockeystar17mnj: Yea stock is looser than a new jersey hooker (6sp. GTI shifter feel)
