Results 1 to 8 of 8
Thread: Audio Volume turns down ??
  1. Member nicolas.gagnon's Avatar
    Sep 5th, 2006
    New-Brunswick, CANADA
    2011 Volkswagen Jetta TDI; 2003 Volkswagen Jetta TDI
    05-09-2012 01:34 AM #1
    A few times already, when I backed into my driveway, I noticed the volume of my music going really low...then it came back - figured it was a new feature...anyways... I was on my way home from work tonight, with the music blasted and singing quite loud - when the volume turned itself down for some reason (I noticed because I could hear myself singing.....it aint pretty)...and when I wanted to turn it up...the volume was still quite high, but it sounded like it was below half !!!!
    has anyone encountered that problem yet ??
    2011 Volkswagen Jetta TDI Comfortline w/ Multimedia, Sunroof and DSG.
    2003 Volkswagen Jetta TDI GLS w/ Leather, Sunroof and 5SPD.
  2. Junior Member
    Sep 11th, 2011
    MKE
    MKVI GLI
    05-09-2012 01:38 AM #2
    Check what your speed sensitive volume control is set at.
    Sep 19th, 2008
    Vancouver, BC
    05-09-2012 05:12 AM #3
    Your car is telling you to stop singing.
  4. Member VWskate's Avatar
    Apr 12th, 2007
    Massachusetts
    2008 CW Jetta
    05-09-2012 01:36 PM #4
    Yup. It's the speed sensitive volume control. It's suppose to be that when the car is generating more noise, it will slightly increase to keep the volume at the same level, and the same goes for slowing down creating less noise. You can turn it off in the radio settings, bearing which radio you have.
    My mkv had it and I absolutely hated it. I'm listening to the music at that volume, because that's what I want to hear it at. It's like having that annoying jerk off in shotgun that always wants to put on his music or turn it down to tell you some crap story you don't care about. My car, my rules, my music.
    Sent from my iPhone 8 using Tapatalk
  5. Member nicolas.gagnon's Avatar
    Sep 5th, 2006
    05-09-2012 01:48 PM #5
    Quote Originally Posted by macleanshaun View Post
    I know...shuddup lol
    And might be the volume sensitive, but i was going 120 kmh when it turned down,,,,i know it usually goes up, never seen it go down when going that fast
  6. Junior Member TransientMole's Avatar
    May 7th, 2012
    Littleton, CO
    2012 Jetta GLI Autobahn/DSG, 2006 Jetta 2.0T
    05-09-2012 05:37 PM #6
    Just a suggestion - but might be the load protection on the crossover kicking in - That happened to me all the time on my mkv, if I had the bass cranked all the way up and the volume too loud (Especially with the fader set to more on the fronts which couldnt handle it), any heavy bass part of the song would kick that load protection in, and the volume would turn down automatically for a few seconds, then it would come back up after the load subsided.
  7. Member nicolas.gagnon's Avatar
    Sep 5th, 2006
    05-10-2012 02:06 AM #7
    Quote Originally Posted by TransientMole View Post
    Just a suggestion - but might be the load protection on the crossover kicking in? That happened to me all the time on my mkv, if I had the bass cranked all the way up and the volume too loud (Especially with the fader set to more on the fronts which couldnt handle it), any heavy bass part of the song would kick that load protection in, and the volume would turn down automatically for a few seconds, then it would come back up after the load subsided.
    That makes lots of sense - since i had the volume way up... Thanks !!!!
  8. Member gt4ever's Avatar
    Jun 9th, 2012
    2012 1.4 tsi comfortline (Euro)
    02-27-2013 06:03 AM #8
    I have a similar problem but the other way around. My volume goes up for no reason I think. I'm not sure what causes it . Happened three times this morning. That's why I posted this up here to get solutions about it. I tried to go into the speed sensitive volume control and I'm not sure how to turn it off. When its in the middle, does it means its off? Need help thanks.
