Results 1 to 16 of 16
Thread: Offset questions
  1. Junior Member
    Jun 8th, 2011
    Connecticut
    05-09-2012 03:18 AM #1
    Okay so i have a 2003 vw passat, and i plan on buying a new set of wheels tomorrow and just wanted to know a few things. The wheels i'm purchasing are 5x114.3 17x9 all around with an offset of +25mm. I would be purchasing 20mm adapters all around as well my big question is can it work? will it poke? and how much will it poke? thank you for any insight or advice you can give, pics of similar setups would be grateful as well
  2. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    Bagged B5.5 1.8T/81 rabbit diesel/tons of B3's
    05-09-2012 06:48 AM #2
    I believe you're going to poke like crazy with that setup. I'm running an 18x10 et45 with a 20mm spacer out back, and I poke a bit. You're going to be 20 more than that.
  3. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    05-09-2012 08:51 AM #3
    Quote Originally Posted by B5.5Lucy View Post
    Quote Originally Posted by vdubb3dan View Post
    Yeah.... um... those are NOT going to work. Not at all. You will be effectivly running a 9" wide wheel with an ET of 5. Thats nuts.
    To put it into perspective.... this is a 9.5" ET ~32 on my wagon:
    You will poke 21mm more than me. Thats .08 inches
    And that's just the rear.... on the front, you'll poke more than 26mm more than my 8.5 ET 25's - thats a FULL inch
    Either redrill the wheels if you absolutly must have them (if they are redrillable that is), or find new wheels.
    Note, even if you were to redrill, on the fronts, you would STILL poke 6mm more than me, and on the rear you would poke 1mm.... so even a redrill poses problems on the front.
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  4. Junior Member
    Jun 8th, 2011
    Connecticut
    05-09-2012 01:05 PM #4
    so the verdict is i poke like crazy pretty much?
  5. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    05-09-2012 01:11 PM #5
    Totally
  6. Junior Member mkIVGLi117's Avatar
    Jun 7th, 2011
    CT
    04' GLI
    05-09-2012 01:22 PM #6
    what if he runs it with smaller adapters? i'm a complete noob in the wheel department haha so don't get all upset with me.
    if you run an et of 25 and run like 15mm adapters, wouldnt it not poke, have 10mm clearence btw wheel and fender?
  7. Junior Member
    Jun 8th, 2011
    Connecticut
    05-09-2012 01:22 PM #7
    but in like a good way...?or like a nah dude dont even touch that way
  8. Junior Member mkIVGLi117's Avatar
    Jun 7th, 2011
    CT
    04' GLI
    05-09-2012 01:23 PM #8
    btw E CODE... DOPE PASSAT! cleanest ive ever seen.
  9. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    05-09-2012 01:35 PM #9
    Quote Originally Posted by mkIVGLi117 View Post
    No worries. Yes, smaller adapters would make it a little better... but not really by much. Thinnest you can go is about 15mm (but I wouldn't trust them), and that doesn't help at all... reduces poke by 5mm...
    Poke is really up to each person.... but it's in the range of huge fender damage if you bottom out at all... so yeah, I'd consider it in the 'don't touch' kinda way.
    Thanks, it won't look like that this year... going to raise it and toss on my 17" Denvers for this year.... make it more usable as a wagon....
  10. Junior Member
    Jun 8th, 2011
    Connecticut
    05-09-2012 01:50 PM #10
    sorry to bother you guys with another offset question...what if i ran 17x8.5 et43 same bolt pattern 5x112
  11. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    05-09-2012 01:55 PM #11
  12. Junior Member mkIVGLi117's Avatar
    Jun 7th, 2011
    CT
    04' GLI
    05-09-2012 02:00 PM #12
    @ ECODE either way, it looks mint. its nice to see a clean wagon now and then.
  13. Junior Member
    Jun 8th, 2011
    Connecticut
    05-09-2012 02:04 PM #13
    that helps alot thanks e code
  14. Junior Member mkIVGLi117's Avatar
    Jun 7th, 2011
    CT
    04' GLI
    05-09-2012 02:04 PM #14
    & thats a sick thread. very helpful
  15. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    05-09-2012 02:26 PM #15
    Thanks, I created it this morning after this thread was made
    Figured we could put everything in one place. There is a similar thread in the Mk6 forums which is where I stole the idea from
  16. Member vdubb3dan's Avatar
    Apr 7th, 2004
    Scranton PA
    05-09-2012 03:37 PM #16
    [QUOTE=E CODE;77310624]Thanks, I created it this morning after this thread was made [QUOTE]
    Was gonna do the same when I got home from work. You beat me to it.
