VWVortex.com - B7 Passat Thrown in Reverse whilst driving HWY speed
    Results 1 to 7 of 7
    Thread: B7 Passat Thrown in Reverse whilst driving HWY speed
    1. Junior Member
      May 9th, 2012
      Temecula
      2012 Passat TDI SEL
      05-09-2012 04:34 AM #1
      Imagine this scenario. You've been driving a manual transmission vehicle for the last 15 years. You finally make a decision to get yourself in a NEW 2012 AUTO/DSG B7 Passat SEL. While Driving to you find yourself needing to downshift. You instinctively reach for the Shifter and attempt to throw it in 3rd gear while pressing a clutch pedal that is not there.
      What I thought was 3rd gear was actually Reverse. Nothing really happened. The car just coasted as I immediately realized what I have done and shifted back into drive.
      There was no loud clunk, explosion or what not. The car simply engaged back into drive and drove normally.
      So before anyone beats me up over this. Yes it was a stupid idiot mistake. Aside from that my question is..
      Is there any unforeseeable damage to the DSG Tranny that I am not seeing. My understanding after some reading is that most modern vehicles have an inhibitor for idiot mistakes such as this. But I found nothing related to the DSG.
    2. Member turboDSG's Avatar
      Feb 1st, 2009
      Carlsbad, CA
      GLI Gen 3
      05-09-2012 04:41 AM #2
      after pondering this for a few moments, I am pretty sure you were in neutral and not reverse. It's already been a while but I do not think it is possible to put the DSG in reverse while driving. You have to depress the brake to start the engine, etc, etc, the system is pretty intelligent.
      I would not loose any sleep over it.. you would know if your car was in reverse and real damage was done
      2014 GLI Autobahn DSG | Unitronic Stage 1 | Neuspeed P-flo Intake | Maniacs Paddle Shifter Extensions | Carbon Fiber Wrap Interior Trim | deAutoKey HIDs & LEDs | Yellow Laminex Fogs | 35% Tint | 3M Gloss Black Roof | VCDS in North San Diego County Coast |
    3. Member turboDSG's Avatar
      Feb 1st, 2009
      Carlsbad, CA
      GLI Gen 3
      05-09-2012 04:50 AM #3
      double post!
    4. Member
      Apr 21st, 2012
      Millersville, MD
      2012 Passat TDI, 2005 Ford F-250 6.0 diesel, 5 2015 Lincoln MKZ Hybrid, 2007 Artitic Fox 5th Wheel
      05-09-2012 12:12 PM #4
      The computer will not allow it.... BUT, if you leave it there, once you coast down to ??? speed, it WILL finally go into reverse. But by then you should have realized what you did and shift back into a forward gear.
      2012 Passat SE TDI NAV
      2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
      2007 Arctic Fox 30' Fifth Wheel
    5. Junior Member
      May 9th, 2012
      Temecula
      2012 Passat TDI SEL
      05-09-2012 12:54 PM #5
      That is what I figured. The car behaved exactly as if it where in Neutral. So that is great to hear...So nothing hurt asside from my Pride.
    6. Junior Member
      May 9th, 2012
      Temecula
      2012 Passat TDI SEL
      05-11-2012 02:39 AM #6
      Can anyone explain the technical mechanics behind the safety inhibitor for situations such as this. It was amazing how easy I was able to throw the car in Reverse. If it were not for the VW Engineers protecting me from myself I may have left a Transmission yard sale all over interstate 15.
    7. Member capclassicv2's Avatar
      Mar 2nd, 2007
      Maryland
      2013 Chevy Cruze 2LT
      05-11-2012 08:54 AM #7
      I can't give you technical mechanics but I believe most modern cars are electronically controlled, especially in automated transmissions. While you're moving and the brakes are not engaged, it locks the transmission from shifting into reverse or park. Look at it like a wall. The wall is only up while you're moving. You may need to switch it into neutral, so that is allowed. But neutral basically just disengages the transmission from the wheels so it wouldn't hurt the transmission to engage and reengage while moving.
      Actually going into reverse while moving forward would most likely chew up the gears, as they move in a direction that's not the same as the direction of travel.
      CURRENT: 2013 Chevy Cruze 2LT
      PREVIOUS: 2009 VW Tiguan SE; 2006 VW Passat 2.0T
