Results 1 to 7 of 7
Thread: ABS Error
  1. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    05-09-2012 06:00 AM #1
    I just got my VCDS cable today and did some tweaks like cluster staging, DRL option in MFD, fogs as DRLs, driver seat heat memory, Turned XDS up to 2, enabled TSC, and a couple other things.
    Now I'm getting fault codes for all sorts of things. Cleared them all, but the ABS one keeps coming back. Also had to unplug and replug the cable a few times before I could get 09 Central Electronics to respond.
    Wednesday,09,May,2012,02:46:36:61587
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
    VIN: WVWED7AJ2CW161400
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
    Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
    Component: 2.0l R4/4V TFSI 0010
    Revision: E3H26--- Serial number:
    Coding: 0403010818070160
    Shop #: WSC 01357 011 00200
    VCID: 78FF5CCD0BC86A9
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Component: ESP MK60EC1 H31 0121
    Revision: 00H31001
    Coding: 114B600C492800FB880F06E492190041B70800
    VCID: 7BF543C1FAFE411
    1 Fault Found:
    01309 - Power Steering Control Module (J500)
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 167
    Mileage: 8687 km
    Time Indication: 0
    Date: 2005.14.30
    Time: 02:43:00
    Freeze Frame:
    Count: 0
    Count: 2
    Count: 12288
    Count: 8212
    Count: 43776
    Count: 1536
    Count: 251
    Count: 0
    Address 08: Auto HVAC (J301) Labels: None
    Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
    Component: AC Manuell H19 0404
    Revision: 00001016
    Coding: 0000001002
    ASAM Dataset: EV_ACManueBHBVW36X A01010
    ROD: EV_ACManueBHBVW36X_VW36.rod
    VCID: 800FB42D1B18A29
    Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
    Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
    Component: BCM PQ35 M 110 0651
    Revision: 00110 AC
    Coding: 6F180A3A80012A04000800C1700003804801038643018D2064 8020000040
    Shop #: WSC 23320 444 12345
    VCID: 3D718DD9A46A8F1
    Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 07101 26 0512
    Coding: 009795
    Address 15: Airbags (J234) Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
    Component: AirbagVW10G 013 0724
    Serial number: 003GVRA0UCJJ
    Coding: 00003131
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360_VW36.rod
    VCID: 3F8DF7D1A6669D1
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5K0 959 339 A HW: 5K0 959 339 A
    Component: BF-Gewichtss. 004 0001
    Serial number: ---0000R--000017G600
    Crash sensor for side airbag; driver side:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H01 ----
    Serial number: 3572MSME7F6B1365ZZZ4
    Crash sensor for side airbag; passenger side:
    Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H01 ----
    Serial number: 3582MSME0A4E6465ZZZ0
    Crash sensor for side airbag; rear driver side:
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME70346679ZZZX
    Crash sensor for side airbag; rear passenger side:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME4A456309Z
    Crash sensor for front airbag; driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME74170629ZZZC
    Crash sensor for front airbag; passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME56041C29ZZZG
    Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
    Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
    Component: Lenks.Modul 008 0080
    Revision: -------- Serial number: 90422KJH001AR
    Coding: 5080140000
    ASAM Dataset: EV_SMLSNGKUDS A05001
    ROD: EV_SMLSNGKUDS_VW36.rod
    VCID: 70EF64EDABB8329
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
    Component: KOMBI H03 0607
    Serial number: 00000000000000
    Coding: 270F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 366392F5895C5C9
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 H HW: 1K0 907 951
    Component: J533 Gateway H42 1620
    Revision: H42 Serial number: 161011F2001921
    Coding: 350000
    VCID: 356195F99C5A571
    Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879 HW: 5N0 919 879
    Component: Kompass 001 0001
    Revision: 00001000 Serial number: 1225223RF2C606
    Coding: 0000002
    VCID: FEF3CAD5A9ECD49
    Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H03 0607
    Coding: 000000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
    VCID: EADBF6850D64489
    Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
    Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
    Component: SG EXT.PLAYER H13 0240
    Revision: A1001003 Serial number: 7661090217
    Coding: 010000
    VCID: 2959498940E2031
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2117
    Coding: 0001076
    VCID: 3169A1E9A8327B1
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 M
    Component: EPS_ZFLS Kl. 74 3201
    Revision: 00H20000
    VCID: 3467A8FD57204E9
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Coding: 0001076
    VCID: 326BAEE5AD34409
    Address 56: Radio (J503) Labels: None
    Part No SW: 1K0 035 164 C HW: 1K0 035 164 C
    Component: LOW NAR SDARS H02 0004
    Revision: -----03S Serial number: VWZ4Z6L3190736
    Coding: 01000400040005
    Shop #: WSC 23320 444 105100
    VCID: 224B5EA53DD4D09
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
    Component: TELEFON H09 2902
    Revision: 1B001001 Serial number: 00007661114347
    Coding: 0A10040000010100
    ASAM Dataset: EV_UHVNA A01719
    ROD: EV_UHVNA_VW36.rod
    VCID: 275D4FB15EF6351
    End ---------------------------------------------------------------------
  2. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    05-09-2012 01:58 PM #2
    Post the Auto-Scan prior to any modifications if the ABS fault was the end result of modifications you made. The Coding and Adaptation logs found in the C:\Ross-Tech\VCDS\Debug folder may be helpful as well.
    Edit: The BCM will not communicate if the doors are locked, so those results sound normal:
    http://wiki.ross-tech.com/wiki/index...us_%285K/52%29
    Dana Marie
    P.S. No Scan = No Soup
  3. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    05-10-2012 01:50 AM #3
    Autoscan from before the error code:
    Tuesday,08,May,2012,23:39:28:61587
    Chassis Type: 7N0
    Revision: 00H31001
    Revision: 00001016
    Coding: 0000001002
    Cannot be reached
    Coding: 00003131
    Serial number: 3522QSME4A456309ZZZX
    Coding: 5080140000
    Coding: 270F01
    Coding: 350000
    Coding: 0000002
    Coding: 000000
    Coding: 010000
    Coding: 0001076
    Revision: 00H20000
    Address 46: Central Conv.
    Cannot be reached
    Coding: 0001076
  4. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    05-10-2012 02:27 AM #4
    Okay I probably solved it just from your wiki...
    "Driver Steering Recommendation (DSR) in activated in Brake Electronics but not in the Steering Aid Control Module or vice versa."
    I know that I changed the DSR settings, and I know I saw those settings in more than one module. So I probably didn't get them both somehow. I'll go back over things in the morning and we'll see.
  5. 05-10-2012 03:03 AM #5
    Fix ?
    Activate needle illumination in ALL MICRONAS cluster since 2004 up to 2010. Activate STAGING for all NEC cluster since 2008 even if not availabe in adaptation chanel.
  6. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    05-10-2012 10:54 AM #6
    ...And that was it! DSR was set to "2" in ABS, but set to "0" in Steering Assist. I set them both to "2" and no more fault code!
    I'm an idiot
  7. 05-11-2012 03:13 AM #7
    I got this same Error last time when I replaced ABS but no 44-Steering Assist. After replaced 44 - intermited fault with J500. Unfortunatelly 44 was adapted to the MK60EC1 not MK60, and problem gone.
