so do you think 17mm spacers with hub centric would be ok/good
#71
That sounds about right. VW upped the ET on the Mk5 and 6 vehicles. Which actually is great for people who want to adapt them onto other cars, but for us they cause rubbing issues....
#73
They would only get you closer to stock.... probably not make it look any different than your last wheels.
#75
For posterity...
18x8.5 ET43 w/ 215/40-18
+10mm fr Final ET33
+15mm rr Final ET28
#76
Excellent! Now we have sedans to compare to, and a b5 as well.
#77
More
Same setup, but 5mm spacers front and back for an ET38 all around.
#79
No.... that's only 3mm, it wouldn't even be noticeable....
#81
Will audi fat fives fit good without rubbing, fenders being rolled, needing spacers?
I'm dropped 1.5 inch. The wheels are 17x8 with 35et.
#82
Fat fives are the wrong bolt pattern I think. If they are from the mk1 tt then they are 5x100. Most people run flat fives, which are 5x112.
#84
Sorry, that was supposed to read 'run flat fives'....
Flat Fives are 18" and come from the A8 and are 5x112. Most people need a small spacer to clear suspension on B5's.
If you are looking at 17" Fat Fives, they will NOT fit your car as the bolt pattern is wrong. Don't even bother trying to get them to fit, as you'll need adapters that will put them into the low teens for offset and be a pain in the ass trying to get to work.
#85
Fat fives came in 5x112 too, on the A6, for example
http://forums.vwvortex.com/showthrea...Fives-(York-PA)
\\_\__\___http://lowdownlabs.com/ ___/__/_//
Passat W8 Sport 6 speed manual
ST Coilovers | Miro 111 19x9.5 | Achilles ATR Sport 235 35 19 | COAM
SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
#86
#87
Ah. I stand corrected.... I would be wary though, and check the bolt pattern before buying as most fat fives I see are the tt ones.
If they are the 5x112 ones they should bolt right on.
#88
Hey guys I need some help. I have 18x8et44 BBS CK's. I had mounted a scrap 235/45 18 on one yo test fitment. They hit the control arms just a little bit in front. I plan on going with 215/35 18 tires to help but Ill still need spacers. I want to get a little staggered look. What sizes should I run? Thanks!
2004 BMP Passat 2.8L 30V V6 5 spd. M/T
I love cars, it's not just a car to me. Its a passion, something that people far and few between can understand and relate with me.
(that's how I pick my friends)
#89
Depends on where you want them to sit overall. I would say probably 10's in front, and 20's in the rear.
#90
#91
Ok thanks guys! Any brand recommendations?
#92
Brand doesn't matter too much, but make sure you try to get something hubcentric to our cars which is 57.10mm. Ecs tuning has some nice stuff.
#93
I was looking on raceland, esetuning, bfi, etc, are they ok as long as they are hub centric?
#94
You need them to be made hubcentric.
Then you can get centering rings for the spacer-wheel contact.
#96
MST is good people.
Just send them the measurements, I'm sure they will ask for them anyway...
#97
They sell premade spacers as well it looks like...
#98
ive got 19x8.5 e.t 38
just bought tires for them and tire size is
235/35/19
would i be able to tuck the tires ?
and go pretty low on my car and also would i need any spacers ? i do want the rear to poke a little
#99
Any help would be appreciated: 19x9 offset: 60 . I am currently looking at a 20mm adapter. I think it is a little low and planned on fine tuning with 1 mm spacers afterwards, but i would rather have the adapter built to the proper size to begin with. Also, what size tires do you think would fit?
No. 2944 - BMP - SOLD
2002 Matte white with pearl (dipped) 2002 Passat GLX, 5 speed, (1 of 22 in N.A. in this configuration) Koni coils, Hella bi-xenon retrofit, ECS stubby antenna, de-badged, B5 all red tails.
#100
Poke or Tuck, pick one... I had 215/35/19's on my 19x8.5's and they stretched a little bit.... 235's are pretty meaty (I had them on my 9.5x19's)
ET 40 would work on the front, but if you are a 4mo it will rub on coilovers on the rear. You'll probably want a bit bigger of an adapter. ET 25 would put them at the same point at the fender as my wagon was in the rear. And ET 30 on the front would put the fronts at the same points as my fronts in my pics.
Tires, depends if you need stretch. a 215 could go on if you stretch, 225 as well...
#101
How much wiggle room is there on the front? 20mm adapters for an offset of 40 will clear, but im not a huge fan of stretch. I was hoping to run 225/35/19s up front but i think it will still touch the spindle arm. Im not 4mo, but am running koni coil overs.
#102
right now ive got 235/35/19 what could i do with them ?
make them tuck or poke ?
without rubbing
#103
Right now? try tucking I guess...
#104
you think i would rub if i were to tuck them ?
and would i need to get my fenders rolled ?
#105
