Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 106 to 140 of 242
Thread: Need help with offsets? See and post here a.k.a the fitment thread
    Oct 30th, 2010
    Modesto
    1998 VW passat wagon
    09-16-2012 03:18 PM #106
    but the only thing i would only rub is the fenders right not the control arms or anything else right so just roll the fenders and i should be good ?
  2. Member passatv6AF's Avatar
    Nov 4th, 2011
    Chicago
    B5 5MT UNITRONIC TUNED, B7 6MT TDI
    09-16-2012 09:05 PM #107
    17x7.5
    Et25
    225/45/17
    Will they stick out too much??
  3. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    Formerly London Dub B5.5 Passat V6 4mo Wagon, MK6 GTI 6MT
    09-16-2012 10:42 PM #108
    No, not at all...
    Buy my clear GTI sidemarkers cheap!
    Will VagCom Mk5 and 6 in the GTA for donuts!
  4. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    09-18-2012 04:08 PM #109
    Hey, im new to all this and really need some help with some suggestions on what size of rims and tires to get, i bought a b5 passat wagon and want some nice stance with a little bit of poke, any suggestions?
  5. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    09-18-2012 06:20 PM #110
    Quote Originally Posted by gard15 View Post
    Sorry, not what this thread is for.
    Best bet is to check out the 5x112 classifieds, and the threads here for some examples and then report back with a set you like and we'll go from there.
  6. 09-19-2012 08:37 PM #111
    Hey guys I just got new wheels 18x7.5 et51 all the way around. I have a b5 1.8t with stock suspension and unrolled fenders. They came with 235/45 on them but I would like them to be flush all the way around and when I lower the car just be able to stretch some 195 on them. Need spacer and lug size recommendations, would love to get it all before h20
  7. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    09-19-2012 09:34 PM #112
    Quote Originally Posted by Mygfcabby95 View Post
    All the info you need is in this thread... please read the first post and then compare your wheels with someones who's specs leave the wheels where you want them. Space accordingly.
  8. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    09-28-2012 11:48 AM #113
    Hey I'm looking into buying a staggered set of rims Wth the fronts being 20x8.5 et 25 and rears being 20x10 et 30. I'm on stock suspension and was wondering how to make these work? Thanks.
  9. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    09-28-2012 12:01 PM #114
    Lower the car first. It will look ridiculous with 20" wheels and stock height. 20's are going to be really hard to pull off at all....
    But, you'll still poke out the rear by 8mm with at ET 30 on the rear. And you might rub on the inside too. Fronts are fine.
  10. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    09-28-2012 12:14 PM #115
    So rolling the fenders would be a good idea? Any suggestions on lowering kits? Thanks
  11. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    09-28-2012 12:19 PM #116
    If you are set on those: stretched tires, rolled fenders, and a stiff rear setup is needed. That means a good fully adjustable (dampening and height) coilover.
  12. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    09-28-2012 12:55 PM #117
    Alright, thanks for all of your help, much appreciated.
  13. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    09-28-2012 05:26 PM #118
    Sorry, one last question, what size of tires do I need if I plan on stretching them onto that setup?
  14. Member passatv6AF's Avatar
    Nov 4th, 2011
    Chicago
    09-30-2012 09:40 PM #119
    5 spoke rims from the b6 passat
    They're 17x7.5 with 47ET
    235/45/17
    Lowered 1.5-2inches
    Will they be inside too much?
  15. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    10-01-2012 08:35 AM #120
    They should be fine as is - but you might want a spacer to flush them out - 20-30mm on the front, even more on the rear.
  16. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    10-05-2012 10:45 AM #121
  17. Semi-n00b
    Sep 18th, 2012
    Ontario, Canada
    99 B5 Passat Wagon
    10-07-2012 07:11 PM #122
    Did you have to roll your fenders to fit that aggressive of a setup?
  18. 10-08-2012 11:18 AM #123
    ST Coilovers with modified upper perches
    rolled front fenders
    pulled rear fenders 5mm
    -3* rear camber
    fifteen52 348 tarmac classics
    19x8.5 et25 on 215-35-19 falken 452
    19x9.5 et19 on 235-35-19 falken 452
    elitistchicks
    Quote Originally Posted by ajd187 View Post
    Buncha queers in this thread.
  19. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    2004 GLX V6 Passat (Daily) 2002 Jetta GLX VR6 1973 Triumph TR6(Project/FS/Dust collector)
    11-10-2012 03:40 PM #124
    I need help with fitment guys!!! I dont know what to do. I have a 2004 passat sedan lowered on Eibach sport springs. I have 18x8 et44 BBS CK's. I have 5mm and 15mm spacers. I test fit the wheels on with a scrap 235/55 18 with both the 15mm and the 5mm in the front. Both seem to poke out a good bit. Heres where I am lost, With it lowered and these big of wheels, they look like they are gonna scrap the fender bigtime even if I go over a small speedbump or something. I am thinking my wheels are just too big for the car, but then I see guys running 19's on passats. So how the @#$@ do you do it without scraping the tire on the car?!?!
    Thanks!
    2004 BMP Passat 2.8L 30V V6 5 spd. M/T
    I love cars, it's not just a car to me. Its a passion, something that people far and few between can understand and relate with me.
    (that's how I pick my friends)
  20. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-10-2012 04:18 PM #125
    Quote Originally Posted by dublax44 View Post
    Thanks!
    235/55 is WAY too much sidewall.... I'd run a 215/35 or similar.... that's the problem....
  21. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-10-2012 04:22 PM #126
    Quote Originally Posted by E CODE View Post
    Thats what I plan to run on them actually 215/35 18's. Do you know the measure of difference between sidewalls? Wouldn't running a smaller tire still be prone to rubbing or scrapping?
  22. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-10-2012 04:30 PM #127
    Here is what it looks like with the 15mm spacers in the front. The guy I bought the spacers from said they were 10mm but they seem to be 15mm after I measured them.
    [IMG][/IMG]
  23. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-10-2012 06:45 PM #128
    What are you using spaces? Bolt them on without first. If you don't clear the suspension, THEN worry about spacing.
    My 8.5" ET 25 wheels were pretty much flush. If you bolt an 8" ET 44 wheel on, you'll be 25mm inside the fender. If you need to clear a little, you can add a spacer.
    Can you confirm that they are ET 44? With a 15mm spacer, you should be at ET 29, which should still put you inside the fender.... something isn't adding up.
    Check the wheel for all their markings and report back.
  24. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-10-2012 07:00 PM #129
    Yes et is 44. Its stamped on the wheel. I tried it without any spacers and it just hit the control arm. I tried the 5mm then and it seems a little tight still. They seemed flush without any spacers... and the 5mmwhole even had a little poke. I'm lost. I don't know what is wrong or what's going on.
  25. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-10-2012 11:33 PM #130
    Try measuring the offset manually to be sure.
    Sure they are 8" wide?
  26. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-11-2012 09:09 AM #131
    Yea its 8" wide. How do you measure manually?
  27. 11-11-2012 12:27 PM #132
    lay the wheel on it's face (on cardboard or something that won't scratch the face)
    take a straight edge and lay it across the entire wheel/tire
    measure from the ground to the straight edge
    that is your total wheel width (8" wheel will measure around 9") A
    then, measure from the back of the hub to that same straight edge B
    B - (A/2) = your wheel offset
    elitistchicks
  28. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-11-2012 05:08 PM #133
    Quote Originally Posted by Heathcliff Huxtable View Post
    Bingo. I have a hunch they won't be 44....
  29. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-11-2012 06:55 PM #134
    Do you want me to get a pic of the stamping? Im just going by what the wheel is saying I cant thank you guys enough for the help though! I really want to run these!!
  30. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-12-2012 08:27 AM #135
    Sure.
    Can you try mounting one without a wheel to the front, with the 5 mm spacer and take profile shots?
    I want to see what it looks like without a tire...
  31. Member NadaGTI's Avatar
    Feb 26th, 2012
    Salem, Virginia
    B5.5 Wagon 1.8T, 80 Caddy Bio Diesel
    11-12-2012 09:46 AM #136
    NUE's-
    19x8.5
    et45
    AG M310-
    18x8.5
    et45
    ECODE already hooked me up on the SNA's
    Im not good at offset so, will those 2 fit? tire size?
    Quote Originally Posted by curvedinfinity View Post
    Brilliant student enters car roof sledding contest, wins darwin award
    Looking to buy interior Caddy parts. LMK what you have.
  32. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-12-2012 10:17 AM #137
    My 8.5's were ET 25 and fit perfect. Had 215/35's on them. Pics are in the first page of this thread.
  33. Member NadaGTI's Avatar
    Feb 26th, 2012
    Salem, Virginia
    11-12-2012 10:47 AM #138
    So with 215/35's 8.5's will fit, or will I need spacers?
  34. Member E CODE's Avatar
    Feb 1st, 2005
    Toronto, Ontario
    11-12-2012 10:55 AM #139
    If you wanted my exact fitment - you'd need 20mm spacers on the front. I think you might run into rubbing the suspension without. It would be close.
  35. Member dublax44's Avatar
    Jul 30th, 2011
    Lancaster, PA
    11-12-2012 12:21 PM #140
    Sure.
    Sure thing I can get some pics tomorrow!
