Originally Posted by
L33t A2
just keep in mind if you decide to run a 16v head you have to mill or otherwise clearance valve reliefs into the 8v piston tops and swap over the correct timing gears as the 16v has a wider belt and the accessory pulleys will then be offset as well, you also get stuck choosing your distributor location
if you're going to keep it simple, then any 8v head will bolt right on: mk1-early mk2 solid lifter, mk2 hydro lifter, mk3 aba (all 8v heads newer than CIS-basic can have the injector bungs swapped out to run electronic fuel injection (Digi2, G60 Digi1, Mk3 Motronic OBD1/2, any standalone system like megasquirt, dta p8pro, autronic, sds, 034 Ic)
yes you can run a turbo on a counterflow head, I'm in the middle of doing that right now, you just have some tight clearances back there. aba will have more space to run bigger/better turbos and manifolds as well as less heat soak of the intake manifold
