We opened a restaurant/lounge/concession stand out at our practice facility. We've got a concession stand with popcorn, drinks, candy, etc as well as a sit down restaurant with full menu and a lounge. We have 2 tills in the concession stand that connect back to a server than runs a MySQL database. The tills are the same kind as you'd see in a gas station, touch screen, a handful of USB, RJ11/45 and serial ports. They're made by radiant systems. The cash drawer is kicked out via the RJ11. It's got an integrated 3 track card reader. The tills in the restaurant/lounge are the same ones. We use the same ones at our main location for our 50/50 system and for the merch booths. They're really solid, spill resistant, and reliable. We've got probably 40 of them total between all spots and in the 3 years we've had them, I've had 1 power supply die and 1 hard drive die. They all run XP embedded. We're using the Epson TM88 series printers, which are pretty much the industry standard.
http://www.radiantsystems.com/indust...lity/index.htm
They're the ones we use for both the software and hardware side for food, and hardware only for merch and 50/50. We use the quick service for concessions and table service for the restaurant/lounge.
You need a box on the back end that will handle the DB, and they can all run off the same network. When we put it in, the table service/quick service DB's were able to run on full SQL, but only on a 32bit version of windows. I suspect they've changed that. To each till, you will need network and power. If you go integrated debit/credit, you need a single line, if you go with stand along credit/debit, you need a second RJ45 or RJ11. Keep in mind with credit and debit you need to have a PCI compliance plan in place as well.
This is who we use, there's a hundred other guys who do the exact same thing software wise, for hardware, there's not that many makers.
I went all over the place with that info, if I missed something or you want to know more, let me know.
, its the software that has me worried. The 2 are usually fine on their own, but when you try and mix complex system with complex software, there can be problems. I can just imagine now the software only playing nice with certain hardware. But alas, I figured I would ask here anyway, maybe someone has some experience with it.
