Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 116
Thread: Is 20PSI on K04 equal to 20PSI on GT28? i think no my friend thinks yes
  1. Member BlackA4stage3's Avatar
    Feb 1st, 2010
    GA
    2003 Audi A4 Avant 1.8T GT28
    05-09-2012 07:05 PM #1
    ok so here is what happened. a few days a ago i saw another B6 A4 guy drive by me so i followed
    him and he pulled over and we talked about our cars for a little. he said that he had a K04 setup
    running 20PSI of boost. so blah blah blah later that day im talking to my friend about his car and i
    tell him yea he is running a K04 at 20PSI. so he says "so its basically as fast as your car". i drive a
    B6 A4 with a GT28 running 20PSI boost. so i say no my car would be faster because it is bigger
    running the same PSI. so he says 20PSI is 20PSI. we argued for a good 30 minutes and couldnt
    come to a conclusion. i figured since its 20PSI in a bigger turbo it would be moving more air. Can
    someone tell me if im an idiot or right or what????? ive searched google and couldnt find a clear
    explanation. please help!!!
  2. Member SVTDanny's Avatar
    Aug 7th, 2005
    Winchester, VA
    2010 GT500
    05-09-2012 07:06 PM #2
    Bigger turbo will almost always give more power at the same boost. Bigger turbos flow more air, more efficiently.
  3. Member ThreadBomber's Avatar
    Feb 4th, 2007
    Vancouver
    2011 GTI 2dr 6M
    05-09-2012 07:07 PM #3
    You should have just whipped your cacks out and the question would have been answered
    Teefy Buna
    Quote Originally Posted by Sump View Post
    I'm sure a lot of these guys went home after the carwash and played a little hans solo.
  4. Member stascom's Avatar
    Sep 12th, 2009
    So. Oregon
    a Nissan
    05-09-2012 07:09 PM #4
    More air would flow at the same pressure through a bigger outlet... Why is this so difficult?
    Quote Originally Posted by ThreadBomber View Post
    This.
  5. Member rsj0714's Avatar
    Dec 3rd, 2006
    Greensboro, NC
    2003 Nissan Maxima 3.5 6-Speed. 2001 GMC Sierra (RIP)
    05-09-2012 07:10 PM #5
    Quote Originally Posted by BlackA4stage3 View Post
    Can someone tell me if im an idiot or right or what????? :
    Possibly all of the above.
    Larger turbos have more capacity, it's pretty simple. If you own a turbo vehicle you should atleast understand the basics of it's operation.
    Station wagons are for moms and Europe.
    Sep 19th, 2000
    SLC
    crappy nissans for days...
    05-09-2012 07:11 PM #6
    Think of power as a function of air volume rather than boost pressure required to supply that volume.
    20 PSI pumped through a straw will not flow the same volume of air as 20 PSI pumped through a garden hose... unless you've got a REALLY big straw.
  7. Member Shomegrown's Avatar
    Feb 26th, 2002
    Detroit
    Current: Audi S4, BMW M5, Audi A3 quattro, Dodge Dakota 4x4
    05-09-2012 07:17 PM #7
    This is going to be one of those TCL threads where it's best to look the other way and pretend you were never here.
  8. Senior Member Fritz27's Avatar
    Mar 8th, 2003
    Gulf Coast, FL
    05-09-2012 07:25 PM #8
    Quote Originally Posted by Shomegrown View Post
    Yeah, I agree.
    PSN: PhilipGTI
    Get lost santa
  9. Member 200HP4dr's Avatar
    Nov 21st, 2001
    NE. OH
    05-09-2012 07:25 PM #9
    Quote Originally Posted by nmap View Post
    This. There are also other factors to consider, like the straw size, not only the ins and outs of the turbo, but the size of the intercooler piping, intercooler etc. The larger that piping is (assuming the bends are equal) the more air can get through at any given PSI. So, yeah, the post I quoted....
    Chris
    | 2012 Nissan Leaf | 1995 Jeep Wrangler |
    | 2007 Toyota Prius | 1999 Plymouth Voyager |
    Jan 23rd, 2011
    N. IL
    01 Suburban 8.1L 92 Cummins 94 Beige Accord
    05-09-2012 07:26 PM #10
    Learn how to read turbo maps and answer your own question.
  11. Member Spiller337's Avatar
    Nov 26th, 2009
    LI NY
    1997 jazz blue wookie rustbox, XJ Cherokee 4.0
    05-09-2012 07:33 PM #11
    With his logic, what would be the point of upgrading a turbo then?
    Quote Originally Posted by Ernie McCracken View Post
    Something something haters something YOLO, etc.
    My work in progress! 1997 Jazz Blue GTI
    Misc. MK3 parts for sale!
    Jun 15th, 2010
    Northeast
    08 335i
    05-09-2012 07:35 PM #12
    You need to get smarter friends.
  13. 05-09-2012 07:47 PM #13
    Pressure and volume are 2 different things...
  14. Member taymk2's Avatar
    Oct 21st, 2001
    Middleburg Va
    95 cabrio 08 jetta 01 mb 320 12 yukon xl
    05-09-2012 07:48 PM #14
    Quote Originally Posted by unintended acceleration View Post
    Lol
  15. Member Shomegrown's Avatar
    Feb 26th, 2002
    Detroit
    05-09-2012 07:51 PM #15
    OK, the answers here are mostly right, but for the mostly wrong reasons!
    To understand, you need to look at the basics - what is boost?
    Positive boost pressure occurs because there is more air being forced through the engine than the engine can ingest using its own volumetric efficiency.
    Changing to a larger turbo does not have a significant impact on VE or the volume of your intake system, nor is it the most restrictive part of the intake (that's the throttle) so the "blowing through a straw" analogy is way off base. It doesn't apply at all.
    The reason larger turbos usually make more power for the same relative boost level is twofold:
    1.) Compressor wheel efficiency leading to lower IAT
    2.) Lower TIP (turbine inlet pressure or less exhaust restriction)
    What this means is if the IAT is the same and the exhaust backpressure is the same, then 20 psi on turbo X will absolutely equal 20 psi on turbo Y even if the turbos are sized differently.
    Now, both factors 1 and 2 can be controlled outside of turbo size. Let's pretend...
    Car # 1 has the smaller K04 but open dump pipes and a huge FMIC with meth injection
    Car # 2 has the larger GT28 but smaller intercooler and a quiet exhaust with cats
    Under those conditions, it would be possible that the Car #1 performs better at 20 psi than Car #2.
    Long story short, boost pressure is restriction in the engine, not the turbo. So 20 psi = 20 psi unless other properties are changed (VE, IAT, TIP, etc).
    So who's not going to read the thread and be the next to post the straw/garden hose analogy?
  16. Semi-n00b
    Apr 27th, 2012
    Sacramento, Ca
    2012 GTI, 2010 Outback
    05-09-2012 07:54 PM #16
    The bigger turbo is capable of pumping more air at higher pressure than a smaller turbo. If the engine management is actuating the waste gate of both a bigger turbo and smaller turbo to keep the pressure in the intake manifold the same for the same throttle position and engine speed, then the power output of the engine will be the same despite the turbo size. The bigger turbo simply has more potential that is being wasted. In fact, the bigger turbo may be worse due to slightly higher turbo lag.
    If you take the smaller turbo and push it near the edge of it's design limits, the charge temperature will probably be higher, reducing engine performance. This situation is probably not terribly likely with a stock setup. In a car that's running higher boost pressure than designed, it can happen.
    It's likely a smaller turbo will hit the limit of it's air flow capability if it's too small, causing a drop in intake manifold pressure at higher engine speeds. So, in this case the bigger turbo is better. It's also not running at the same "PSI." The air flow is not high enough to maintain the pressure.
    If one of the setups is faster, it's probably because the slower car had a turbo that couldn't maintain intake manifold pressure when the engine gets closer to red line.
  17. Member Shomegrown's Avatar
    Feb 26th, 2002
    Detroit
    05-09-2012 07:56 PM #17
    Quote Originally Posted by Brad2021hk View Post
    Correct, but only if you assume intake air temps and engine volumetric efficiency is the same between both setups.
  18. Member abawp's Avatar
    Nov 30th, 2005
    Newport News
    2002 Subaru Outback, 2003 Miata, 2006 EX500R, 2011 ZX-6R
    05-09-2012 07:59 PM #18
    I'll just sit back and wait until someone tries to "correct" you
    Quote Originally Posted by Lwize View Post
    What, none of you watch reruns on TV?
    Quote Originally Posted by NPH View Post
    I don't know about you but, I get angry and shout "IB4TL" when one comes on.
  19. Senior Member JettaGT8V80's Avatar
    Jun 11th, 2003
    Waltham , Ma
    06 GTI UM Tuned
    05-09-2012 07:59 PM #19
    no
  20. Member BlackA4stage3's Avatar
    Feb 1st, 2010
    GA
    05-09-2012 08:04 PM #20
    thanks for the comments guys. i always thought i was right but he made me second guess myself causing this thread lol. i will be sending him a link to this thread so say hi to him. his name is rusty and he drives a g35 coupe fully bolted
  21. Member 302W's Avatar
    Jul 24th, 2004
    NoVA
    05-09-2012 08:07 PM #21
    Is the reason that IAT is lower with a larger turbo at the same PSI due to less air turbulence with a bigger inlet?
    1988 is not an 80's car, it's an early 90s car but whatever.
  22. Member VWturbonium's Avatar
    Jul 14th, 2003
    Venice, FL
    1997 BMW 740iL, 2013 MS3
    05-09-2012 08:24 PM #22
    Basically to expand upon what Shomegrown said, two differently sized turbos (lets assume similar compressor and turbine designs just different sizes) *can* make the same power at the same boost, it is IN SPITE of the size difference. The bigger compressor will generate less heat for a given pressure, and arguably even more important is the fact that the bigger turbine side will have a lower Exhaust or Turbine pressure ratio (lower ratio=better Volumetric Efficiency).
    On otherwise identical physical setups, even if you work to get IAT's on the smaller turbo down the bigger turbo will more power because of the hot-side still allowing greater VE.
  23. Member konigwheels's Avatar
    Nov 12th, 2002
    OP WA
    1982 MB 500SE AMG, 2000 Ford Focus ZX3, 1989 Lincoln Town Car, Yamaha R6
    05-09-2012 08:31 PM #23
    There's the problem. G35 with bolt ons, he should know the VQ doesnt do anything with simple mods. I'm totally assuming and kind of being an ass, but he probably got 10whp for $2000.
  24. Member BlackA4stage3's Avatar
    Feb 1st, 2010
    GA
    05-09-2012 08:55 PM #24
    Quote Originally Posted by konigwheels View Post
    he beats my avant with a gt28. he has put a lot of money in it but it looks great and sounds great and handles very well, so id say money well spent. plus NA means no turbo heart ache like us audi guys have sometime lol
  25. 05-09-2012 09:02 PM #25
    Yes, more capacity, but the same amount of air flowing through two different size tubes (turbos) will produce different pressures. Less flow through a smaller opening will produce more flow through a larger opening.
    The equation escapes me at the moment, I have not had physics for over 20 years. But this is straightforward physics. Your statement is suspect.
    Quote Originally Posted by rsj0714 View Post
  26. Member DIAF's Avatar
    Sep 17th, 2005
    2007 GS 350 AWD
    05-09-2012 09:05 PM #26
    Said simply:
    A bigger turbo will have cooler, denser air (read:more oxygen) at a given PSI than a smaller turbo, all things being equal.
    More oxygen means more bang bang.
    More bang bang means more zoom zoom.
  27. Member silverA4quattro's Avatar
    Jun 21st, 2004
    Conshohocken, PA
    '10 Jetta TDI, 02 Golf 2.slow
    05-09-2012 09:05 PM #27
    Did you cup his balls?
  28. Member BlackA4stage3's Avatar
    Feb 1st, 2010
    GA
    05-09-2012 09:08 PM #28
    Quote Originally Posted by silverA4quattro View Post
    yes. i was on my way to class and saw the only other modded audi in statesboro GA so i had to creep. ended up skipping class. thats Audi dedication
  29. Member
    Jan 17th, 2012
    Croydon, PA
    2011 Jetta S 2.0
    05-09-2012 09:11 PM #29
    You will just build your 20psi faster and reach peak hp quicker thats all 20psi is the same whether it be a small or large turbo. your just pushing more air to build 20 psi before the smaller turbo, its a pretty simple answer...
  30. 05-09-2012 09:16 PM #30
    I thought a turbo forced an exhausted mixture which has very little O2? Most would have been exhausted in the initial cylinder detonation. I wonder if the difference in exhausted gases would even be a factor? I thought the pressurized exhaust from the turbo provides the energy, not the O2?
    Quote Originally Posted by DIAF View Post
    Said simply:
  31. Member DIAF's Avatar
    Sep 17th, 2005
    2007 GS 350 AWD
    05-09-2012 09:19 PM #31
    Quote Originally Posted by LhW View Post
    No, the exhaust spins the hot side and then continues out the tailpipe.
    On the other side of a nice bearing is the cool side, which pulls air in through the intake.
    Intake air is not exhaust air. You are thinking of DEI.
    :lol:
  32. 05-09-2012 09:23 PM #32
    Ahhh - I got it. The illustration is classic!
    So, 02 does play a factor. News to me. Thanks for the info.
    :lol:
  33. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    2008.5 GTI w/TSI motor, 1995 GTI Vr6
    05-09-2012 09:25 PM #33
    PSI = a measure of resistance, so "boost" does not equal horsepower. What you want is CFM. That's a measurement of flow, and all a motor is, is an air pump. The more you can push through it, the more HP you can make.
    A small turbo can reach 20psi, yes, and a large turbo can also reach 20psi. Difference is that with a larger housing, you can flow more cubic feet of air per minute than a smaller housing. Think of it this way: 20Psi of air through a 3ft diameter pipe flows more air than 20Psi of air through a 1/4" pipe
    Anyone that tells you 20 psi = 20 psi has no clue what they are talking about
    Check out my Garage build thread - 08.5 GTI 2.0T TSI, APR stage2, APR intercooler, 42DD 3" Catless Downpipe, Autotech 3" Exhaust, Full Carbonio intake, AWE DV relocation, BSH Motormounts, Labonte S4 Meth injection, Dieselgeek Shortshifter, Southbend Stage2 Endurance clutch, Forge Shift knob, Newsouth boost gauge, Euro LED tails, Koni Coilovers, Miro STP3 19x8.5 rims, General Exclaim 225/35/19 Tires
  34. Member DIAF's Avatar
    Sep 17th, 2005
    2007 GS 350 AWD
    05-09-2012 09:26 PM #34
    There are three things that matter in motor - fuel, air, and spark (hidden fourth would be timing).
    If you add more of the three proportionally, you get more power.
  35. Member mariok2006's Avatar
    Jul 18th, 2006
    Tampa, FL
    S2000 v3
    05-09-2012 09:33 PM #35
    wait for it...
    Quote Originally Posted by Slayer View Post
    ...and there it is.
    135
    246 R
