Results 1 to 21 of 21
Thread: Cabrio stalled. Burnt electrical smell.
  1. 05-09-2012 09:13 PM #1
    My daughters 02 cabrio stalled on her and doesn't even turn over at all now. There is a burnt electical smell under the hood which appears to be near the battery. Anyone have any suggestions as to what may be wrong. Thanks for any help.
    Sent from my LG-LS670 using Tapatalk 2
  2. Member fredges's Avatar
    Apr 27th, 2012
    Seattle...ish, WA
    1987 VW Cabriolet - (Stock, Auto)
    05-09-2012 10:24 PM #2
    Was there anything acting up before it happened? Can you take a photo of the engine bay? Is there any aftermarket stereo wiring in there?
  3. 05-09-2012 11:34 PM #3
    I did scan the engine codes with VCDS Lite. There was a code P1570 - Engine Start
    Blocked by Immobilizer. The immobilizer module didn't respond when I tried to test it. I don't think it ever did though. The power locks stopped working a couple months ago. The stereo is factory. I'll try to get a picture tomorrow. Thanks.
    Edit: After more research I see that the immobizer could possibly be part of the instrument cluster module. I think that didn't respond also. I'll have to double check tomorrow.
  4. Member
    Jun 15th, 2011
    North Carolina
    05 Passat Wagon, 1988 Cabriolet
    05-10-2012 07:07 AM #4
    Check the wires at the starter.
    Also ignition switches are great about causing a "no crank" issue.
    Immobilizer will let the car start, then shut it right back off.
    Working hard to show everyone that not all dealer mechanics are crooks. Most of us really care about our customers and their cars. You can read all about it on the car blog
    Any thoughts I post are my own. I am not speculating on any repair VWoA is making, has made, or will make.
  5. 05-10-2012 12:25 PM #5
    I just had it towed to be looked at. Thanks for the help. I'll post back when I find out what the problem is/was.
  6. 05-11-2012 11:14 AM #6
    It was the starter. It was just replaced 6 months ago because the bendix gear wouldn't engage. Can't believe a starter dying caused the car to stall also. Thanks for the help.
    Jun 15th, 2011
    North Carolina
    05-11-2012 11:16 AM #7
    Quote Originally Posted by foltz61 View Post
    Glad you got it fixed. Did they warranty the part?
  8. 05-11-2012 11:33 AM #8
    My daughters boyfriend put the last one in. I can't believe how much they charged to replace it. Astronomical.
  9. Member aoj2108's Avatar
    Sep 12th, 2003
    Newark, NJ & Vieques, Puerto Rico
    '00 Golf Cabriolet & '11 JSW 2.5
    05-11-2012 11:55 PM #9
    *NOTE I've found that when you scan a car with an immobilizer and do not turn the key to the on position before it scans, you will get code P1570 every time.
  10. 05-12-2012 01:22 PM #10
    Thanks.
  11. 05-20-2012 12:16 PM #11
    POS died on her again. I have 2 vw's. They both basically fell apart shortly after the warranty ended. They will be my last vw's. Just ranting. I know that it's 10 years old now but, still.........
    Jun 15th, 2011
    North Carolina
    05-20-2012 10:27 PM #12
    That stinks. What happen to her?
  13. 05-21-2012 10:09 AM #13
    She said the guages all went crazy. She smelled an alcohol smell. She pulled over and turned it off. It wouldn't turn over when she tried to start it again. I guess there's a short in it somewhere.
  14. 05-21-2012 07:31 PM #14
    It's the starter again.
  15. Member 1956dub's Avatar
    Jun 12th, 2010
    Castle Rock, WA
    I own the SLC parking experience
    05-25-2012 02:14 PM #15
    Something seems amiss here, starters don't usually just "die" unless there is something else wrong with the car causeing the starter to labour while starting the engine.
    Did you get it fixed yet? It definately sounds electrical, but maybe that is killing the starter. Replacing the starter gets it going again, but probably is masking the root problem.
    Quote Originally Posted by Rento_VW View Post
    Needs a real Zender wing.... lower it.
  16. Member
    Jun 15th, 2011
    North Carolina
    05-25-2012 09:45 PM #16
    Quote Originally Posted by 1956dub View Post
    That is kinda where I was going too!
  17. 05-26-2012 10:45 AM #17
    They replaced it under warranty. I'm thinking what you guys are thinking. Just waiting to see if it happens again. I hope it was just a fluke. I know it's probably not though.
  18. Member BigFatDog's Avatar
    Apr 23rd, 2003
    Texas - 713
    2002 Cabrio GLX, 1969 Type 1 Baja
    05-30-2012 08:29 AM #18
    Have a look at the ignition switch. Make sure it is disengaging after being turned to "start."
    A local dealer went through a few starters when my car was under manufacturer's warranty. The problem wasn't the starter it was the ignition switch.
  19. Member iamdagerman's Avatar
    Feb 18th, 2006
    ga
    1 70 bug, 2 71 supers,89 Cabby, 72 Ghia (FS)
    05-30-2012 10:27 AM #19
    Does it have the fuse box on top of battery?
  20. 05-30-2012 02:16 PM #20
    Quote Originally Posted by iamdagerman View Post
    No
  21. 05-30-2012 02:17 PM #21
    Quote Originally Posted by BigFatDog View Post
    Will do. Thanks
