you may have a bad ignition coil. They need to be removed to get to each spark plug. best case one not seated or connection issue...
you need a vagcom to check the fault codes. but it might be time for new ignition coils.
did you get a blinking check engine light while the "fun stuff" was going on?
sorry, no idea where to go in Vegas, but im sure someone here will know..
