Results 1 to 3 of 3
Thread: not another mk2 vr6 question??
  1. Member iWantaTurbo's Avatar
    Aug 5th, 2001
    columbus ohio
    90 gti vr6; 94 passat vr6; 08 gti autobahn
    05-09-2012 09:33 PM #1
    I'm using a mk3 front cradle with mk3 2litre control arms. The issue is that the control arm mount holes are larger than the bolts that mount to the frame. The previous owner had some JANK shems jammed in the bushings to tighten them up.
    What's the best solution? Drill out the mk2 rail to take the mk3 bolts, OR, score some mk2 control arm bushings and hope they fit the mk3 control arms?
    thanks!
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    05-09-2012 10:08 PM #2
    what?
  3. Member Scrubbs's Avatar
    Mar 13th, 2006
    GB Maryland
    Mk2,s Mk3's
    05-29-2012 02:41 AM #3
    What bushings were used in the control arms? A2 bushings use a thin sleeve to space the bushing to the bolt. Possible mix up? Correct bolts on the k frame to body?
