Results 1 to 10 of 10
Thread: no sway bar
    Oct 21st, 2010
    NJ
    05-09-2012 10:31 PM #1
    Is there anything that i can do since i have my front sway bar removed. It feels like the car is swaying alot especially when i go over train tracks or smoother roads. Also sometimes when i hit a bump it feels like my rear moves ( kinda like jumps from side to side). D
    Dont Know if this can be from not getting an alignment or the sway bar.
  2. Senior Member 98DUB's Avatar
    Feb 21st, 2003
    Lowlife, WA
    MKIII VR6
    05-09-2012 10:32 PM #2
    put it back in? dont know what platform you have but on MK6's it doesnt hold you up if done right
  3. Member Seppdelaney's Avatar
    Apr 11th, 2011
    West Chester, PA
    2010 VW Jetta Wolfsburg Edition and a 2009 VW Tiguan 4 Motion SE
    05-09-2012 10:44 PM #3
    Dorbritz brackets...
    ///KCH2O ”VDUBkill 2:0 – The path of 2.0T is beset on all sides by the injustice of the speedtrap and the Plague of the Prius drivers. But blessed is he who in the name of disparity overwhelmeth the exotic in the valley of the s-bends. And I shall strike down upon thee with great revs and furious acceleration those who attempt to obstruct or delay my overtaking and you will know my engine is turbocharged when I lay my powerband upon thee.”
  4. Member Rat4Life's Avatar
    Oct 13th, 2004
    Fair Lawn, NJ
    lada 2101,rx7,bmw 318i,87 golf gt,93 1.8t two tone,01 flat blue mk4,02 gti 1.8t. 1JZ e21 in works
    05-09-2012 11:45 PM #4
    Quote Originally Posted by apoleski View Post
    this would def help
    http://bagriders.com/modlab/products...-BRACKETS.html
    http://www.ksportusa.com/b2c/proddetail.php?prod=AE0001
    and after that alignment.
    Complete air ride installs,frame notching,welding, in north jersey.
    http://www.flickr.com/photos/rat4life/
    roll cages,race rally preps in upstate new york http://www.rktmotors.com/Gallery.html
    follow me on instagram RAT4LIFE
  5. Member choey's Avatar
    Feb 10th, 2007
    All over Eastern PA
    Bagged GTI
    05-10-2012 03:09 AM #5
    Just had my sway bar reattached in my mk6 feels tighter now just need the alignment
    @gtijoey
  6. Member Miguel Lopez Ma's Avatar
    Mar 12th, 2007
    Valencia-Spain
    VW Golf´03
    05-10-2012 11:42 AM #6
    car?
    : Confused:
  7. Member MoWsE's Avatar
    May 14th, 2007
    Aiea, Hawaii
    Current: 2008 MKV .:R32 Old: 2000 B5 Passat
    05-10-2012 05:19 PM #7
    I don't think these things are due to you having the front sway removed... I was told it was from being lower than stock height (don't know how that's prevelant honestly)... But once I got my alignement redone they mostly went away...
    As for getting the front sway back in, dorbitz brackets and adjustable endlinks will allow you to run it and still lay frame if you wish...
  8. 05-14-2012 12:56 PM #8
    You absolutely need an alignment!!!! You are running with too much toe out and this will cause the car to dart side to side over bumps (even small ones) causing the car to turn and thus roll.
    You will feel much more planted with proper front and rear geometry and your tires will thankyou for it..
    Brian@AirLift
    Engineer Dude
    http://airliftperformance.com/
  9. 05-14-2012 12:57 PM #9
    You will feel much more planted with proper front and rear geometry and your tires will thank you for it..
    Brian@AirLift
    Engineer Dude
  10. Member hussdog426's Avatar
    Nov 20th, 2011
    North Jersey
    Bagged 2012 Golf TDI
    05-14-2012 02:58 PM #10
    The sway bar doesn't have much to do with it, you need the alignment so you aren't all over the road
    2012 Bagged United Gray Golf TDI OEM+
    follow me on instagram: @hussdog426
