Results 1 to 19 of 19
Thread: SAI delete??
  1. 05-09-2012 10:52 PM #1
    Ok, I performed a search on the subject and found a few posts regarding deleting the SAI. Unfortunately none are specific to our R32. The closest, was a 2.8 VR6 DYI.
    What does it do? It is used to lower emissions especially during cold start up. Allow the Catalytic converters to warm up faster.
    Why delete?
    1. aesthetics, cleaner engine bay
    2. more room to work on engine
    3. less weight (avg. system including pump, hoses, and switches aprox. 7 lbs.)
    Issues?
    1. CEL
    2. not passing state inspections
    Has anyone any input?
    I was thinking of questioning Jeff at United Motorsports to see if he could override the fault(s)/readiness code.
    Has anyone done this on a NA motor?
    PSU, have you done this?
  2. Member AWhiteRabbit's Avatar
    Sep 30th, 2008
    Maryland
    MKV Rabbit
    05-09-2012 10:53 PM #2
    Quote Originally Posted by yellow bunny View Post
    PSU is no more
    PSU | perfect. | TTMAB | All in the Details
  3. Member AWPower's Avatar
    Apr 27th, 2005
    Somewhere
    VR6 Golf
    05-09-2012 10:55 PM #3
    I remember doing this on my 1.8t. Fairly simple you can buy diodes to bypass the CEL. Try searching in the 1.8t technical forum
  4. 05-09-2012 11:09 PM #4
    I read the 1.8T versionm the resistor at the air pump plug, according to the author, only prevents the CEL for a missing SAI pump missing. The delete will prompt a improper flow CEL, that the author didn't provide a remedy. The author still has 2 CEL faults due to the SAI improper flow, and PCV delete.
    Were you able to do so without faults??
  5. Member AWPower's Avatar
    Apr 27th, 2005
    Somewhere
    VR6 Golf
    05-09-2012 11:43 PM #5
    When I performed the the SAI delete, i used two resistors one for each wire if I remember correctly. I didnt not have any CEl on the dash, but im not sure if i had hidden CEL that didnt show up on the dash but did when you scanned it
  6. Member xbr80bx's Avatar
    Feb 2nd, 2007
    nineonezero
    Mk5 3.2 / Mk5 1.9
    05-10-2012 12:26 AM #6
    incorrect flow... classic VR6.
    insert cheap credibility statement here...
  7. 05-10-2012 09:25 AM #7
    So Josh, powerdubs replied and confirmed that Jeff from UM should be able to delete the faults. I am now awaiting to hear from Jeff to see if and when he could do this.
  8. 05-10-2012 09:37 AM #8
    Just red the "IE 24V SAI Block Off Plates In Stock and On Sale!" post on the MK4 R forum. I initially didn't read the whole thing, thinking it was only regarding the selling the block off plate. There is actual good information. Apparently some of the UM tunes already have the SAI disabled. I suppose I could test mine by unplugging and seeing if it throws any codes.
    Now I don't know if there is anything different or specific on the Mk5 R?
  9. Banner Advertiser JC@DouglasVW's Avatar
    Jun 24th, 2009
    Summit, NJ
    Billet 72'd 07 GTI, Billet 6265'd 08 R32, 2010 GMC Sierra
    05-10-2012 11:00 AM #9
    Just have UM flash the car and they can stop the CEL from coming on.
    I used an IE MK4 R32 SAI delete kit and then made my own block off for the passanger side combi valve to the head. I am working with pete at IE to make a plate for that too so expect them to offer complete kits in the near future.
    Before SAI delete
    After SAI delete
    Douglas VW
    Distributors for FFE Racing, GoAPR, CTSturbo, Integrated Engineering and HPA
    Innovative Motorsports + UM
  10. 05-10-2012 01:09 PM #10
    Quote Originally Posted by JC@DouglasVW View Post
    Before SAI delete
    After SAI delete
    Thanks for sharing! This is definitely on my list to do.
    Looks cleaner!
  11. 05-11-2012 03:28 PM #11
    Ordered my SAI block off plate today. Hopefully make this happen in a week or so.
  12. 05-14-2012 01:40 PM #12
    United confirmed that they would be able to sort out the CEL/ faults. Sweet!
    Also ordered gasket to remove combi valve from the other side of the head. I'm hoping that my friend will be able to make a block off plate. Can't wait to clean that stuff out!
  13. Banner Advertiser JC@DouglasVW's Avatar
    Jun 24th, 2009
    Summit, NJ
    05-14-2012 01:44 PM #13
    you just need to make something simple like this until IE releases a pretty one.
    Douglas VW
  14. 05-14-2012 04:55 PM #14
    Yuup, thanks! My friend has access to a cnc machine, so it may actually be a nice piece? We will see. Thanks again.
    Manny
  15. 06-26-2012 10:56 PM #15
    So, removed the SAI. I chose not to use the resistor in the plug, so CEL is on. I have an appointment with Jeff at UM coming soon to sort this out. Not much in weight savings, maybe 10-15lbs. Car runs smooth as always. Engine bay looks slightly less congested.
  16. Member
    Aug 8th, 2011
    PDX
    MKV R32
    06-27-2012 12:28 AM #16
    Any weight saved (especially from the front) is great!
    I'm interested in this as I am contemplating an HPA 20th and this subject came up here:
    http://forums.vwvortex.com/showthrea...highlight=20th
    HPA tells me there will be no codes / issues with passing emissions with their ECU tune for their kit, so apparently it must be tune-able-out-able.
  17. Member
    Apr 12th, 2011
    IOWA
    Mk5 R32 #108, 08' Mk5 Jetta
    12-25-2012 03:55 AM #17
    I am thinking about doing this. I have the UM tune does anyone know what it cost to get UM to remove the CEL? or is it free, and you just need to contact UM? I should probably just contact UM anyways lol
    Projekt German Auto Grüppe - German car entusiast club based in Iowa with members all over the Midwest
  18. Member
    Feb 15th, 2009
    FT Cambell, KY
    MK5 DBP R32 #442, 2013 MK6 CW Jetta
    12-25-2012 12:13 PM #18
    Its a separate option for the SAI Delete... I think I paid $50.00 additional to the ECU Tune.
  19. Member
    Apr 12th, 2011
    IOWA
    12-25-2012 11:19 PM #19
    Ok thanks
