VWVortex.com - Tiny's Cabby: Progress Thread
    Page 2 of 10 FirstFirst 123456 ... LastLast
    Results 26 to 50 of 227
    Thread: Tiny's Cabby: Progress Thread
    1. Junior Member EuroTrash_miT's Avatar
      Oct 29th, 2005
      Pomona, CA
      '85 2.0L Cabriolet, '88 16v Scirocco, '00 VR6 GTI
      07-16-2012 02:23 PM #26
      Quote Originally Posted by tinygiant View Post
      I usually dont approve of stickers on my cars, but this one is hot
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-16-2012 03:17 PM #27
      Quote Originally Posted by EuroTrash_miT View Post
      it was like 4 bux shipped on ebay
      http://www.ebay.com/itm/290701915827...#ht_823wt_1413
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-16-2012 03:22 PM #28
      had some issues today.
      yesterday on the way home from the beach it seemed like the clutch cable got loose.. We stopped for pizza with friends and I messed with it and got it readjusted.. but it was still sort of grindy into reverse.
      so this morning i went out and got it perfect.. drove up the road and back going between all the gears making sure they were all working great.. they were.
      then the wife and I decided to do some errands and i was having the same problem. I did tighten the set nut on the cable.. so it shouldn't be coming loose. All the parts are there, cable is only a couple months old, new attachment kit, grommet.. etc
      so I went home (in 4th gear) and finally seemed to get it re adjusted..
      drove around for a while and it goes great through the gears but doesnt like getting into reverse all that much.. still a little grindy..
      I can turn the car off and start in reverse and then clutch and shift out of it ..
      what sort of tolerance is there on the clutch cable? does it have to be like within a mm or something?
    4. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-17-2012 11:28 AM #29
      Bushing retainer replaced on clutch cable.
      also replaced the hoses on the advance off the distributor.. the hoses braiding was very frayed
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-18-2012 03:40 PM #30
      finished the rear emblems today and put them back on the car
    6. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-30-2012 06:52 PM #31
      was rummaging around in the basement and found some metal pieces that happen to have the same spacing as the side markers (that have been disconnected inside)
      figured i would replace the reflectors with them.. now i need to find something to put in them.. maybe some mini german flags or something
      i might not keep em either.. just got me thinking
      and i almost forgot.. my cabby has a new pet
    7. Junior Member EuroTrash_miT's Avatar
      Oct 29th, 2005
      Pomona, CA
      07-30-2012 07:06 PM #32
      Thats such a great idea
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-30-2012 07:13 PM #33
      new bearing, hub and cv axel tomorrow. should be able to drive it again tomorrow night!
    9. Member SB_GLI's Avatar
      Oct 17th, 2005
      Stevens Point, WI
      04.5 TR GLI, 10 Wolfsburg Tiguan, 03 Allroad
      07-30-2012 09:05 PM #34
      love the blood splatter, very unique.
    10. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-30-2012 09:16 PM #35
      eventually i want to get bright red carpet for the interior and this winter probably redo the seats..
      if its another snowless winter i'll have a lot of money and a lot of free time on my hands Scored a hefty snowplowing contract this year. i get paid wether it snows or not... so i'm praying for no snow this year.. complete opposite of last year
      i really wish i had a garage so i could work on the car in the winter.
    11. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      07-30-2012 09:17 PM #36
      im really torn on exterior color.. i keep going back and forth on it..
      i was just thinking it would be cool to keep the black hood and hatch and do the sides in white with red blood. would look pretty sweet i think.
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-01-2012 06:32 PM #37
      being as anal as i am, after installing the axel and bearing tuesday i wanted to double check everything.. I drove a bout 5 miles then made sure the lugs were still tight.. i noticed a tiny bit of a click when seeing if there was any wheel play.. i narrowed it down to the tierod end. its new so i figued it must not be in enough or something.. it wasnt enough to do anything so i left it be.
      today after work i decided to double check again and see if i can get that click in the play to go away.. all it was is the set nut for the tierod end was like a 1/4 turn from being tight.. so i viced the tireod and tightened the nut. now the wheel feels as tight as the rear wheels.. muahah
      ...now... do i keep fixing/replacing things.. or just keep driving it.
      I really want to get the a/c compressor out since its hoses are all cut and its not in use... and i would like to replace my alternator since its bearing is really loud.. sounds like i'm running a super charger in the car lol.
      also already have a new valve cover seal and cam baffle to install and a new oil pan and gasket.. we'll see how ambitious i get this weekend
    13. Member joser11's Avatar
      Aug 8th, 2010
      San Juan, PR
      2007 Audi A3 S-Line 2.0T; 1990 Volkswagen Cabriolet; 1967 Volkswagen Beetle
      08-01-2012 11:56 PM #38
    14. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-02-2012 12:10 AM #39
      i've thought about decals like those. .but i would think in a real zombie situation it wouldnt be on the car.
      the rat mascot now hangs from the rear view mirror by his tail. lol
    15. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-13-2012 03:02 PM #40
      Decided i would have some fun with the underside of the cabby hood today. Started with a degrease and a pressure washing.. then i dawn dish soaped it and pressure washed it again.
      sprayed it with a grey paint. then went to town with my airbrush only the 2nd time ever painting with it. I'm pretty happy with the results
      then i decided to paint part of the engine bay and bloody that up too!
    16. Member Sean A's Avatar
      Sep 8th, 2011
      Red Lion, PA
      87 Cabby, 01 Jetta 2.0
      08-13-2012 09:07 PM #41
      Love the originality in this. Bringing something completely different to the table.
    17. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-13-2012 10:42 PM #42
      thanks
      i generally have mondays and tuesdays off.. so when i'm not as adventurous mechanically i spend the time doing cosmetic things to the car
    18. Member
      Dec 1st, 2011
      Cleveland, OH
      '83 Cabby Wolfsburg "Nimbus"
      08-14-2012 12:47 PM #43
      I don't think you'll be pleased to learn that, though it took a while, your car finally made it over to the MK1 "Epic Fail" thread.
      DW
    19. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-14-2012 01:06 PM #44
      Eh. They can fail all they want . Its my car
      Sent from my VM670 using Tapatalk 2
    20. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-14-2012 01:23 PM #45
      Quote Originally Posted by Dragonwing View Post
      DW
      and i think its been there since i did the door cards P
    21. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-14-2012 02:18 PM #46
      i've never looked through the epic fail thread until now..
      my car has been there for a long time i guess.
      http://forums.vwvortex.com/showthrea...1#post76681658
    22. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-15-2012 02:25 PM #47
      I got some inspiration via the fail thread to do a better job on the bloody engine bay.. so i decided to do the bay black with red blood.. looks much much better..
      also painted the car flat olive green so its all the same color finally. its dangerous when i get the day off unexpectedly
      here are a bunch of pics!
      I plan on getting a black vinyl VW logo to overlay on the red dripping splat.. lol much better than the logo i butchered the other day when messing with the airbrush
    23. Member
      Mar 17th, 2012
      Rochester, NH
      1989 Cabriolet
      08-15-2012 07:29 PM #48
      took off the "flag holder" things i added last week and made up some custom reflectors. i had to drill two holes in the rear pannel since its almost all bondo lol. but i wanted the two holes next to the reflector so i could have the bolts there all the way around.
      I also found out today that the little trim piece on the handle comes out.. so i painted that up too
    24. 08-16-2012 10:24 AM #49
      Cool thread. I like your originality!
    25. 08-16-2012 12:24 PM #50
      Jeje good
