Results 1 to 20 of 20
Thread: APR TSI K04...issues...
  1. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 02:23 AM #1
    long story short...
    got car ghetto dyno'd...made crap #'s...
    got car re dyno'd with better/more readings...same crap #'s but with reasoning...
    the very knowledgeable and educated owner of the shop said i was running too lean, this being why i am not making peak power. could this be a software issue i am having? mind you without me saying a word on what im SUPPOSED to be making and him never hearing of APR or any VW tuners for that fact (hes a nissan/subi tuner) asked me if i should be making near 360 (APR states 366 on theri website).
    the red dotted line on the AFR graph shows the lean/rich...above is lean...below is rich
    any ideas on whats going on?
    NO CELs, no soft codes, no leaks
    quick mod list: (on 93 oct)
    APR K04
    APR software
    forge twintercooler
    forge twintake
    s3 intercooler
    BSH TB pip
    AWE outlet pipe
    42dd catless dp
    custom 3in catback
  2. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    05-10-2012 04:26 AM #2
    I dont see anything wrong with it. your making pretty good numbers there.. there are people out there making less and running richer. I mean, you could make more power if you had more fuel and boost, but its still good
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  3. Member NS01GTI's Avatar
    Jan 30th, 2005
    Canada eh
    2012 VW GLI K04
    05-10-2012 08:12 AM #3
    314whp... That's pretty much what most of the APR TSI K04s are putting down on Dynojets.
    If you're concerned things aren't running well, run some logs and post them up.
    http://www.goapr.com/support/datalogging.php
    2012 GLI DSG
    APR K04 - Carbonio intake - BB 3" Catted DP - APR FMIC - HPA SHS Coils
  4. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    2003 X5 3.0i 5SPD, 07 SV1Ks
    05-10-2012 08:25 AM #4
    THE ONLY thing i can think of, is get rid of your Forge twintake and use an intake which keeps the stock MAF and housing. APR tunes for this on their K04 tune, and it may be affecting the lean condition which MAY be keeping your numbers a bit lower.
    AWE/GIAC tune for their k04 kit with an intake which uses a different MAF housing, and Revo does too. Unitronic tunes for stock MAF housing as well as APR i believe. It's just my theory but something you may want to look into.
    I specifically remember Arin saying a while back that with the k04 they tuned it with MAF being stock as they run it with their Carbonio, and some people were having issues with intakes that relocated it.
    Numbers look good, but considering you have every bolt on imaginable I would hope you would be making in the 325whp range.
    How about valves, have they been cleaned?
    Quote Originally Posted by Senor Pelligro
    It's a car for a fashion forward, style conscious guy that's always looking for the season's hottest accessory. A guy that watches Project Runway, reads TMZ, and drinks Cosmos.
    It's simply fabulous, sweetie.
  5. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-10-2012 08:35 AM #5
    numbers seem legit
    If you are that worried run some logs before you start pointing fingers.
    :APR -stage 2 :BSH -Intake,Mounts,RSB,TB Pipe :Whiteline -A.L.K.,Endlinks
    :Devils Own -DVC-30+Direct Port Injection :BC Racing -BR Coilovers :Flik-FTD :OSIR
    :Neuspeed -Insert,Brake Lines:Eurojet -Ceramic Coated DP :DEFI :Unibrace :Tyrolsport :Bildon :Hawk
    TSI FAQ: http://forums.vwvortex.com/showthread.php?4042736
  6. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    05-10-2012 09:16 AM #6
    also what are your torque numbers?
    and the most important question of all, how does the car drive and are you happy with it?
  7. 05-10-2012 09:42 AM #7
    That is probably the most powerful APR K04 I have seen to date... 366 is BHP and 314 is WHP.. most APR K04 run 290-315.
  8. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 11:55 AM #8
    ok well thank you to everyone for some clarification. i have to go back to the shop today so maybe ill try another pass and see whats up.
  9. Member snubbs64's Avatar
    Oct 23rd, 2004
    2010 A3q, 2003 20 AE GTi 1.8BT, 2004 CBR 600F4i
    05-10-2012 01:08 PM #9
    Now i'm new to this motor but i was under the impression they ran lean compared to port-injected motors? Maybe not this lean (?), but lean.
    Also, doesn't an engine usually make more power when running lean (maybe not this lean???), but also lots more heat leading to all sorts of awful things?
  10. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 01:41 PM #10
    so i took some logs on a 4th gear pull (same pull as dyno) and this is what i found...
    if someone has any insight on this...please explain as i am new to taking logs and such
  11. 05-10-2012 03:02 PM #11
    I think the logs dont look bad at all.. you have a little timing pull but from what i understand it is normal to have a little.. You should post on golfmk6 if you want more help.. Grambles over there knows alot about what you should be seeing with the APR K04
  12. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 03:02 PM #12
    just spoke with APR on this "issue"..they will be posting on exactly what we talked about on the phone...
  13. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    05-10-2012 03:11 PM #13
    Quote Originally Posted by sum41kid861 View Post
    great i would love to hear the follow up from APR! as I am going that route eventually to K04!
  14. Forum Sponsor Evan@APR's Avatar
    Nov 8th, 2010
    Milton Keynes, UK
    Scirocco 2.0TSI
    05-10-2012 03:54 PM #14
    The logs look spot on, really. As I discussed with the OP, the car is not running too lean and meeting requested boost so there's no indication of underperformance. Mildly speculating that there is insufficient cooling/airflow on the dyno itself so we agreed to run logs on the next dyno. We'll see what they yield shortly.
    “The bitterness of poor quality remains long after the sweetness of low price is forgotten."
    www.goapr.com
  15. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    05-10-2012 03:57 PM #15
    you have 20 people jumping up and down saying everything is normal....
    maybe things are in fact, normal
  16. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 04:01 PM #16
    it looks like i wont be able to get back on the dyno until tomorrow so i will have new dyno sheets and dyno logs tomorrow evening.
    and i know everyone was saying it was ok but i wanted to be sure by speaking with apr and reviewing my logs first
  17. Forum Sponsor Evan@APR's Avatar
    Nov 8th, 2010
    Milton Keynes, UK
    Scirocco 2.0TSI
    05-10-2012 06:24 PM #17
    You know you can always just call us first, right?
    www.goapr.com
  18. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 06:32 PM #18
    Quote Originally Posted by Evan@APR View Post
    i do...it was after business hours when i had been dynod and taken logs tho
  19. Member RedLineRob's Avatar
    Feb 8th, 2009
    San Francisco
    2012 A3 Quattro
    05-10-2012 07:10 PM #19
    take off then forge twintercooler forge twin take they dont pair up good with APR!
    also i think APR's power figures on there webpage are not WHP but horsepower to the motor
    So 360hp to the motor and your putting out 310 whp not to bad at all, plus all dynos are different. It seems thou your dyno is pretty honest
  20. Member sum41kid861's Avatar
    Oct 30th, 2006
    NY
    08 GTI
    05-10-2012 08:40 PM #20
    lol im happy with my configuration...despite what "works well" with APR. i was a major player in the 2 pieces on the TSI motor so its sentimental to me if you may. plus im not to fond of the other options out there (no offence to those companies but its to each his own right?).
