Results 1 to 6 of 6
Thread: MK1 VR6 fuel line and filter?
    May 14th, 2009
    85 Cabby, 03 GLI 24v, mk3 Jetta
    05-10-2012 07:46 PM #1
    Just curious what some people are doing for their mk1 vr6 fuel lines and a fuel filter. What do you like/not like about your current setup?
    Thinking about re-flaring the current lines and running a rubber fuel line to the rail.
    Thoughts? Suggestions?
    May 14th, 2009
    05-11-2012 09:18 PM #2
    Anyone?
    Aug 26th, 2007
    '08 touareg, '97 jb de x2, '86 vr6 Rocco, '84 8v Rocco, '95 Vr cabby "hers"
    05-20-2012 11:24 PM #3
    I just got mine running correctly... Kinda today... Y would u do that? If you lookat a mk3 the rubber line starts on the firewall to the fuel rail... Just disconnect the union where the fuel line begins to feed over to the dr side and go from there...
    May 14th, 2009
    05-21-2012 03:11 AM #4
    The factory hard fuel lines in my cabby come up by the firewall like in a mk3 then bend and run towards the driver side. I was thinking about using the rubber fuel lines from the mk3 and cutting the factory hard lines in my cabby right by the firewall like you said.
    What are you doing for a filter?
    Aug 26th, 2007
    05-22-2012 12:01 AM #5
    Didn't even think about that I'll figure out somewhere to splice one into the feed line prob under the car right after the pump under the car...
  6. Member RedWabbitVR's Avatar
    Feb 28th, 2006
    Lansdale
    84 Rabbit Convertible VR6, 81 Rabbit Hatch, 81 Rabbit Diesel Caddy, 00 Jetta VR6, 01 Jetta 2.0
    05-28-2012 09:04 PM #6
    Quote Originally Posted by sweetrocco420 View Post
    I took the mk3 plastic lines and right under the car near the firewall cut the hard lines and just used an adapter to mate the 2. no leaks but I do need to shorten up the plastic lines some more.
    VRSociety #301
