Results 1 to 9 of 9
Thread: need help installing mk3 lights
  1. Member lilgreenmk3's Avatar
    Dec 15th, 2011
    orange county
    mk2 16v/ b3 vr6/ mk3 2.go/ 73 ragtop squareback /mk3 vr6
    05-10-2012 08:05 PM #1
    sup, so i bought some smoked lights for the mk3 and when i took the stock ones off i realized the lights dont exactly line up i dunno if i got some defected ones or if its goin to take some modification here is what i have http://www.ecstuning.com/Volkswagen-...ator/ES248211/ now looking at the fog light side posts where the bolts would go the stocks are opposite than the new ones " long top & short bottom" now hopefully that made some kinda sense, if you have these installed on your mk3 can you please help or point me in the right direction. thanks
    thanks in advance
    Never let your vr know your broke........ then they think its OK to break....
  2. Member cdub58's Avatar
    Sep 25th, 2006
    south cal.
    mk3 60' bug g60corrado
    05-10-2012 09:16 PM #2
    The ad states
    Requires the use of European spec front bumper OR requires some modification to secure these in a USA spec bumper
  3. Member lilgreenmk3's Avatar
    Dec 15th, 2011
    orange county
    05-10-2012 09:19 PM #3
    i understand the modification part but not sure what to exactly modify i'd rather do it somewhat part of right than just start hackin away, so they would sit securely and still work properly want to try to get some help before i end up sellin em and buying a shaved bumper thanks for your op. tho cdub
  4. 05-10-2012 11:07 PM #4
    this helped me, here ya go.
    http://www.aircoolednut.com/erkson/p...jetta_e-codes/
    Goodluck..
  5. Member lilgreenmk3's Avatar
    Dec 15th, 2011
    orange county
    05-11-2012 01:27 AM #5
    Thanks but I have my ecodes and badge less grill installed I was talking bout my smoked blinkers dummies and fogs needed help with the installation of those thanks tho much appreciated
  6. Member hainuS4's Avatar
    Nov 23rd, 2001
    Diamond Bar
    95 golf sport
    05-11-2012 11:05 AM #6
    for the fog lights, you'll need to make a lil extension bracket for the nounting tab. The turn signals, you'll have to trim out some of the bumper, to get them to slide into place. I actually have mine double side taped in place, since the tab that should hold it in wasnt cutting it.
    TBS Fo Life!
    psn: PandaGti
    I can't wait for Oktoberfest!!!
  7. Member lilgreenmk3's Avatar
    Dec 15th, 2011
    orange county
    05-11-2012 04:18 PM #7
    Koo thanks hain would ya happen to have any pics or know where some are I tried Google but no dice, hain u play gt5 huh I know u sir at least on gt5 I do' lol I think ....
  8. Member cstjetta's Avatar
    Jan 27th, 2004
    San Clemente
    mk5 2.5 rabbit
    05-11-2012 09:40 PM #8
    i had to trim my old mk3 bumper to fit the smoked as well. the best thing to do is just take them and place them in the bumper slots, see what needs to be trimmed take a little bit off each time and continue to test fit, cut, test fit, cut continue. this will give you the best fitment.
  9. Member lilgreenmk3's Avatar
    Dec 15th, 2011
    orange county
    05-12-2012 12:02 AM #9
    Aight koo bruh thanks I'll have to do that in the morn I'll post pics as I go along so I can try to make a DIY to help others again thanks man much appreciated
