Can you pull logs VIA VCDS?
(Yes - I got this from
GOAPR)
1 001-1 Engine Speed
2 014-3 Misfire Sum
3 031-1 Lambda, Current Value
4 054-3 Accelerator Pedal Position
5 054-4 Throttle Plate Angle
6 101-3 Injection Timing (Median)
7* 103-1* Current Fuel Pressure*
8 114-4 N75 Duty Cycle
9 115-3 Boost Pressure (Specified)
10 115-4 Boost Pressure (Actual)
11 230-1 Rail Pressure - Specified
12 230-2 Rail Pressure - Actual
This will help us determine what is going on. It could be several factors.
I have heard a couple of people mention the Diverter valve. I have spoken to APR about the diverter valve and have asked them several times if an aftermarket valve is required. They told me that the OEM revision D valve that our car uses is more than adequate to hold their stage III kit which puts MUCH more stress on the car than our little K04 does.
I agree that there is still a possibility that you have a failing diverter valve, not arguing that. I would suggest that you run some logs and get some hard evidence before we come to any conclusions. There are other things in the system that could cause problems.
