Results 1 to 8 of 8
Thread: EVOMS V-Flow Intake Install
  1. Member BlueDream's Avatar
    Nov 7th, 2010
    Land of Hippies & Ducks
    '04 R32 '97 Taco
    05-11-2012 11:38 PM #1
    Hey guys, so I'm attempting to install my V-Flow intake but I am having an issue with getting the rubber coupling to attach to both the MAF and the rear part of the intake itself. It seems that the rubber coupling is not large enough to get around either so I was wondering if there is any specific way to get it on there. Any help/suggestions would be much appreciated.
    I also searched on here and there isn't squat on this subject, and I have looked at EVOMS website at their instructions but that didn't seem to help and I'm at loss.
    Sorry for such a noob question
  2. Member rconn14's Avatar
    Sep 6th, 2006
    Connecticut
    2004 BMP R32
    05-11-2012 11:58 PM #2
    Take a picture of what you're trying to put it on... mine goes on where it should, maybe you're putting it on the wrong part of the tubing?
    http://r32registry.org/802 ||| Large Garage Banners FOR SALE
    Quote Originally Posted by B3VW Hasan View Post
    I have to stop this idiot from deminishing my credibility every time he posts because my usernsme is in his sig. Who do I talk to?
  3. Member FigureFive's Avatar
    Dec 21st, 2003
    Nashville, TN
    MkIV R32
    05-12-2012 12:40 AM #3
    Stretch, stretch, stretch the silicone coupler. You can probably get it on there. I had a similar problem getting the coupler from my EIP intake onto the MAF housing, but I just kept pushing and twisting it and it eventually stretched out enough to slide on.
    Maybe try heating it a little.
  4. Junior Member choppeR32's Avatar
    Apr 24th, 2010
    Rhode Island
    MKIV BMP .:R32
    05-12-2012 03:24 AM #4
    Quote Originally Posted by FigureFive View Post
    ^^x2
    The coupler is TIGHT!!! Especially brand new, the best way is to heat it with a hair dryer, or heat gun if you have one and immediately slip it on. It'll still be tough but you'll get it.
  5. Member The Sage's Avatar
    Jul 30th, 2004
    Mobile, AL
    13 AW 328 M-Sport 04 DBP R32, 01 RS VRGTI, 04 CW TREG
    05-12-2012 08:01 AM #5
    Luuuuube
  6. Member BlueDream's Avatar
    Nov 7th, 2010
    '04 R32 '97 Taco
    05-12-2012 11:46 AM #6
    Here is how I'm putting it together:
    Untitled
    And here is the silicon coupling:
    Untitled
    Now I guess my question is which end of the coupling goes on which part? As in does the larger side of the coupling go on the MAF or does that attach to the intake tube?
    Thanks for all the help/suggestions so far
  7. Member FigureFive's Avatar
    Dec 21st, 2003
    Nashville, TN
    MkIV R32
    05-12-2012 11:50 AM #7
    Quote Originally Posted by BlueDream View Post
    If the MAF is the same diameter or wider than the intake tube put the wider side of the coupler on the MAF. If the intake tube is wider than the MAF you will probably have to put the wider side of the coupler on the intake even though it'll be a little bit of a bottle neck.
  8. Member BlueDream's Avatar
    Nov 7th, 2010
    '04 R32 '97 Taco
    05-12-2012 11:58 AM #8
    If the intake tube and the MAF are the same diameter I'd put to the wider side of the coupler on the MAF so that it isn't bottle-necking. If either the tube or the MAF is wider than the other then put the wide side of the coupler onto the wider of the two.
    Ok well I guess I'll be putting the larger side of the coupler on the intake tube as its just a hair bit bigger than the MAF. Thanks for the help.
