VWVortex.com - Front Rotors
    Results 1 to 7 of 7
    Thread: Front Rotors
    1. Member FGuri32's Avatar
      Dec 26th, 2007
      NY
      .:R
      05-12-2012 03:11 PM #1
      In the market for new front rotors. I am most likely going to replace the front rotors with OEM ones, but I am sick and tired of the brake dust.
      Crossed drilled rotors supposedly help with this issue. Is it true? If so, anyone have recommendations for what brand of crossed drilled rotors?
      Thank you!
      All replies are appreciated it.
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      05-12-2012 05:02 PM #2
      brake pad compounds will help more with brake dust
      APR Stage 1/Morimoto 5500K D3S bulbs/Hella XY 9006 bulbs... keeping the mods light on this one...
      Aug 10th, 2007
      Nuevo México
      2008 Passat, 2.0T, 6-speed manual
      05-12-2012 10:46 PM #3
      Quote Originally Posted by BsickPassat View Post
      +1. Brake rotors, regardless of design, are not going to help reduce dust very much.
      Alpinweiß
      2008 Passat, 2.0T, 6-speed manual, Euro lights
    4. Member FGuri32's Avatar
      Dec 26th, 2007
      NY
      .:R
      05-13-2012 03:19 PM #4
      Quote Originally Posted by alpinweiss View Post
      ah i see. so crossed drilled rotors dont make much of a difference in terms of performance?
    5. Member nodashi's Avatar
      Mar 20th, 2012
      Whidbey Island, WA
      2006 FSI 2.0t Passat
      05-13-2012 08:20 PM #5
      Drilled rotors help heat escape.
    6. Member
      May 10th, 2010
      North Jersey
      05-13-2012 08:29 PM #6
      Quote Originally Posted by jettamkIVvr6 View Post
      for street applications... it is all about looks
      not really worth spending extra money
      slotted rotors dust more, as it continually scrubs the pad
      Feb 13th, 2009
      Ontario
      2007 2.0T, 6MT, shadow blue Passat wagon
      05-13-2012 11:41 PM #7
      Agree with above about cross drilled being for looks on the street. You'll only ever see any appreciable difference with drilled rotors if you track the car. Most 'drilled' rotors are not cast with the holes in them.. .they are actually drilled. And drilling cast iron and using them on your daily means water/rust will get in the holes and they'll crack and cracked cast iron will crack.
      Bottom line, you won't see a diff in braking performance. Get some solid vented rotors and get pads with some ceramic/organic compound for reduced dust and better braking. I just bought a set of Zimmerman rotors and PBR Deluxe pads. Very low dust (had this setup on my B5).
