View Poll Results: How long do you wait?
Voters
274. You may not vote on this poll
  • very minimal - get in and go
    109 39.78%
  • 5-30 seconds - Let the engine drop to normal idle
    137 50.00%
  • A minute or so - set up the radio/GPS
    18 6.57%
  • A few minutes - turn the car on and walk back inside
    10 3.65%
Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 80
Thread: From turning the key to driving - how long do you wait?
    Jun 4th, 2009
    Ocean Springs, MS
    '03 GTI 1.8T
    05-12-2012 03:37 PM #1
    Assuming the car is cold and the weather is warm.
    I have heard various things from "you need to start driving right away" to "let it idle for a few minutes before driving." I am just curious to see what TCL thinks
  2. Member someguy123's Avatar
    Sep 30th, 2005
    05-12-2012 03:40 PM #2
    If weather warm, just start & go.
    Just keep the revs down while doing it until it is fully warmed.
    5-30sec will not drop revs to idle....
  3. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    05-12-2012 03:45 PM #3
    I usually give it a minute or two of bouncing off the rev limiter before I go. Seems to warm it up enough. A little longer when it's really cold out (winter).
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  4. 05-12-2012 03:47 PM #4
    As long as it takes me to put my seatbelt, find my shades, and press the clutch.
  5. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    05-12-2012 03:47 PM #5
    Quote Originally Posted by AIRider View Post
    What about at night? Do you also have to find your shades at night?
  6. Member 302W's Avatar
    Jul 24th, 2004
    NoVA
    05-12-2012 03:50 PM #6
    Ah crap, voted wrong. About 30 seconds, let the oil circulate for a bit and then drive normally.
    1988 is not an 80's car, it's an early 90s car but whatever.
  7. Member Iroczgirl's Avatar
    Feb 17th, 2007
    Bend, OR
    '55 Ford 351C, '80 Rabbit AAZ
    05-12-2012 03:54 PM #7
    I look at the oil pressure gauge, when it builds up, I take off.
    Usually about 5 seconds.
  8. Member BeBop!'s Avatar
    Jun 18th, 2009
    MN
    2006 Passat 2.0T
    05-12-2012 03:54 PM #8
  9. Member oldskoolracer's Avatar
    Mar 6th, 2009
    Clearlake, California
    1989 Volkswagen Golf GTi, 79 Plymouth Volare 225 supersix
    05-12-2012 03:54 PM #9
    First start of the day I always let it sit for 2-5 mins at least. Mid-day (going home for lunch) I let it sit for a min or two before I start driving. Any other part of the day, running errands, going to the store, ect, I turn the key and start going putting my seatbelt on as Im pulling away
  10. Member VadGTI's Avatar
    Feb 24th, 2000
    Hollywooooooood, CA
    05-12-2012 04:11 PM #10
    Quote Originally Posted by oldskoolracer View Post
    That's a whole huge chunk of your life wasted idling.
    Sent from my T-Mobile G2 using Tapatalk 2
    Fizzy - Team My Little Pony
  11. Member Minty_Fresh's Avatar
    May 27th, 2009
    Dela-Where?
    Juced Cutty on 13's
    05-12-2012 04:13 PM #11
    once i hear the SAI pump turn off i drive.
  12. Member oldskoolracer's Avatar
    Mar 6th, 2009
    05-12-2012 04:41 PM #12
    Its just a metter of planning ahead, I know when I gotta leave in the morning so I go out about 5 min before I have to leave, start the car and go back inside to finish. Also I guess Im never really so busy in life that allowing my car to warm up is a waste of time
  13. 05-12-2012 04:44 PM #13
    I usually give it a minute or two.
  14. Member undpilot757's Avatar
    Sep 17th, 2005
    Davenport, IA(the Quad Cities)
    '98 BMW M3/4/5, '67 Mercury Cougar
    05-12-2012 04:45 PM #14
    The engine warms up faster and is oil pressure is much higher if you just drive. This is better for the engine than idling. Most BMW manuals say to drive immediately and I've yet to see an owners manual that said to let the car idle to warm up.
    It's a machine, it's not human, or alive for that matter.
    '98 E36 M3/4/5
    '67 Cougar
  15. Member lojasmo's Avatar
    Dec 23rd, 2002
    SE MN
    2006 Vue, 2012 Chevy Cruze LT2, Soon to be NA Miata.
    05-12-2012 04:49 PM #15
    Start car, shift to drive, mash go-pedal.
  16. Member Avus's Avatar
    Sep 20th, 2000
    Toronto
    1993 Celica GTS, 2007 S2000
    05-12-2012 04:51 PM #16
    I chose minimal. I don't warm up my car by idling on drive way wasting gas. My method of warming up my car is accelerate the car slowly and shift early (not over 2500rpm).
    Windows Vista (32bit only)/7/8 "God Mode"
    - Create new folder on desktop
    - rename folder to the following:
    GodMode.{ED7BA470-8E54-465E-825C-99712043E01C}
  17. Member TheTimob's Avatar
    Sep 13th, 2003
    Glenside, PA
    84 Scirocco on Megasquirt
    05-12-2012 05:02 PM #17
    I just start and go.
    My grandpa will get in his car, put it in gear (all household cars are manual trans) and start it with the clutch in. He lets the clutch out as soon as the starter finishes cranking and goes.
    Vintage Watercooled Technotes:
    http://www.vintagewatercooleds.com/tech/
  18. Member oldskoolracer's Avatar
    Mar 6th, 2009
    05-12-2012 05:03 PM #18
    Quote Originally Posted by undpilot757 View Post
    Well lets keep in mind not all of us drive a fuel infected car, being carbed with a choke Im kinda forced to let it warm up at least until the choke opens. More modern cars ( including electronic carbs) have preset fuel curves and idle adjustments that allow you to start it and drive. A freezing cold day, its nice to come out to a warm car with defrosted windows right? Oil pressure in most cases may be a little lower at idle (depending on vehicle), my volare 225 six has 50 psi when cold @ idle, and about 40 when warm at idle, so dont really care theres plenty of oil flow to all the engine components. Giving it a min and just driving it easy works perfect too, but its silly hearing "I jump in and smash the gas"... Its a preferance thing for me not a matter of having to.
  19. 05-12-2012 05:06 PM #19
    Turn it on, wait at lease 2 minutes, be out.
    Sega|Saturn
  20. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    05-12-2012 05:20 PM #20
    the injection system in my new truck drops to idle in around 30 seconds actually, then away I go on a warm day.
    According to the owner's manual that is how it should be driven, fire it up and go.
    According to much older and legitimate information the best way to warm up a vehicle is to drive it normally at a maximum of 35 mph for the first 10-15 minutes of operation.
    The reason this makes sense, is you may be warming up your motor, but the transaxle is not warming up unless equipped with a cooler and pump.
    On a day where things are frozen I am inclined to let a vehicle warm up from 2 to 5 minutes before driving. Usually so I can get the defrost kicking.
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
  21. Senior Member A.Wilder's Avatar
    Mar 1st, 2003
    Raleigh, NC
    99 V70
    05-12-2012 05:25 PM #21
    fire it up, do a smokey burn out and go!
    neighbors are such whiners
    Mark Twain
  22. Member MikkiJayne's Avatar
    Jan 1st, 2007
    UK
    A6 TDI Quattro wagon, A4 V8 Quattro racecar
    05-12-2012 05:28 PM #22
    Quote Originally Posted by lojasmo View Post
    This ^
    Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
  23. Member ti.pilot's Avatar
    Feb 13th, 2002
    Atlanta, GA
    '10 RX-8 R3
    05-12-2012 05:32 PM #23
    ~30 sec. Or until I see the tech needle sitting at about 1500RPM
    zoom-zoom
  24. Member
    Mar 17th, 2003
    Lehi, UT
    Miata, Wrangler, Soul, Mustang & a turbo minivan
    05-12-2012 05:38 PM #24
    Depends which vehicle I'm driving.
    For either Soul or my Wrangler, I typically buckle up and do any/all other preparatory activities before I actually start the car. Once the engine is finally fired up, I will pause only long enough for the idiot lights to go out (3 or 4 seconds), then I put it in gear and off I go.
    For the minivan, the process is different. I will jump in and fire it up immediately, then go about buckling in, grabbing sunglasses, turning on the stereo, etc. Even when those other preparatory activities are complete, I typically pause for an additional 10 to 20 seconds before finally putting it into gear and moving off. I probably give it about 30 seconds or so in total.
    Dempsey Bowling
    Sales Consultant at Doug Smith Dodge/Chrysler/Jeep/Ram/Subaru/Kia/used (800) 553-3099
    My fleet: 91 Miata, 98 Wrangler Sport, 12 Soul +, 89 Voyager turbo, 06 Mustang GT, 01 Suburban 2500 8.1L
  25. Member undpilot757's Avatar
    Sep 17th, 2005
    05-12-2012 05:44 PM #25
    DOH! My other car is carbed, and it definitely doesn't run for crap until it's warmed up!
    '98 E36 M3/4/5
    '67 Cougar
  26. Member volkstyle's Avatar
    May 11th, 2010
    BMP .:R32
    05-12-2012 07:11 PM #26
    Cold weather? Let it run until the heat is nice. Hot weather get in and go but keep it under 3000 Rpms. No reason to wait.
    Heart pumping antifreeze as I stand here.
    Lloyd Banks
  27. Member FBMphil's Avatar
    Feb 18th, 2006
    Chicago 'burbs
    Focus hatch
    05-12-2012 07:27 PM #27
    I turn the key right before I clutch into first after my car rolls backward down the driveway in neutral. Nevar waits.
  28. Member
    Apr 26th, 2009
    Raisin toast on 22s
    05-12-2012 07:28 PM #28
    I've got underground parking, so the temp is usually around 15C regardless of outside conditions.
    I usually give it 10 seconds, basically long enough to get my belt on and the handbrake off (old habits die hard), and a few seconds to listen to the engine for anything unusual.
  29. n00b
    Mar 3rd, 2012
    Grand Forks, ND
    2008 Mazdaspeed 3, 2007 Chevy Silverado
    05-12-2012 07:37 PM #29
    I remember an old factory Porsche manual i had that specifically stated to NOT warm up your vehicle before driving. It basically said drive easy until at operating temperature. If i remember correctly it mentioned " hot spots" if you try to warm the car up before driving it.
  30. Member
    Jan 15th, 2002
    Brooklyn, NY
    05-12-2012 08:58 PM #30
    5 seconds unless something gets my attention.
  31. Member Hawk's Avatar
    May 7th, 2010
    Toronto, Canada
    05-12-2012 09:07 PM #31
    Why would anyone turn on the car and walk back inside?
  32. Member Hawk's Avatar
    May 7th, 2010
    Toronto, Canada
    05-12-2012 09:09 PM #32
    Quote Originally Posted by DTMTrini View Post
    What happens in those 2 minutes?
  33. Member McBanagon's Avatar
    Feb 24th, 2010
    Northern part of the Virginia
    Two Vanagons and some old British iron.
    05-12-2012 09:42 PM #33
    That's a little long, don't you think? Aren't most leases like, 36 months
  34. Member Shomegrown's Avatar
    Feb 26th, 2002
    Detroit
    Current: Audi S4, BMW M5, Audi A3 quattro, Dodge Dakota 4x4
    05-12-2012 09:46 PM #34
    Why would you wait?
  35. Member 2.0_Mazda's Avatar
    Nov 3rd, 2010
    Mtl, Quebec
    Protegé
    05-12-2012 09:51 PM #35
    I take longer in Winter, but when cold I take about 45 seconds
    no signature
