Results 1 to 4 of 4
Thread: RPM cutout
  1. Member ThatsNotStock's Avatar
    Dec 30th, 2004
    S.E. Wisconsin
    81 Rabbit Diesel AKA The Smoke Monster
    05-12-2012 04:05 PM #1
    The C has been running good latley so I wasnt surprised when this started. Its all stock with ISV reroute and Boost return bypass. In the video I am slowly increasing the rpms.
    I can get thru the dead spot by keeping the rpms above 3k. and it Idles just fine. It will do it with/without the ISV plugged in. I checked for vacuum leaks, gremlins, broke wires ect.
    Sounds like a bad ISV at idle. Anyone else have an Idea?
    "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former"
    (Albert Einstein)
  2. Member G60 Carat's Avatar
    May 14th, 2004
    Regina, SK
    1986 Jetta Carat G60, 2001 Allroad 2.7T, 1982 320i
    05-13-2012 04:19 AM #2
    what exactly is it doing? I watched the video, but I don't know if you are reving it or if it is reving up itself.
    What is the exact issue.
    | Rust | Zip-Ties | JB Weld | Bad Idle | Scrapes Ground | Rubs when Turning | Busted Ass Door handles |
  3. Member ThatsNotStock's Avatar
    Dec 30th, 2004
    S.E. Wisconsin
    05-14-2012 09:41 AM #3
    The first couple revs are me getting it smoothed out(up to 14s in the video)...then I steadily/slowly gave it gas (about 17s on)....I never let off the gas pedal.
    (Albert Einstein)
  4. Member ThatsNotStock's Avatar
    Dec 30th, 2004
    S.E. Wisconsin
    05-16-2012 09:43 PM #4
    found the problem....bad o2 sensor
    (Albert Einstein)
