#36
How much did they draw at idle each?
I just corrected my timing last night with a advanced timing light so I could finally set it.
After I set the timing, I just threw the gauge on all, they were all pulling 10 evenly. I haven't touched the idle mixture screws or anything yet. I only had like 30 mins last night, so I set the timing then cleaned up pretty much, but tonight I plan on investigating a little more.
Some of my work
http://forums.vwvortex.com/showthrea...and-powdercoat
#37
#39
got a new cellphone and wanted to try how it filmed.. small vid of the idle with throttle response , im always amazed of how well webers can make big cams idle like stock !dont know why it sounds so echo , IRL it dosent sound like that
link to the vid
#40
Sounds awesome, did you have any jets around? That you wanted to sell? I'm going to be ordering a redline kit tomorrow if I can find any jets cheap.
I turned my mixture screws all the way in, then back out 2 1/2 turns. No Bueno with the current drilled out jets... I have to turn them out like 4 -5 turns to get it to run.
Some of my work
#42
new update with pictures soon,
ordered some stuff :
MS from need a vr6 ( not received yet )
dist block off plate ( not received yet )
got another valve cover modified and powdercoated wrinkle black
modifier some 2lt coils
arp head stud
metal headgasket ( fiber one didnt last long lol )
034 external crank trigger kit
new lifter ( not received yet )
lot of techflex and shrink tube ( not received yet )
should start to work on it this weekend !
#43
looooong day at work today, still not over yet, but im done for today, what a pain in the A/$?%/ !
and new wheels !
#44
got all the old undercoating off then put new one + graveguard, also i am doing a bit of finition of the windshield frame
#45
exterior of the frame is done, now im rebuilding a lip inside
#47
Some of my work
#48
didnt really had the choice, it was leaking and found out that first the lower frame was gone, and that that windshield wasnt even glued to the car ,i removed the molding and the windshield came loose and i removed it.. that was very dangerous can you imagine if it had a crash the windshield would have popped out ! damn people![]()
#50
what a great build! I wish I knew how to work with carbs so I could clean up my bay with webers like these!
"complaining is silly, either act or forget."
MKII GTI build:
http://forums.vwvortex.com/showthrea...-GTI-build!...
#51
if you really want it, just pm me and i can give you help !![]()
#52
any updates?!?!?!
MKII GTI build:
#54
traded the weber setup for a 92 16v motronic setup + cash from him .. i wanted everything to be as good as possible and as realible as it could be so ..
things new :
- new fuel pump
- new accumulator
- new metal fuel lines
- new cold start injector
- passat fuel dizzy cover
- new coil
- new injectors, cups, seals
- new FP relay
- new coolant sensor
- new 02 sensor
soon to come : new FPR
old stuff .. :
#56
i wanted to try something different ( here there are almost no gti 16v and even less with they motronic most are swapped vr6 or 1.8t ) and i want to use my gti as a daily driver this summer but could not because of fuel consuption, i will go webers again but later and on a 20v head and dcoes 48
