Results 1 to 28 of 28
Thread: CODE P2181 check engine light question
  1. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 08:05 PM #1
    my light has been on for about 2 weeks now and i can't figure out why,
    code from autozone states, cooling system performance, low coolant level probable cause (coolant isen't low) failed radiator or water pump (it's not overheating and has been at the same temp for years) and lastly check ECT sensor and i changed that last week (coolant temp sensor)
    anybody have any advice on this?
  2. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    02 Mercedes C230 Kompressor Coupe 6 MT, 2012 Nissan Cube, 00 VW Beetle 1.8t
    05-12-2012 08:48 PM #2
    Quote Originally Posted by breez6777 View Post
    When my car threw this code the waterpump went within a couple hundred miles.
    Miles?
    Instagram: jetta02awp
    Sep 8th, 2010
    05-12-2012 09:17 PM #3
    You said you've replaced the coolant tempature sensor so that's rulled out.
    Are both the fans working?
    - Turn the car on
    - Put the fan on and push the a/c button.
    - Are both fans working? If not, there's your problem.
    Quick easy way to check water pump and thermostat:
    - Put the fan on with temperature set to hot.
    - Does heat come out readily from the vents?
    If not, Probably the water pump is gone. If it does, likely the thermostat is gone
    BOYCOTT ebay...............................VRalliance#69 VRSociety#279
    FS: *RARE* 17x8.5 Mercedes Markabs....Feeler: Vintage 1988 Mongoose Stylist
  4. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 09:51 PM #4
    Quote Originally Posted by Jetta02AWP View Post
    Miles?
    86,000 timing belt's been done just not pump.. by me at least i bought it with 70,000
    Quote Originally Posted by KCISRViTG10 View Post
    - Turn the car on
    i seen this online and checked, yes both fans are working and when i place on heat, it comes out normally..
    so possibly thermostat?
  5. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    05-12-2012 09:54 PM #5
    Geez, who replaces the timing belt and not the waterpump. The $100 part is definately worth it when going in there to do all that work
  6. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 09:59 PM #6
    lol true dattt, oh well my bad
  7. Member turbo3jetta's Avatar
    Dec 17th, 2011
    Tucson, Arizona
    2003 Vw Jetta
    05-12-2012 10:00 PM #7
    water pump and thermostat should have been done. either can cause that code. honestly the water pump should have been replaced with the t-belt. especially since they are plastic and are known to crack/fall apart... t-stat should be done just because its pretty much tired out by 100k. mine went out at 110000. i know t-belt replacement is expensive but its cheaper than buying a new engine or a new car...and if you know your way around a car you can do it yourself
  8. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 10:03 PM #8
    Quote Originally Posted by turbo3jetta View Post
    i think the thermostat is what im doing next, what are the symptoms of a bad water pump though? my car is not overheating or ever has and the temp gauge is constant
  9. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    05-12-2012 10:05 PM #9
    The thermostat is a 20 minute job is you follow the DIY from one of the Audi forums (should be in the FAQ/DIY) using the right combonation of extensions and a u-joint on the ratchet and you don't have to take out the alternator. This was the first thing that I did and it turned out to be the waterpump
    edit: here is the link for the thermostat replacement
    http://forums.audiworld.com/showthread.php?p=16925102
  10. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 10:06 PM #10
    oh geez that sucks, do u know of any symptoms ?
  11. Member turbo3jetta's Avatar
    Dec 17th, 2011
    Tucson, Arizona
    2003 Vw Jetta
    05-12-2012 10:13 PM #11
    the car doesn't have to overheat necessarily in order for the pump to be suspect. the engine may get hotter than normal under load, and it can overheat. remember there may be some propellers left on there that haven't broken off. it will fail on you if it was not replaced. its just a matter of time. i'm not trying to scare you and i hope i don't come off like that. just trying to be as factual and informative as i can.
  12. Member Jetta02AWP's Avatar
    Feb 27th, 2003
    Eastlake,OH
    05-12-2012 10:15 PM #12
    If you change the thermostat, while you have the old one out you can stick your finger in there are feel the waterpump impeller and if you can turn it, it has most likely separated from the shaft. The impeller in my car did not fall apart but there was spider cracks around where the plastic was pressed onto the shaft and at any RPM but idle the impeller would basically stop spinning. It came pretty much without warning. I was driving home from work and out of nowhere the temp spiked and started beeping at me. I stopped and the temp would drop back down to normal. Start moving again and it would start to overheat again.
    The spider cracks around the shaft were allowing it to spin under little pressure but as soon as I put the car under a load the impeller would stop spinning and the car would overheat
  13. Member
    Aug 4th, 2011
    KCMO
    2010 UG K04 GTI, 2006 g35x, 2003 mkiv Gti, 2001 mkiv jetta
    05-12-2012 10:17 PM #13
    Agreed. Plus you should probably do your waterpump anyways, even if it isn't what is throwing the code. I know I had a magnaflow catback on my old GTI and it caused this code and the CEL to come on every now and then, but it would just go away.
    But again, this was after I had already replaced the thermostat, water pump, and looked into any other culprit, so if you don't have an aftermarket exhaust, or done a cat-delete or something...then I would replace all parts you need to anyways, because you eventually will have to, and you might as well before something actually goes out
    edit: you will most likely know if it is your water pump
  14. Member turbo3jetta's Avatar
    Dec 17th, 2011
    Tucson, Arizona
    2003 Vw Jetta
    05-12-2012 10:21 PM #14
    ^ this is very true. i have seen this before as well as chunks missing and the whole impeller missing. OP just replace it and save yourself the trouble. or do the t-stat first and check the water pump as previously suggested. but honestly it will most likely fail before the next t-belt is due.
  15. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-12-2012 10:39 PM #15
    oh no i completley understand and appreciate it i know of this already i guess i just been overlooking it b/c everything seemed fine for so long
    Quote Originally Posted by travis.rudd View Post
    i have a magnaflow catback and 42 dd downpipe & highflow cat WITHOUT the o2 sensor spacer lol but it was on for like 3 weeks with no check light on so i thought i just got lucky and didnt need 1
  16. Member
    Aug 4th, 2011
    KCMO
    05-13-2012 01:31 AM #16
    ya I had mine on for almost 6 months before the light came on, I replaced everything, even though when I got to the thermostat, and sensor I came to find they already had practically brand new ones, but oh well, and I had replaced my pump previously so I knew it wasn't that. So it had to be the o2 sensor and my exhaust system. Like I said though ,it was on an off, but mostly just annoying to look at. If you do all the maint and it's still there, you can get a vagcom and clear it out if you want, I did, but it came back a couple times. Then it just shut off, and when I sold the car it was still off, but I let the buyer know about it. So idk, just annoying more than anything, as long as that's all it is
  17. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-13-2012 02:18 AM #17
    yeah i dont think its anything bad i just dont like the idea of it being on just incase some bad **** happens and i drive it normally like its not.. what code will it throw from the 02 sensor not being spaced?
  18. Member
    Aug 4th, 2011
    KCMO
    05-13-2012 11:59 AM #18
    Ya I hear ya. If it's anything REALLY bad it will flash, instead of be a steady light. The code is still 2181 From the O2 sensor I think, it's really an emissions thing that unless you live in a state that cares, isn't even anything to worry about. It will prob go off on it's own if you have already taked care of the aforementioned problems
  19. Member breez6777's Avatar
    Jun 3rd, 2011
    NM
    2004 VW Jetta 1.8T
    05-13-2012 02:10 PM #19
    yeah i live in new mexico right now where their are basiclly no laws lol but im going back to new york soon and have to get everything fixed
  20. Member
    May 8th, 2007
    NH
    2004 GLI
    03-13-2013 06:08 PM #20
    Bumping this thread for an answer, got the p2181 today. Temp is normal, both fans run, heat comes out when I turn heat on. Pump was replaced 10k ago (at 80k) with metal impeller. So its the t-stat or the ECT?
    I will search how to do the ECT, just wanted to know if it could be anything else.
  21. Member Jazzydub's Avatar
    Oct 13th, 2009
    Snohomish WA
    JB 20th 0440, 1987 Audi 4kq, 1998 Yukon, 1969 Datsun 2000
    03-13-2013 06:15 PM #21
    Quote Originally Posted by Parsons View Post
    I'd start with the CTS (cooling temp sensor) especially if it's not a green top one. Both parts are cheap and the CTS is easier to replace. Takes like 10 minutes.
    Kind of a shoddy picture but gives you an idea of it's location.
  22. Member
    May 8th, 2007
    NH
    2004 GLI
    03-14-2013 09:32 PM #22
    I'll take a look at that first. I really don't want to do the T-stat because its a pain in the ass and everything seems to be working fine outside of the CEL.
  23. Member
    Jun 27th, 2012
    South Metro, MN
    '04 Jetta 1.8T
    03-14-2013 10:07 PM #23
    I had this issue today also. I had it happen a year or so ago and was told it was the coolant temp sensor. Had it replaced, light came back on the next day, had it replaced again under warranty, light came on again a few days later. Brought it to a guy I trusted more and had it replaced and it has been off for a year. Came on today on my way home from work after just giving the engine some gas. Got the code cleared from the auto parts store and didn't come back on after driving around. I will have to get the water pump and timing belt soon so maybe that was my issue this time? Stupid generic CEL codes....
  24. Member
    May 8th, 2007
    NH
    2004 GLI
    04-16-2013 06:40 PM #24
    So apparently I've been driving around for a month now with this CEL. I stopped at an acquaintance's house today who has a vagcom, returned p2181, coolant system. So same thing as a generic scanner.
    I guess I'll order an ECT sensor, though it reads normal all the time. My current one IS a green top also.
  25. Member
    May 8th, 2007
    NH
    2004 GLI
    04-22-2013 05:19 PM #25
    Day before new one arrives, CEL goes off on its own...seriously? I suspect it will return.
  26. 04-26-2013 07:39 AM #26
    Guys, I get the same code on my '04 1.8 Jetta.
    Replaced the CTS
    Car does NOT overheat.
    At operating temperature, I turn on the A/C and my fans don't immediately turn on.
    HOWEVER, they do turn on and cycle for about 10-15 seconds at a time then turn back off again.
    Thoughts?
  27. Member engineman98's Avatar
    May 30th, 2008
    Moyock
    2004 24v GLI, 2007 Fahrenheit GTI #975, 1984 rabbit GTI
    04-26-2013 08:02 AM #27
    I have been getting p2181 for months on my jetta changed water pump thermostat and temp sensor. The more research ive done I have found lots of other people with the same issue. I have read a bad coolant mix will cause this also. Mine only gives me problems in the colder months after that it goes away for the summer. I just clear the code and keep driving mine since draining the coolant system and refilling with g12 costs too much imo to fix this little cel.
  28. Member Elvir2's Avatar
    Nov 19th, 2007
    HOTLANTA-thats right i said it.
    04-26-2013 09:54 AM #28
    I got that code on My R32. I only got it when the weather was super cold. Once it warmed up it went away on its own.
    Elvir
    '81 Simple-Build-PIKMEUP-VR6
    '01 Simple-Build-SpeedyVW-V1.8
    '04: .:R32 Daily Driver...Raw Fun?
