Results 1 to 8 of 8
Thread: Where is your headlight cutoff, OR what height is correct?
  1. Member coderedcomputing's Avatar
    Sep 22nd, 2011
    DC Metro Area
    2008 Passat 2.0T TSI; 2005 Scion xB
    05-12-2012 09:02 PM #1
    Wondering about where the headlights should be on the B6. My wife has commented when I'm driving behind her, that she doesn't usually see my headlights, almost as if they are pointed too low.
    Wanted to know if anyone has any info on the proper alignment on the low beams for the B6.
    If you measure your cut-off, and post up this measurement...and your car is lowered, also post how much lower your car is than stock.
    Thanks folks.
    2008 Passat 2.0T TSI - Unitronic Stage 1+ / BSH True Seal Intake Stage 2 / AWE Diverter Valve / 42DD Boost Tap / MKV MFSW with Paddles / Driver Gear Springs & Koni FSD / Euro Spec F/R Turn Signals
    May 8th, 2012
    New York City
    Passat 08 jetta 01 jetta 98 240sx
    05-13-2012 01:55 AM #2
    I would like to know this too, and also know how to do the adjustment I can see one light pointing higher than the other one
    May 10th, 2010
    North Jersey
    08 Passat wagon 2.0T 6MT (current). Past: 02 Golf TDI, Dark Beige 88.5 Camry V6 5MT, AE82 Corolla
    05-13-2012 08:31 PM #3
    www.danielsternlighting.com has good guidelines on setting the aim
    2008 Passat wagon, 2.0T 6MT with mods
    Other Rides:
    - 2013 Cannondale CAADX-6
    - 2010 Specialized Secteur Elite
    - 2009 Specialized Rockhopper Comp 29-er
  4. Member
    May 8th, 2012
    New York City
    05-13-2012 08:36 PM #4
    interesting web page, thank you BsickPassat
    now i just need to know (and maybe you know) how manually/physically adjust the lights on my b6 i just haven't find the right screw, nut, bolt, that needs to be twisted to go up or down
    May 8th, 2012
    New York City
    05-17-2012 08:15 PM #5
    i read most of the recommended blog and i have to say that it indeed have very nice information is very outdated or that is what i think.
    still haven't found the how to adjust the height on my headlights
  6. Member low_passat's Avatar
    Sep 11th, 2010
    Goodyear, AZ
    05-18-2012 12:23 AM #6
    Quote Originally Posted by EVANGELIONHD View Post
    If you have standard halogens there is a hex screw on the back of the housing (see the white hex in the red box)
    (pic stolen from this thread http://forums.vwvortex.com/showthrea...djustment-help)
    2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
  7. Member x9t's Avatar
    Sep 19th, 2005
    Bay Area-CA
    07 Passat 2.0T 6MT/96 Passat GLX VR6/ 87 Scirocco 16V
    05-18-2012 03:52 AM #7
    do you see ok? I would only raise them if your having issues.. you dont want to blind on coming traffic by having them to high.
    From my understanding you need some actual equipment to set them up correctly and follow VW procedures.
    JT
    Passat B6 6MT 2.0TFSI, Spork Pkg, Bixenons, Giac,EVOMS Intake, Neuspeed SS, NS Rear S B, Koni FSD/Eibach Pro kit, Peloquin LSD, VF Mounts, Forge DV and FMIC, 18x9 Wheels,Badgeless Grille, Hidef Rear Bumper/Spoiler/Tips, Votex Side, Abt Front lip..
    Passat B4 5MT GLX VR6. Moddified Intake Box with K&N Filter, Borla Muffler... more to come.
    May 8th, 2012
    New York City
    05-18-2012 08:39 AM #8
    Oooohhh is that one?! I've being adjusting this white plastic thing...
    Actually I ned to lower the right one I can see the light beam reaching further than the left one and when I park pursue the garage door I can se the center points on different heights
    Sent from my DROID2 using Tapatalk
    DO YOU SPEAK DAS AUTO?
