Results 1 to 6 of 6
Thread: Gentex Auto dimming mirror with homelink
    Jun 21st, 2009
    New York
    2012/VW/Golf R
    05-12-2012 11:45 PM #1
    I have been reading up on this installation and I should be installing this tomorrow morning, quick question, when installing the cables to the map light, how do you feed the wires through the headliner. The diy says to pull it down but I couldnt find pics if its actually down alot or just enough to get the wire through. Does the headliner reattach if pulled down too far? This is the one part im not sure on for the installation so any insight or pics of the headliner moved for the wires, would be highly appreciated. Thank you so much
    Current Car - 2012 Rising Blue VW Golf R
    Revo Stage 1
    Old Cars - 2007 CW GTI, 2001 Gold GTI, 92 Eagle Talon
    Sep 28th, 2011
    Texas
    Rising Blue Golf R
    05-13-2012 08:41 AM #2
    You don't have to pull down on the headliner much at all to feed the wires through. It's really easy. My only recommendation would be that, if you can, feed the wires from the map light area down to the mirror. It's easier than feeding the wires in the other direction.
    That said, I wouldn't tap into any wires in the overhead console at all. I do not like tapping into stock wiring where I can avoid it, plus there's no good spot in that area to get a ground. I tried ti ground it where they suggested in the DIY you're probably using, and even dremeled down that screw head to get good metal on metal contact, and u still didn't get a good enough ground. The mirror appeared to work, but the homelink wouldn't program properly. I would suggest doing what I did, which would be ti route the wires to the fuse box, which is actually an easier install. See post 100 in my build thread and let me know if you have any other questions.
    Sent from my iPhone 4S using Tapatalk
    2012 Rising Blue Golf R (Build Thread)
    2012 Night Blue Tiguan SEL w/ Premium Nav
  3. Member Jay07GLI's Avatar
    May 27th, 2007
    Springfield, MA
    2012 Golf R, RB, 4DR, Loaded
    05-13-2012 10:49 AM #3
    ^ This. I have my Audi mirror wired down the A pillar to the fuse box. It is easy
  4. Junior Member Koppey's Avatar
    Mar 15th, 2007
    SW Michigan
    '12 Rising Blue R, '96 Jetta GLX
    05-13-2012 09:10 PM #4
    We did my install by tapping into the wires in the overhead, which as stated before wasn't the easiest thing to do. Then routed them down the A pillar and to the back (I installed a model with a 3.3" display in it for a camera). If you're just doing a normal EC mirror with homelink I'd take everyone else's advice and route it down to the fusebox.
    Nov 7th, 2011
    Marysville, WA
    2012 Golf TDI
    05-14-2012 02:11 AM #5
    I tapped into wires in the map light area.
    I cut the harness off to the correct length and crimped connectors on like the kind on there originally, except I put a spade on the ground and crimped both power wires in a single spade. Two taps and done. Good connections, no problems.
    Adam
    Jun 21st, 2009
    New York
    2012/VW/Golf R
    05-14-2012 08:19 AM #6
    Thanks for the help and suggestions, I ended up running it to the map lights because I am a nervous nelly and the more pieces I have to take off the 100% chance of me making an oops goes up by 10% . I think it came out looking good, and can post pics later. I wasnt able to get the the garage to pair, think it was the supers fault though (will fix this tonight) and I got my work gate to work this morning so it should be good to go . I ended up using a washer with the ground, I dont know if that helped but everything appears to be running good so I am hoping for the best Thanks again
    Revo Stage 1
