Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 35 of 179
Thread: Longevity of A Vehicle...
  1. Member madrussian's Avatar
    Mar 29th, 2003
    Akron, OH
    12 GLI
    05-13-2012 12:38 AM #1
    I was filling up my gf's Jetta tonight, and I got to wondering.
    Does the octane used add or decrease the longevity of a motor in a car? For example, she's a 2.5L so if I put in 93 as opposed to 87 am I going to increase longevity or just pay more for some extra oomph essentially?
    I suppose we can throw the oil debate in here too, how often is too much or too little. She goes the 10k mark, I go by the 5k on mine.
  2. 05-13-2012 12:46 AM #2
    You neither increase the longevity or add an extra oomph by filling up with higher octane gas than your engine recommends.
  3. Member bherman13's Avatar
    Sep 9th, 2010
    The Village of 7,400 Location:___ and the City of 3,100
    MK3 VR6 Jetta Vehicles:___ B4S TDI Passat
    05-13-2012 01:02 AM #3
    These questions usually start a storm of fans from both sides. I imagine longevity is not affected by grade of gas, just quality, which doesn't usually matter because "all gas is the same so the quality is the same". Oil shouldn't go past when it starts to break down, obviously. If you want to know how close to the end off your oil's life you went, send of a sample for analysis.
  4. Member Live-Wire's Avatar
    Jun 9th, 2005
    Guelph Ontario
    2008 BMW 335i
    05-13-2012 01:03 AM #4
    The only advantage to using the higher octane fuel in a car that doesn't recommend or require it is the added detergents which keep the injectors cleaner. Using regular seems to require doing a top end cleaning every couple years, while vehicles running premium don't seem to need it.
    The cost of running the more expensive fuel would outweigh the cost of Seafoam every year tho...
    More octane actually has slightly less power per unit measure... It only improves performance in a high compression motor which would knock if running at peak tune on regular.
  5. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 01:09 AM #5
    Quote Originally Posted by thegolfer18 View Post
    You neither se the longevity or add an extra oomph by filling up with higher octane gas than your engine recommends.
    Actually you do add more power, not much, but power goes up with higher octane. Why do you think that people would use 100 Octane when they race?
    There are quite a few examples out there where higher or lower octanes would increase or decrease power respectively.
    Longevity, as long as you use some good fuels, should be OK.
  6. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 01:19 AM #6
    Quote Originally Posted by Live-Wire View Post
    It is not power, is energy, they are related, but not the same thing. And when a car is tuned to run on 87, like the Camry, but because of advanced engine management, it will have power increase with 91-93.
    The engine was actually designed to run 91-93, but due to the economy and the advanced Engine Management Controls Systems, it can run 87 just fine without spark knocking. Hell my GLI with a Stage II 93 tune can run 87 and not spark knock.
  7. 05-13-2012 01:26 AM #7
    The gas grade best for a vehicle is what's described in the owner's manual and behind the gas door. Nothing more, nothing less.
    If it says "87 octane"...use 87 octane.
    If it says "premium fuel only"...use 91 or higher.
    If it says "premium fuel recommended"...check forums to see what gives the best power and mileage.
    Of course, there are certain folks that just don't get it...like my uncle who will lease a BMW for $800/month but thinks the required premium fuel is "too expensive", since "I'm not bringing it to a racetrack."
    Oil changes - once again, follow the manual, unless the car has some known problem/TSB with the recommended intervals.
    Of course, if you have an engine like a Chrysler 2.7, you're S.O.L no matter how often you change the oil and what type it is.
  8. 05-13-2012 02:05 AM #8
    Quote Originally Posted by B3sat16v View Post
    Which is why I said higher than your engine recommends
  9. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 03:11 AM #9
    Camry recommends 87 on the new V6. With 87 it develops 268HP, with 91 or 93 anywhere from 272 to 275 HP. The older 300 M also recommended 87, but the manual would tell you that with Premium higher HP would be achieved. Again, not much, but there is a gain.
  10. Senior Member SSLByron's Avatar
    Jul 29th, 2004
    Annapolis, MD
    05-13-2012 03:33 AM #10
    There's a gain if the car is programmed to take advantage of it. Not all cars are/do.
    And are you sure they "recommend" 87 on the Camry V6? Many cars have a "required" octane and a "recommended" octane, so you'll know right off the bat that the ECU is adaptive.
    http://www.speedsportlife.com press vehicle(s) this week: None.
  11. Member zhenya00's Avatar
    Aug 7th, 2003
    Ithaca, NY
    05-13-2012 03:38 AM #11
    Not a true statement unless qualified by 'in certain engines.' Using a higher octane than your motor was designed for is a waste of money, and in some cases, can even cause a drop in performance or economy.
    There is no difference in the amount of 'energy' or 'power' stored in different grades of gas. Octane is simply a measurement of how resistant the fuel is to burn. Higher octane may be compressed more than lower octane without pre-igniting; allowing for a design with a higher compression ratio. More compression means a bigger bang meaning more power. If the motor is built with a compression ratio suitable for 87, running 93 is just a waste of money and efficiency.
    1987 Mercedes 190E 16v Cosworth
    1997 Volvo 855 T5
    2010 Volvo XC90
  12. Senior Member SSLByron's Avatar
    Jul 29th, 2004
    Annapolis, MD
    05-13-2012 03:42 AM #12
    Quote Originally Posted by zhenya00 View Post
    Bingo. So to answer this:
    Race gas is higher-octane because race engines tend to have higher compression ratios and more aggressive timing.
    Some owners, especially those running more aggressive-than-stock ECU maps, will use a higher octane fuel when they track their cars because they don't want to risk detonation due to the heat generated by extended high-RPM running. They're not looking for power. They're looking for a safety cushion.
  13. Member mac dre's Avatar
    Jan 20th, 2008
    St. Louis/Columbia, MO
    318ti
    05-13-2012 11:42 AM #13
    Depends on the motor, while the VW 2.5 motor runs on 87. If you put 91 in it consistently, the ECU will adapt and provide a minor HP increase 5-10HP I think was what I last saw.
    Quote Originally Posted by efrie View Post
    I told him the car wasn't going to win any races, to which he responded was "chill".
  14. 05-13-2012 11:59 AM #14
    Quote Originally Posted by mac dre View Post
    No, just... no.
  15. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 01:17 PM #15
    And you are wrong. The lower the octane the higher the energy content; however, since you cannot run higher compression, and cannot increase the thermodynamic efficiency, it does not make as much power.
  16. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 01:19 PM #16
    Quote Originally Posted by PassSedanGLX View Post
    Have any of you have studied engines, like graduate level classes and applied it and then tested them?
  17. Member TM87's Avatar
    Dec 30th, 2008
    Windsor CT
    VW
    05-13-2012 01:28 PM #17
    You are basically wasting moneyand in some cases can decrease mpgs. Your ecu,timing and air to fuel ratio is preprogrammed for 87. That's the best fuel grade to use.
    I have ecu that can switch between 91 and 93 depending on use.
  18. Senior Member Aonarch's Avatar
    Dec 4th, 2006
    SYDNEY, NEW SOUTH WALES, AUSTRALIA, OCEANIA, AKA UPSIDE-DOWN LAND
    B6 Variant 3.6L VR6 4Motion | E30 325e | MKVI Golf 2.5L | Versys 650
    05-13-2012 01:38 PM #18
    President @ ARD
  19. Member SGLoki's Avatar
    Dec 12th, 2004
    The Ham
    88 fox RIP 86 jetta RIP 81 rabbit RIP, 1984 GTI RIP, 03Ranger RIP, (03 Legacy, 03 Allroad, 86 Jetta)
    05-13-2012 02:35 PM #19
    Higher octane gas detonates less readily, it is not a huge benefit (if any) in stock vehicles. The reason a vehicle needs higher octane ratings is to reduce predetonation that can result from higher compression ratios.
    If you increase the compression ratio of an engine it stands to reason you should also increase the octane IF you suffer pinging or pre-det. IF not, it's just a waste of money.
    As someone else said, gasoline quality has more to do with longevity. Save the extra $ to put on routine maintenance, baby the car, and don't drive it over 55mph if you want longevity.
    1% defined: Lone wolf, no club. Duct tape it yourself. It is broken down 1% of the time, and work is always 1% completed.
    2% defined: I'm too old to drive broken sh*t and VW people are cool. DBVW!
    Quote Originally Posted by nsindel View Post
    May I introduce Senor SGLoki -
    the man, the myth, the slamdancer...
  20. Member mac dre's Avatar
    Jan 20th, 2008
    318ti
    05-13-2012 04:16 PM #20
    Quote Originally Posted by Grey Mouser View Post
    No, just... no.
    http://www.europeancarweb.com/tech/p...n/viewall.html
    see ya.
  21. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 04:29 PM #21
    Quote Originally Posted by SGLoki View Post
    All of you do a bunch of typing without actual back up. Have any of you done a graduate level engine studies?
  22. 05-13-2012 04:54 PM #22
    Enlighten us plebeians who have not done any graduate level engine studies please
  23. 05-13-2012 04:54 PM #23
    This is an exception, not the rule. Most cars don't do better on fuel they aren't designed for.
  24. Member mac dre's Avatar
    Jan 20th, 2008
    318ti
    05-13-2012 05:03 PM #24
    Right, which is exactly why I said "Depends on the motor"
  25. Member dirtygmc's Avatar
    Apr 9th, 2009
    CT
    09 Jetta TDI, 98 GMC K1500, 80 Honda CB750F
    05-13-2012 05:09 PM #25
    Where are your back up references?
    Yeah, the lower octanes do have higher BTU/energy ratings, but a 10k BTU variance is negligible for people outside of a dyno shop. The primary reason for higher octanes is to run higher compression, which do make a considerable difference. ECU allowances aside, it does nothing noticeable for real life, seat of the pants power or engine longevity.
  26. Member Subie J's Avatar
    Dec 16th, 2009
    Pacific Northwest
    05-13-2012 05:21 PM #26
    I put c16 in my prius once, I pulled on liter bikes all day long.
  27. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 05:29 PM #27
    Go take a course yourself. I am not here to quote or reference my books.
    Most modern engine can run multiple octanes. These days they will run 87 and the ECU will adapt to 93 and add a bit of power by changing timing etc etc etc.. This is not 80s, or the 90s even.
  28. 05-13-2012 05:31 PM #28
    Quote Originally Posted by Subie J View Post
    But did you chirp third?
  29. Member
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    05-13-2012 05:35 PM #29
    This.
    It does increase the longevity of your joints though. A lighter wallet does that.
    Quote Originally Posted by apizzaparty View Post
    never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
  30. Member
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    05-13-2012 05:41 PM #30
    That might be the case, but I'll opt for higher octane to offset the higher temperatures seen at the track that make predetonation more likely. Very few factory equipped cars can handle the very high temperatures of track duty, so little things like this help.
  31. 05-13-2012 06:24 PM #31
    If one runs too low of an octane, and your engine has significant predetonation, your longevity may be hindered.
    Outside of that, the answer is 'it depends'. Along with a few engine "tweaks", my old GTI went from ~130wbhp at 91 to over 325wbhp on MS100.
    Speaking of which, what "graduate level engine studies" would be best to understand cavitation in the fuel flow when operating at around 6500 psia?
    "You'll have to answer to the Coca-Cola company."
  32. 05-13-2012 06:49 PM #32
    ... Only appropriate if the engine is built to use that fuel (high compression, etc) and in that case, the engine cannot run (for very long) on lower octane fuel.
    People not involved in racing may not grasp that there is no such thing as "race gas". There are many, MANY customized fuels available for various racing applications but there is no single thing called "race gas".
    Some racing fuels such as VP MR12 are only 87 octane. It's meant for getting more power out of production or nearly-stock engines with near-stock compression ratio.
    On the other hand, VP C12 is 108 octane and is meant for compression ratios up to 15:1 ...
  33. Member Spinnaker's Avatar
    Jul 12th, 2007
    SFO
    05 1.8T; 04VTek800 (sold); 08Speed3
    05-13-2012 07:17 PM #33
    Quote Originally Posted by JLJetta View Post
    ~130wbhp at 91 to over 325wbhp :
    Wheel Brake Horsepower?
  34. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    05-13-2012 07:46 PM #34
    Quote Originally Posted by GoFaster View Post
    What I realize is that I should have been more specific. Modern engines with high CR are capable of running 87 and 91-93 due to their advanced engine management systems. The issue here is that with the gas prices as high as they are companies are now saying 87 or higher in their manuals. My Lexus says 87 can be used in the car, but for maximum performance 91 or higher is recommended. I have already stated all of this. I am not sure why this does not pass some of you knuckle heads. There are many cars out there with high CR, that will benefit from higher octane. And as for the "racing fuel" a car with a tune can run a more aggressive timing providing slight increase in performance. Hell with with just a modern ECU it will do this.
  35. Member
    Sep 2nd, 2001
    Mazda2, Mr2
    05-13-2012 07:59 PM #35
    Here is one possible scenario where using premium could prolong the life of your car : Older cars not meant to run ethanol could actually benefit from running on premium that has less or no ethanol in it.
