More than likely I'd guess that your window was replaced and the installer never put the connector back on OR it had the wrong one and they said eff it and couldn't connect it. But that wire coming off the window is def the defroster connector, and I'd assume that black thing is where it goes. You can see that they are not even close to being the same style so thats why I think it was replaced before. Check the DOT number on the glass and that will tell the tale of OEM or aftermarket...
