#72
#73
Soundaktor delete complete! & what a difference it makes!!! I couldn't be happier having true engine sound and no unnecessary fake vibrations.
One thing that I would recommend for anyone looking to do the simple unplug technique as I just did is to actually remove the two 10mm bolts that hold down the unit. This makes it a lot easier to get at the clip on the back side. It also make more room for wrapping the exposed end with a plastic baggie or balloon and cinching it off.![]()
#74
Yanked!!! Soundaktor!!! OUT!!! WTF was the point of that thing? Night and day difference. My R's cool went down a peg till I found out that a Mustang GT has a Sound tube like the GTI.![]()
#75
The soundaktor is an electronic controlled unit so we should be able to disable it via VCDS / VAG-COM. Why haven't anyone figured it out yet?!
I'll pay a finders fee to the one who first get this done!![]()
#76
I am doing my APR Stage 2+ this week and told the shop to get rid of this while they were removing the ECU. My question is... do you guys think its better to just unplug it in case I ever want to put the car back to as close to stock as possible? Or should I remove the dead weight?
#77
I think I'll have to drive the car more to know the difference. What am I looking for exactly, and why should I remove it?![]()
Follow my Project:365 on Twitter!
'CPTNSLW' 2013 Golf R
My friend's Jetta has automatic roll-down windows; activated at 61kph. Only Volkswagen.![]()
#78
They shouldn't have to remove your ECU... If they tell you they have to, they are wrong. If you are going 2+, you will want to hear your exhaust noises and they will cover up the soundaktor anyway so just remove the whole thing.
Info is there. Search "soundaktor" You would only remove it completely if you are happy with the lessened fake sounds and know you don't want to ever hear it again. If you're not sure, just unplug it.
#79
#80
#82
#83
No removal necessary, just flashed through the port.
2012 Deep Black Pearl Golf [R]|APR Stage 1|Soundaktor unplug|OEM tinted LED tails|H2Sport Roller Follower|EVOMS engine cover|EVOMS V-Flow Intake
#84
The shop is going to call APR but they were under the understanding that all 2012's were not a direct Port and some internal work on the ECU was needed.
#85
#86
#87
This is probably blasphemous...but I love all the R sounds, including the soundaktor. I guess VW built 'em for people like me. Sorry guys![]()
#88
Well, I just did it, and I must say it was more difficult than what I expected. I only did the controller, but the shrouding did not bend up very much at all. It made for tight quarters.
Secondly, for the folks that used the balloon trick, how the hell did you fit a balloon over that massive connector? I even tried cutting the little o-ring off of the end of it to cut down on the elasticity, but no go. The aforementioned tight quarters certainly didn't help either. My connector is unprotected right now, which has me a bit nervous. Any suggestions?
#89
Just did this too. Removed the controller(I guess/on pass side), wrapped it in duct tape and zip-tied it to the bracket it sat on. It shouldn't go anywhere or get wet at all.![]()
even at your best as a man, you couldn't equal half of me - Sully Erna/Godsmack
2012 Deep Black Pearl "R" w/Bilstein PSS10's; APR Stage 2+ w/APR-Carbonio intake; APR HPFP; APR TBE; Neuspeed HI-FLO TOP; 42DD shifter bushings; TyrolSport Solid Shifter Bracket Bushings...
#90
#91
I just went through this with my GLI. I was having this ridiculous rattle at higher RPMs when driving spiritedly. I figured it HAD to be the aktor since I already had the wastegate clip installed. So this morning before work I unplugged it and what a difference. The driving experience is enhances 100% and although I may not have the same motor and sound as the R, it is still a much nicer tone.
When I get home I'll be covered the connector in tape and zip tying it to the unit, that way I can put it back if/when I sell the car. No sense in removing it entirely since it's hidden anyways.
#92
I just pulled my Soundaktor controller out of my 2012 R. I can't say it sounds better or quieter. I hear other noises now, like the tick of the injectors and more wine from something (turbo maybe). I'm not putting it back on, but if I had that half hour of my life back I would not bother taking it off again.
Many people complained of a buzzing with the Soundaktor. I was wondering if I just was not hearing it. I had no buzzing with the Soundaktor - at least nothing that I notice gone now. Maybe theirs weren't installed or working properly.
I wonder if the Soundaktor was designed to be a noise/vibration cancellation device. I know from past experience (think "silent service") where devices very similar to this are used to quiet radiated noises.
#93
I attempted to do this yesterday, but I ran into difficulty lifting the plastic cover after I peeled back the weather strip. I don't know where the clips are that hold it in place and didn't want to break it. With it in place, I could open the clip and even pull the cover off of the wire harness, but I had no leverage to pull the harness out of the controller.
I have done a few searches and I am unable to find info on this. Can someone advise how I remove the plastic cover without damaging it?
2013 VW Golf R (Candy White, 2-Door, Loaded, Stock)
#94
To remove the tray completely you have to remove the wiper arms. To just unplug it you don't, this is how I did mine. Yes the plug is hard to get to. I used one hand to pull on the plug and locking clip thing on the back of it. Then with the other hand I used a long socket extension to help push the plug from the front. Yes it tight and might take some time. And you'll probably have others tell you they reached right in and pulled it off in 2mins...
Golf R CSG 4dr Nav/Sunroof
#95
I really like the idea of using a long socket extension! I'll try that tonight and hopefully I can get it disconnected. If/when I do the delete, I'll need to know how the tray is secured, because it looks like it should be able to be lifted without removing the wipers.
#96
You only need to remove the wipers if you want to remove the rain tray which you'll have to do if you want to remove all components of the sound maker. But to just unplug it all you need todo is remove the weather striping on the passenger side in front of the rain tray and lift...
#97
Well, I made my second attempt at disconnecting the Soundaktor from its controller. I am able to open the retention clip thingy, but even with a socket extension, I am unable to get proper leverage in such a tight space to unplug the harness. I got it to budge maybe 1mm on one side and that's it. It is in there pretty good.
I have done numerous searches and I cannot find the information I need on safely removing the rain tray. A visual check says that I should at the very least be able to remove it and lift it out of the way by a couple of inches even with the wipers still attached. I am not very mechanically inclined and am very wary of breaking anything, especially plastic.
Also, has anyone actually had a dealer disconnect or remove the Soundaktor?
#99
I tried the Soundaktor delete. Love the engine and turbo sound without "auto tune". Anyway when I first disconnected the harness before I was sure that I would leave it disconnected, I used blue painters tape as temporary protection. When I decided that I would not be re-connecting it, I was concerned about the tape solution. I wanted to protect against moisture and shorts but I did not want the heat to degrade the tape or cause it to leach adhesive residue. I visited a local electronics supply store. They suggested silicone x-treme tape. It only adheres to itself and works in high temperature environments. See pics. To get the rain tray off enough to wrap the connector, I removed the passenger side wiper. Rain tray removal was difficult. It helped to find a looser part by probing and pushing from underneath. Once you get a place where it pops up, it is much easier. Putting it back in place required some effort and a plastic putty knife (no metal!) in one section where it refused to pop back into the groove against the windshield.
#100
Just unplugged by Soundaktor and am very pleased with the quieter cabin. I have not wrapped any connections yet as I wanted to see if this made a difference but, once I have some more free time, I will tape up the connections.
#101
Came across this last night -- just for ****s and grins I gave it a try and could instantly tell a difference with noise inside the cabin. Noticed at idle in the driveway I could hear the intake (stock) much more than before.
Too bad they didn't omit this on the R and give us any one of the lovely features available anywhere else in the world.![]()
I just put a single piece of electrical tape over the female connectors.. I'm really temped to just get a condom and a zip tie since no one will ever see this.. I mean a ziplock bag would probably work too but what fun is that?![]()
#102
2012 CSG 2 DR NAV/SR | Tuning: 4 Seasons | Paint: Dave the Painter | APR STG 2+ (w/program switching) | STG 3ish Clutch | HPA Gen 4 Switchable Stock/Race/Eco Controller | Autotech HPFP | Billy Boat Down Pipe | Volant Golf R intake | Neuspeed short shifter | Neuspeed Torque Arm Insert | Badge-less grill + notch fill/paint | Some rad stickers | Gloss Black Stock Wheels | VWR Sport Springs | ESC hack | ("Build" Thread) | #731 ( :
#103
#104
#105
They're surprisingly resilient.
Two rounds of 9mm on the right, one round of .40 on the left.
