Results 1 to 9 of 9
Thread: Help with Part number for steering wheel swap
  1. 05-14-2012 09:40 AM #1
    Will this steering wheel work with my jetta? I believe i read somewhere that golf and jetta steering wheels are different.
    http://www.ebay.com/itm/VW-MK5-MK6-G...#ht_2534wt_840
  2. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    05-14-2012 10:00 AM #2
    I've seen scirocco wheels in the Jett and mk6 wheels in an mk5 so I don't see why not
    SteveMKVI JettaMy Car Activate Full MFD MK6 Jetta DIY
  3. 05-14-2012 10:09 AM #3
    Yeah i had already bought it, then i started reading there were similar but different steering wheels out there, and i didnt want to get the wrong one.
  4. Member CDN TDI's Avatar
    Jan 25th, 2012
    Canada
    2011 TDI Jetta 6MT, 1991 Turbo Diesel Jetta 5MT
    05-14-2012 10:18 AM #4
    Quote Originally Posted by ME_GU5TA View Post
    Post back here and let us know if it works, so we have a record of what's compatible.
  5. Member Rpc07's Avatar
    May 17th, 2010
    Long island
    Mk6 Jetta
    05-14-2012 12:08 PM #5
    It will fit, i have the same wheel in my car without the multi function buttons.
  6. Member Mo_Focus's Avatar
    Oct 9th, 2005
    2010 Golf Highline TDI DSG, 2011 Jetta Highline TDI
    05-14-2012 02:37 PM #6
    All the wheels are the same. Airbags might be different. So do your homework making sure the airbag will fit yours. Also some have different airbag harness.
    10 VW Golf Highline DSG TDI- wife's , 11 VW Jetta Highline 6spd TDI mine!
  7. Junior Member Antonio Freire's Avatar
    Dec 27th, 2011
    Recife - Brazil
    2011 VW Jetta Comfortline 2.0 Tiptronic
    05-15-2012 12:44 AM #7
    It will fit. However, to operate the multi-function buttons and paddles shifters, you will also have to swap the following items:
    Elec. Modul - 5K0953569H or 5K0953569B
    http://keffervwparts.com/parts/2011/...icleid=1447457
    Multifunction switch - 5K0953502M9B9 or 5K0953502C9B9
    And for this steering wheel you will have to use the steering wheel without buttons airbag, is the only compatible, but you'll have to replace the airbag wire harness for this here:
    Harness - 5K0971584A
    Jetta 2.0 Comfortline Tiptronic 2011/11 Black - Cornsilk Beige - Sunroof
    Cup Kit H&R Komfort, Passat CC wheels 18" x 8" ET 45 - Tires Pirelli Dragon 235/40 R18, 5k0419091ASASZ, 5K4959857XSH, 1K1064206, 5C6071303, 3C0035507Q, 5K0853688AFXC, 5C6071360, 3" x 7" Stainless Steel, Slant Bolt-On Exhaust Tip
    Pics: http://clubedojetta.forumeiros.com/t...-parte-3#33220
  8. Member jettsy's Avatar
    Mar 28th, 2011
    Orlando, FL
    2011 Jetta
    05-15-2012 05:56 AM #8
    It will always be cheapest to just buy a complete wheel than piece together
    Oct 25th, 2011
    Fairfield County, CT
    2011 Jetta S
    05-15-2012 09:50 AM #9
    Will this steering wheel work with my jetta? I believe i read somewhere that golf and jetta steering wheels are different. GTI's are golf's, right?!
    That is essentially another version of the Golf R wheel
