Ground Control sells one, but it's a solid mount (no rubber isolator) so it will likely add a lot of ride harshness. Whether or not that would toelrable is up to you. The Mk IV strut tower doesn't allow for much clearance for adjustment, so to get the most camber a full coil-over is required (otherwise the spring can hit the sheet metal).
Another advantage of going to TSMF is that allows for going to an aftermarket LCA or the HSport spindle, which TSP rules do not.
Send a message to DIAF. He and a few others put in a lot of time putting together a solid SP suspension package for the Mk IV. I've seen and ridden in the results and it's pretty amazing. Bombardius is currently trying to sell the car it's now with ('05 GTI). I would buy it if I wasn't stuck with too many cars, not enough room and a bunch of pending house repairs.
