Also as for oil? What do you guys use for break in? After break in? I just bought half a case of Brad Penn 30 weight break in oil, I have read it has high zinc that older engines require and coats the internal parts better. I think I'm going with 30w brad penn oil after the break in. By the way the climate I'm in is So Cal.
