Results 1 to 7 of 7
Thread: Removing steering column - what's this cable (pic)?
  1. n00b
    May 13th, 2012
    Northern CA
    VW Cabrio 2001, VW Bus 1979
    05-14-2012 03:45 PM #1
    I am replacing my ignition switch, following the DIY here where you remove the steering column.
    I am almost done taking out the steering column, but there is one cable holding it back. It comes from where you insert the key. There is no connector to undo, so I'm stuck. I have no idea how to pull it out. Its a 2001 Cabrio, Manual transmission (basically similar to a mk3)
    Any ideas?
  2. 05-14-2012 04:04 PM #2
    If it's an auto, I think it's the shift lock cable. You should be able to remove it. My auto had one but it didn't look like that. You could see the end of the cable instead of that black connector and just disconnect it. It was like a little ball socket that popped out.
  3. n00b
    May 13th, 2012
    Northern CA
    05-14-2012 04:10 PM #3
    Its a manual transmission (just edited the post above)
  4. Senior Member reynolds9000's Avatar
    Oct 16th, 2003
    Chattanooga, TN
    MK3 VR6's
    05-14-2012 04:13 PM #4
    It must connect to something. Can you detach it from the colum itself?
    SoWo
    BHC- It's not about who we are, it's just how we feel.
    Roll Tide.
  5. 05-14-2012 04:14 PM #5
    If it's manual, I'm not sure...but this is what mine looked like and it just pops off:
  6. n00b
    May 13th, 2012
    Northern CA
    05-14-2012 05:01 PM #6
    Quote Originally Posted by reynolds9000 View Post
    It doesn't look like I can. The cable goes into the body of the car. This is a better picture:
  7. n00b
    May 13th, 2012
    Northern CA
    05-15-2012 02:58 AM #7
    Its the immobilizer housing. Its a pain in the ass to take off - would involve drilling a hole in the key barrel, or following cable through body to the immobilzer gizmo. This is only on the cabrio.
    So I put it back together again and am going to attempt to remove the steering wheel using the puller method tomorrow. Fingers crossed
    Mat
