Results 1 to 22 of 22
Thread: Megasquirt V3 on OBDII VR6
  1. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    95 4dr Golf 20V, 02 TT 225, 99 Rodeo, 85 MR2, 05 S40 2.5T AWD
    05-14-2012 07:24 PM #1
    Hi,
    I have never done a Megasquirt install before. I am hoping for a little help with the wiring. This is what I have so far. Does it look right? The areas with the ???? on it need confirmation. Thank you for taking the time to help...
    MS ECU pinout////////// Motrinic ECU
    2 VR (-) sensor ////////// 68 (pin 2 of crank sensor)
    3 tach////////// ??22?? (inst. cluster)
    4 spr2 ////////// ?????
    5 spr3////////// ?????
    6 spr4////////// ?????
    7-11 grounds//////////
    19 ground//////////
    20 air temp sensor////////// 36(+ air temp sensor)
    21 coolant temp////////// 14(pin 1 temp coolant temp sensor)
    22 throttle position signal////////// 40 (pin 5 of throttle body)
    23 O2 sensor (signal)////////// 20 (pin 4 of O2 harness plug)
    24 VR(+) sensor////////// 67 (pin 1 of crank sensor)
    25 ignition coil 1,6///////// ??8?? (pin 2 of coil)
    26 Throttle position sensor(+)/////////41(pin 4 of throttle body)
    27 ignition coil 2,5///////// ??52?? (pin 4 of coil)
    28 87 of main relay///////// 23 (+ pcv)
    29 ignition coil 3,4///////// ??60?? (pin 3 of coil)
    30 idle valve///////// ??53?? (pin 2 of throttle body)
    31 ground////////////
    32 injectors 1,2,3///////// ??3,24,26?? (injectors 5,1,3)
    33 injectors 1,2,3///////// ??3,24,26?? (injectors 5,1,3)
    34 injectors 4,5,6///////// ??2,4,25?? (injectors 4,6,2)
    35 injectors 4,5,6///////// ??2,4,25?? (injectors 4,6,2)
    36 ground///////////
    37 fuel pump (85 on relay)///////// 6
    Thank you,
    Larry
  2. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-21-2012 04:41 PM #2
    Am I asking this the wrong way, or in the wrong place? Should I form it in a different way?
    Thanks,
    Larry
  3. 05-21-2012 05:31 PM #3
    you came the the correct place. needavr6 knows more about this.
    I need to find my excel file for my pin out that, paul did.
    Racing Improves the breed..
    "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
    CrossroadsLI
    MY ALL MOTOR BUILD THREAD
  4. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-24-2012 11:41 PM #4
    fourthchirpin
    Do you think he would mind if I asked him directly? Or sent him a link to this thread?
    Thanks,
    Larry
  5. 05-25-2012 12:21 AM #5
    need_a_vr6 is his sn on here. heres the megasquirt genius around here. Iam sure his beeper will go off soon at this post
    CrossroadsLI
  6. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    05-25-2012 01:33 AM #6
    Do it the mans way and just run an entirely new harness But yes Paul (need_a_vr6) and Jeff (prof315) are the 2 rockstars here.
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  7. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    05-25-2012 06:40 AM #7
    Let me see if I can dig up the notes on the OBD1 VR install I did (we cut the 68 pin Motronic connector off the factory harness and pinned it to a DB37). At a glance it looks like there are some things not quite right.
    2 questions though, is this a v3.0 or v3.57 mainboard? and what mods were done to it and what pins on the DB37 do they ( the mods ) go to?
    The Professor
    Melbourne, FL
    92 Corrado OBD2 ABA Powered by MS3Pro
    M & L EFI Performance
    Sandy Linfert 11/4/1991 - 5/13/2013
  8. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-25-2012 12:13 PM #8
    Yesterday 09:33 PMSirSpectre
    This is for a friend. He already shaved the bay and extended the harness through the front rail. If I can confirm the pin out connections. I can do it either way, use part of his extended harness or run an entire new setup. He was specific on what the final product should look like and we will use that info to decide what way it will be wired in the end. His car his way....
    Thanks again.
    Larry
  9. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-25-2012 12:46 PM #9
    This ECU was built by a company called K&P performance. My friend purchased this from someone else. So I do not know how it was set up other than the diagram that came along with it.
    Thanks!
    Larry
  10. 05-25-2012 06:40 PM #10
    Quote Originally Posted by Larry Horowitz View Post
    LOL
    CrossroadsLI
  11. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    05-25-2012 08:34 PM #11
    Almost definitely built for a direct spark 4cyl. What serial number is on the bottom?
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  12. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-25-2012 09:02 PM #12
    need_a_VR6
    The schematic shows 6 coil outputs and 6 injectors. What would lead you to say that? The only thing that I could guess that would be a serial # is on the bottom of the box. It is K&P 2011073. Also on the underside of the upper cover it shows K&P 2011092.
    Thanks for the help!
    Larry
  13. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    05-25-2012 09:55 PM #13
    I must have post modded for 3 bips, as I dont do it that way generally.
    I will try and post up stock ecu pin numbers and some ecu details this weekend.
    -Paul
  14. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-25-2012 10:09 PM #14
    need_a_VR6
    Holy crap, I am stupid. I just put the names together.....
    Thank you VERY much,
    Larry
  15. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    05-30-2012 04:21 PM #15
    Quote Originally Posted by need_a_VR6 View Post
    I am sure you are very busy. Were you able to look back and find anything?
    Thank you,
    Larry
  16. 06-05-2012 10:46 PM #16
    I bought the assembled ecu from Paul back in early 11.
    The car is now in Larry's hands and he is finishing it for me.
    Thanks for your help guys.
  17. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    06-27-2012 01:04 PM #17
    Hi again here is a revamped list. Again any help would be great! Thanks.
    DB37 pins...........................................OBD 2 T68
    2) VR sensor (-)...................................68
    3) tach.............................................. ..22
    7-11) grounds
    19)grounds........................................ .TPS,IAT,CLT (t42/26)
    20)air temp signal................................36
    21)coolant temp signal (+)....................14
    22)throttle position signal......................40
    23)O2 sensor signal..............................20
    24)VR (+) sensor.................................67
    25)ign coil 1,6......................................pin on 04 dodge 3.3 coil
    26)throttle position (12v).......................41
    27)ign coil 2,5......................................pin on 04 dodge 3.3 coil
    28)87 on main relay..............................23
    29)ign coil 3,4.......................................pin on 04 dodge 3.3 coil
    30)idle valve.........................................???? ????????????
    31) ground
    32)inj 1,2,3..........................................3,2 4,26
    33)inj 1,2,3..........................................3,2 4,26
    34)inj 4,5,6..........................................2,4 ,25
    35)inj 4,5,6..........................................2,4 ,25
    36) ground
    37)fuel pump relay 85...........................6
  18. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-27-2012 05:38 PM #18
    27/53 for the idle valve. I think 27 is 12v feed but dont quote me on that.
    -Paul
  19. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    06-27-2012 06:27 PM #19
    Okay that is what I had had. pin 53 went to pin 2 of the TB. So It needs 12V? It was screwing me up calling it a idle valve But there was nothing closing and opening to outside air.
    Does everything else sound correct?
    Thanks again,
    Larry
  20. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    06-27-2012 06:35 PM #20
    looks like you are right. 27 (pin1) and 53 (pin2) of the TB motor
    On the schematic it shows an out board idle valve that is getting power from the main relay location 87 along with pin 28 of the DB37. So this is where I get lost. Do I just hook T68/53 to DB30. Or is there something else that is needed that I am not understanding?
  21. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    06-27-2012 09:55 PM #21
    Yes 53 would be fidle/30 and 27 would just use key on, or fuel pump triggered power.
    -Paul
  22. Member Larry Horowitz's Avatar
    Dec 9th, 2002
    Ventura, Ca
    06-28-2012 12:22 PM #22
    7-11) grounds
    30)idle valve.........................................53
    31) ground
    36) ground
    There, that should be everthing. The plan is to use the existing tucked harness and cutting the wires from the hidden stock ecu.
    Thanks,
    Larry
