Results 1 to 4 of 4
Thread: help! blew engine after oil pan blew
  1. 05-14-2012 08:30 PM #1
    Just like the title says i blew a hole in my jettas oil pan... my mechanic replaces it and adds oil then tries to start car and won't turn over even after few attempts. he found medal shavings in the old oil pan and did a camera check off the timing chain and found more metal pieces. he says he could start replacing parts but it would be easier/cheaper to find a new motor. anyone have the similar scenario? or what could be my options.... i would like to put a 1.8t or vr6 in but i don't know what else id have to do and make it work without engine light being on..thanks for the help
  2. Member Glumrug's Avatar
    Apr 15th, 2012
    Ann Arbor, MI
    1998 VW Cabrio; 2004 Honda S2000
    05-14-2012 10:26 PM #2
    Getting a different engine is the right call.
    With metal shavings all over you would be looking at a complete rebuild, and for an engine that in that shape the cost would be in the thousands.
    Even if you were able to completely rebuild the engine yourself, and had access to a machine shop the cost of parts would would far exceed what you can find a used engine for.
  3. 05-14-2012 11:25 PM #3
    sucks for me but thanks for the input
  4. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    Eight valve like WHOA.
    05-15-2012 03:27 AM #4
    So how long did you run the motor after the you gouged a hole in the pan?
    It's Timmy with mmmmMojo, i have returned
    8VALVETURBO - Sorting the kinks out.
