Results 1 to 11 of 11
Thread: FS: built 2.0, ATP manifold, GT3071R
    Apr 20th, 2010
    York, PA
    BT 2000 A4
    05-14-2012 10:28 PM #1
    basically wrapped the car around a pole, now everythings for sale
    built motor:
    ATW head
    supertech stainless intake valves, iconel exhaust valves, tripple groove
    titanium retainers
    dual exhaust springs
    stock cams
    ATW block
    bored/stroked 2.0
    ABA crank
    DM rods
    mahle pistons, 83mm 9.25:1 CR
    asking price for engine $7000, has roughly 10k miles
    turbo, GT3071rWG welded to be externally gated, would prefer to sell turbo manifold and WG all together. ATP manifold, tial 38mm WG, adapter elbow WELDED to manifold to ensure the PITA bolts never came loose/broke again, WG still detaches. asking $1000 for all 3, turbo has roughly 15k on it
    clutch:
    clutchmasters fx400 240mm 6-puck with steel single mass flywheel, roughly 10k. asking $700
    also have maestro 7, stern mounts, podi gauge etc for sale. will be pulled everything out in next few weeks, just looking for interest
    build thread: forums.vwvortex.com/showthread.php?5420604-the-on-going-casa-build-thread
  2. 05-15-2012 01:02 PM #2
    FWD or quattro? got exhaust??
    Apr 20th, 2010
    York, PA
    BT 2000 A4
    05-15-2012 03:51 PM #3
    Quattro. Its got neuspeed on it, but you don't want it, I've always had problems with it
    Aug 16th, 2011
    Groton, CT
    99 Audi A4 1.8TQM; 98 Audi A4 1.8TQM (Part-Out)
    05-15-2012 04:50 PM #4
    transmission mounts?
    Apr 20th, 2010
    York, PA
    BT 2000 A4
    05-15-2012 09:35 PM #5
    stern's, both have less than 100 miles on them
  6. 05-15-2012 11:34 PM #6
    Curious how you came up with the 7k number for the engine that seems really high even including machine work?
    Sent from my iPad using Tapatalk HD
  7. Member Jordan80's Avatar
    Sep 8th, 2010
    Saratoga, NY
    00 Nogaro S4
    05-15-2012 11:34 PM #7
    pics and price of the podi?
    B5 Nogaro S4
    Mk2 Turbo Diesel Coupe
    04 GSX-R 1000
    02 5.9 Cummins
    AutoHausMotors
  8. Member crazexr7's Avatar
    Nov 9th, 2011
    Bristol, CT
    1998 Audi A4 2.8Q, 1968 Mercury Cougar XR7
    05-16-2012 12:10 AM #8
    how much for the passenger mirror? Condition?
    Apr 20th, 2010
    York, PA
    BT 2000 A4
    05-16-2012 12:22 AM #9
    ill have to get you a pic of the podi, its just a standard steering column pod, blue LED, gauge is dual display, EGTs and A:F, if you want id sell the whole kit which comes with the innovate lm1 wideband controller. and why im asking 7k for the engine: simply put i put almost 11k into the damn thing with all the new seals, gaskets, a $1500 machine shop bill, and all the damn things ive broken and had to replace since i built it
    rods: 500
    pistons: 700
    crank: 200
    machine work: 1500
    bearings: 150
    valvetrain: 1200
    gaskets: 280
    new lifters: 350
    APR mains 115
    timing kit 185
    chain tensioner 165
    APR head studs 200
    valve guides 180
    all that is roughly $5600 without labor (i built it myself) and im still missing some stuff
    im also selling it as a complete engine preferably, timed ready to install with accesories. if need be ill start breaking parts up. id probably let the whole thing go for 6, i also have other things to go with it such as the fuel pump etc (deautchworks 300lph) every supporting piece you might need minus a s4 drivetrain
    Apr 20th, 2010
    York, PA
    BT 2000 A4
    05-16-2012 12:28 AM #10
    passenger mirror is fine, i JUST bought that damn thing on ebay for $120 i honestly dont know what they SHOULD go for. its not dimming though, but i see you have a 98 so it will fit in just fine with your d/s blue colored mirror haha
  11. Member Jordan80's Avatar
    Sep 8th, 2010
    Saratoga, NY
    00 Nogaro S4
    05-16-2012 02:24 AM #11
    Quote Originally Posted by colony7 View Post
    Thought it was a boost gauge, sorry about that.
    B5 Nogaro S4
    04 GSX-R 1000
    02 5.9 Cummins
    AutoHausMotors
