Results 1 to 13 of 13
Thread: Wiring help PLZZZ
  1. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    99.5 cabby , 2002 dodge ram 1500
    05-15-2012 05:01 PM #1
    fixed delete
  2. 05-15-2012 09:09 PM #2
    grounds
    Sent from my iPhone using Tapatalk Reihenmotors
  3. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    05-15-2012 09:16 PM #3
    Quote Originally Posted by llanowar View Post
    grounds
    Ya I figured as much. Looked what I believe to be everywhere inside. I know that the ebrake is not only connected to the cluster, but also runs to the running lamps. . No idea where or what to look for at this point. I think I've exhausted options in the car so I guess I need to rip the motor harness out and start looking for problems with that . Maybe melted wires grounding something out
  4. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    05-16-2012 01:35 PM #4
    anymore ideas?
  5. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    05-31-2012 12:47 PM #5
    the cluster works ok'ish when ebrake is up, then fades away when ebrake is down. its got to be something plugged into where it shouldnt be. unfortunately, my friend ripped the whole dash out to do the vr swap so he could get to the fusebox and who knows what wires he plugged in or unplugged. i need suggestions, ANY help will be great
  6. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    05-31-2012 11:26 PM #6
    anybody?
  7. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    05-31-2012 11:55 PM #7
    Did u swap the cluster harness? Or just plug in the VR cluster?
    Boo ya tapatalk! If you haven't got it yet get it!
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
  8. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    06-01-2012 12:18 AM #8
    [QUOTE=sk8too;77628251]Did u swap the cluster harness? Or just plug in the VR cluster?
    I It did it with the cluster harness that was in there , so I swapped it out from a Vr and still the same . All the grounds are good and I put in another engine harness to see if it was a ground on the frame. And it's still doing the same . So it's got to be a wire inside. I'm assuming a wire plugged in where it shouldn't be rather than a wire not plugged in. I need some pictures of the wiring on the inside. I think it's something to do with the wires plugged into or not plugged into the fusebox
  9. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    06-01-2012 10:10 AM #9
    have you tried jumping D8-E2? Its a simple jump wire that worked for me.
    http://a2resource.com/electrical/CE2.html
  10. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    06-01-2012 08:32 PM #10
    Quote Originally Posted by sk8too View Post
    we tried that as well, still same problem. its got to be something with a ground or something that is putting power to a ground that shouldnt be . it works with ebrake up but not down.. still workin on it
  11. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    06-02-2012 12:00 PM #11
    still need help, has anyone heard of this before?
  12. Member Einkaufswagen's Avatar
    Oct 25th, 2009
    N Kingstown, RI
    1999.5 Jetta VR6 GLS, 2000 Jetta VR6 GLX, 2001 Jetta VR6 GLX, 2001 Jetta VR6 GLX
    06-04-2012 12:33 PM #12
    I would defonaly be tripple checking the ebrake electronics. It sounds like it is either pluged in the wrong spot or is shorting out the cluster some how.
    Thats where i would start
    My OEM+ build thread with a twist: Einkaufswagen's Build
    Quote Originally Posted by jaysleeves View Post
    I'm just curious if I should wipe my ass with the left, or right hand? Any input would be appreciated and yes I searched.
  13. Member Bmiller1986's Avatar
    Dec 26th, 2011
    pburg, NJ
    06-04-2012 01:42 PM #13
    Quote Originally Posted by Einkaufswagen View Post
    i went over it a bit, from what i can tell, the ebrake cables run under the floor mats and couple up with the heated seat wires and go to the fuse box, theres only so many wires , and i checked where they go and everything seemed ok
